Reggaebird
Airbus A380 Upper Deck Safety Question
Tue Sep 11, 2007 5:36 pm
I was looking at a picture of the A380 yesterday and noticed that the upper deck windows look smaller than those on the lower deck. After searching through Airlners.net for comments on this, I found out that the windows look smaller because they are slanted by the curvature of the fuselage (optical illusion) giving the passengers an upward view. I also read that this slant prevents upper deck passengers from seeing the ground area around aircraft. If this is true, couldn't that pose a risk to upperdeck passengers in an emergency where they have to judge the safety of an exit route by looking out of the windows? I don't think that there is a similar issue with the upper deck on the 747 as the walls are more vertical than on the A380.
Reggaebird
MadameConcorde
RE: Airbus A380 Upper Deck Safety Question
Tue Sep 11, 2007 5:51 pm
Will we be able to choose our seating at check in (within our class of service of course)?
Whether we want to be on upper or lower deck?  Confused
LifelinerOne
Tue Sep 11, 2007 5:54 pm
Quoting Reggaebird (Thread starter):
Well, probably not, as the plane has been granted it's certification, so the authorities like the FAA and EASA don't share your concern.
Cheers!  wave
Only Those Who Sleep Don't Make Mistakes
jonathan-l
Tue Sep 11, 2007 5:59 pm
You can see the ground from the upper deck windows.
Also, the aircraft is certified by EASA and the FAA and the aircraft has undergone a full evacuation test with EASA and FAA officials present.
Morvious
Tue Sep 11, 2007 6:08 pm
If you get the chance to choose the safest exit that is. I think in most cases you will be glad just to reach the closest one.
have a good day, Stefan van Hierden
airfoilsguy
Tue Sep 11, 2007 7:17 pm
Probably not since you don't get to make that choice. The flight attendants are the people responsible for deciding exit routes during an emergency.
It's not a near miss it's a near hit!!
Bramble
Tue Sep 11, 2007 8:11 pm
The cabin crew judge whether to open an exit or not and monitor it during an evacuation.
The pax do not make a decision based on their view from the window. The airbus door has a downward looking porthole so the crew member can see the area below the door to judge the safety of that area before deploying the slide.
airfoilsguy
Tue Sep 11, 2007 10:30 pm
Quoting Bramble (Reply 6):
Kind of like what I wrote.  eyebrow
JAAlbert
Tue Sep 11, 2007 11:09 pm
so what's the dimensions of the 380 windows?
UAL747
Tue Sep 11, 2007 11:55 pm
Boeing 777's and 747-400's have these as well. They are weird to look through because you look in them and expect to see directly in front of you, but something in the glass changes your point of view. Noticed this on numerous 777 and 747-400 flights. Not sure about the rest of the Boeing or Airbus fleet.
UAL
Gr8Circle
Wed Sep 12, 2007 3:20 am
I've never been on the A380, but believe me, the 747 UD windows have a terrible slant to them.....
XT6Wagon
Wed Sep 12, 2007 4:44 am
depends alot on how stupid you are. One of the last people out of the upper deck nearly managed to make the trip a very painful one as they jumped out from the door, landed part way down and the slide acted like a trampoline and just came short of launching him onto the hanger floor. Managed to land in the last couple of feet. So if you are very agressive in jumping OUT from the upper deck, you just might have a short flight with a hard stop at the end.
Use them right and it seems that its just fine.
Markhkg
Wed Sep 12, 2007 12:46 pm
The evacuation slide on the upper deck of the A380 is designed to minimize the pax ability to "look down" and hesitate at the exit. This was an important design consideration that Goodrich had to implement. If the design still allows for pax hesitation, the flight attendant will push you out.  Wink
Reggaebird
Thu Sep 13, 2007 4:38 pm
Quoting Gr8Circle (Reply 10):
I've flown on the upper deck of 747-100/200/300/400 aircraft and I've never noticed any inward slant of the windows. I love taking photographs from the inside looking out and I've had just as good a view on upper decks as I've had on lower decks. I get the impression that will not be true on the A380.
Reggaebird
474218
Thu Sep 13, 2007 10:55 pm
Quoting Airfoilsguy (Reply 5):
Airfoilsguy is correct. I don't know about the A380 but other planes I have worked on have a prism type window in the door so the view is a close to the fuselage as possible, allowing the FA to determine if it is safe to open the door.
redflyer
Thu Sep 13, 2007 11:22 pm
Quoting MarkHKG (Reply 12):
If not the flight attendant then the panicked passengers behind you clamoring to get out as quickly as possible.
My other home is in the sky inside my Piper Cherokee 180.
N14AZ
Thu Sep 13, 2007 11:50 pm
Quoting RedFlyer (Reply 15):
Exactly, there is a video about the evacuation on youtube: http://www.youtube.com/watch?v=weOcrP7u7Y8
Furthermore, some pictures are provided here: A380 Evacuation Pics (by Kaitak744 Apr 3 2006 in Civil Aviation)
