super80
Question On The 1st B747
Wed Sep 12, 2007 1:56 am
Hi everyone, I was going thru some pictures and I found that the 1st B747 had more than 10 windows on each side on the upper level during the 80s and then it became 3 windows on each side again. Any reason why?
Did Boeing take those windows down or they needed to re-skined the plane?
thanks !
super80
kc135topboom
RE: Question On The 1st B747
Wed Sep 12, 2007 2:03 am
They were covered with window plugs.
northstardc4m
Wed Sep 12, 2007 4:09 am
werent the extra windows actually painted on 001? I remember seeing that somewhere.
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety.
SEPilot
Wed Sep 12, 2007 4:15 am
Quoting NorthStarDC4M (Reply 2):
I suspect you are right; most of the -100's had just the three windows, and I'm sure the prototype did. Certainly it only had three when it rolled out of the factory for the first time.
bullpitt
Wed Sep 12, 2007 4:18 am
hi all
off topic, who got the first 747 and what happened to it?
These are my principles but if you don't like them I have others
imapilotaz
Wed Sep 12, 2007 4:24 am
Quoting Bullpitt (Reply 4):
hi all
Right now it's sitting in Seattle at the Museum of Flight (across the road at the static outside display behind the Concorde). You can get within a foot or two of it, but no ability to go inside of it.
B777Neuss
Wed Sep 12, 2007 4:26 am
See also N7470 in database.
LTU932
Wed Sep 12, 2007 4:29 am
Quoting SEPilot (Reply 3):
I doubt that by the time of rollout, those additional windows were plugged, so I presume that later on, the aircraft got modified for testing the 10 window layout, and later got those windows plugged.
bullpitt
Wed Sep 12, 2007 4:30 am
thanks for the feed back guys.
visityyj
Wed Sep 12, 2007 4:31 am
Nobody. Boeing kept it and it's now in the Seattle Museum of Flight. Well, across the road actually.
bennett123
Wed Sep 12, 2007 4:24 pm
BreninTW
Wed Sep 12, 2007 4:39 pm
I recall reading on here that the first 747's were structurally limited to only three windows in the upper deck. Later aircraft had a structural modification that allowed more windows in the upper deck. It's also been stated that some airlines (TWA) actually plugged the extra windows so that all their 741's would look the same.
gunsontheroof
Wed Sep 12, 2007 6:08 pm
Quoting Visityyj (Reply 9):
As far as I know, nobody other than Boeing has ever flown it. N7470 did some flight testing for the 777 engines prior to first flight/in service, but aside from that, I don't think it's done much besides sit in storage (in LAS if I recall) and look good at BFI.
Users browsing this forum: alggag, Baidu [Spider], Bing [Bot], Boeing778X, ha763, iahcsr, ikolkyo, jakef, jamie86, lebda, MesaFlyGuy, salttee, VirginFlyer and 270 guests
