777way
A332 Tails Some Taller Than Others?
Mon Sep 17, 2007 9:00 pm
Are some A332 tails taller and narrower at the top than other A332, I'm not confusing the aircrfat with A333 which has a shrter tail thats broader at the top, or its just that in photos that seems to be the case.
[Edited 2007-09-17 14:34:10]
LY777
RE: A332 Tails Some Taller Than Others?
Mon Sep 17, 2007 9:06 pm
Can you send a photo to see, please?
BlueSky1976
Mon Sep 17, 2007 9:08 pm
A330-200 does have taller tail than A330-300.
POLAND IS UNDER DICTATORSHIP OF JAROSŁAW KACZYŃSKI AND HIS PUPPET GOVERNMENT. DEMOCRACY SHALL PREVAIL.
OHLHD
Mon Sep 17, 2007 9:13 pm
Maybe it is depending on the angle the photographer is taking the pic.  Smile
USADreamliner
Mon Sep 17, 2007 11:22 pm
Quoting BlueSky1976 (Reply 2):
Really? Or it looks like, because the body is shorter?
Not trying to be a smart ass, just asking.
andrewtang
Mon Sep 17, 2007 11:36 pm
A330-200's tail is indeed bigger and taller than the A330-300. That's because a larger tail is required after shrinking the fuselage size.
Same theory applies in the making of 747SP.
kc135topboom
Mon Sep 17, 2007 11:39 pm
Quoting Andrewtang (Reply 5):
All this time I thought the A-330-200 came out before the A-330-300 did.  Wow!
EI321
Mon Sep 17, 2007 11:41 pm
Quoting USADreamliner (Reply 4):
Nope it is actually taller. This is often required when you shorten a design. The A318 and 747SP also have higher tail extensions than the standard designs.
cloudyapple
Tue Sep 18, 2007 1:13 am
When the fuselage is shortened, the yawing moment arm about the CoG is shortened thus the force is bigger. (re:secondary school physics). So a bigger fin is required to counter the force.
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
PADSpot
Tue Sep 18, 2007 1:17 am
Quoting KC135TopBoom (Reply 6):
Nope the -300 is from 1993 and the -200 from 1998.
777way
Tue Sep 18, 2007 2:14 am
I was asking about A332 only, I know the A333 has a shorter tail, anyways the A332 tail confusion must be related to photo angles.
CJAContinental
Tue Sep 18, 2007 2:20 am
Quoting EI321 (Reply 7):
I am curious as to why this is?
Work Hard/Fly Right.
egnr
Tue Sep 18, 2007 3:57 am
Quoting CJAContinental (Reply 11):
It's due to moments. Consider the aircraft's fuselage as a lever...
It is easier to turn a larger/longer lever than it is a shorter one. This is why people use extension bars on wrenches to undo tight nuts/bolts. A moment is turning force, and it is calculated by the force applied multiplied by the distance from the pivot point. Therefore, on a longer aircraft, the tail can be shorter than on a shorter-fuselage variant to maintain the same level of stability. Also, on the larger tail, the rudder will also be larger to apply more force when used.
7late7, A3latey, Sukhoi Superlate... what's going on?
cloudyapple
Tue Sep 18, 2007 4:47 am
Quoting Cloudyapple (Reply 8):
mop357
Tue Sep 18, 2007 2:20 pm
Does this also apply to the A 343 and the A 346? I always thought the 346 had a short tail but I thought it was due to the comparison of its length. The 343 came out about 8 years before the 346. How did they work that design?
ag92
Tue Sep 18, 2007 8:30 pm
Quoting PADSpot (Reply 9):
Thanks for clarifying that
Also thanks for teaching me something new, in how the tails of shorter aircraft of the same family is taller than others  Smile
Ag92
MEA330
Tue Sep 18, 2007 9:15 pm
Airbus introduced in 2003 improvements to the A330 line (LCD screens, updated interior introduced from the A340-600 line).On the A330-200 a new Fly By Wire rudder control system was introduced with a smaller rudder than older A332's.
The first A332-203 (improved) was for EVA.
777way all EK A332 have the old large fin, while the new Etihad A332's will have the smaller one
777way
Tue Sep 18, 2007 9:23 pm
Taller thinner top
Photo © Dominik Zimmermann
Shorter thicker top
Photo © MUCpictures
So I was right.
[Edited 2007-09-18 14:43:47]
777way
Tue Sep 18, 2007 9:49 pm
Quoting MEA330 (Reply 16):
Thanks for this information, I noticed it on EVA first before on others like KLM and Air Algerie
CJAContinental
Wed Sep 19, 2007 6:48 am
Quoting EGNR (Reply 12):
Cheers, thanks a lot, I understood your answer really well, I study mechanics, so I could completely relate.
