irobertson
B707-400s With RR Conways - Lifespan?
Thu Sep 20, 2007 10:38 pm
Seems that this variant lasted a fairly short life. Was there anything inherently wrong with this variant of the 707? I don't believe any of the type even survives today. I just read about this one, delivered to BOAC in 1960 and broken up in 1977.
Photo © Richard Vandervord
Yet Saha Air and various other air forces continue to fly the -300 variants?
Aleksandar
RE: B707-400s With RR Conways - Lifespan?
Fri Sep 21, 2007 1:53 am
It is just that -320 was more economical and not many of 420s were actually made. Only 37 were made and the last was a plane delivered to El Al in February 1962. The initial advantage of -420 was that it was available two years before JT3 powered 707s
R-E-S-P-E-C-T
bennett123
Fri Sep 21, 2007 1:57 am
Was availibility of Conway spares also a factor.
CV990A
Fri Sep 21, 2007 2:01 am
Quoting Irobertson (Thread starter):
I think the 707 at the Hamburg Airport is an ex-Lufthansa 707-430, so at least one still survives. Also, wasn't it intended as a special variant for BOAC, to encourage them to buy the type?
Kittens Give Morbo Gas
ImperialEagle
Fri Sep 21, 2007 4:16 am
Quoting Aleksandar (Reply 1):
Well, now there are more than a few gray-beards from BA who would dispute that. And BA used quite a few versions of the Conway as well as the JT-3D. I think the better "economics" of the Pratt powered 7-ohs had a lot more to do with politics than numbers.
"If everything seems under control, you're just not going fast enough!"
LTU932
Fri Sep 21, 2007 4:32 am
I presume you mean the JT3D (or TF33). The JT3 was already available on the 707, although the JT3 initially offered as the JT3C turbojet (or J57).
OceansWorld
Fri Sep 21, 2007 4:37 am
BOAC went for the -420 because it had more powerful Conways (17,500lb) than the Intercontinental -320 and its JT4A turbojets (15,800lb). Only 69 -320 were built. I don't think the -320 was that much more economical than the -420. But then came the -320B and -320C both powered by turbofans engines. As a side note, the DC-8-40s weren't sold in great numbers too, just 33 aircraft.
Two other factors played in favour of the RR: less smoky and quieter engines. And they were British-built of course. BOAC got 19 of the production.
Quoting CV990A (Reply 3):
You are right.
MEA-707
Fri Sep 21, 2007 4:41 am
The RR Conways were older and noisier turbojets. The later JT-3Ds were turbofans and, although you can't believe that now, considerably quieter and fuel efficient. The pure jet 707-300s (NOT -300B and 300C ) and DC-8-30s were retired in the 1970s too and compared to that the Conway engined 707-400s survived comparably long.
nobody has ever died from hard work, but why take the risk?
OceansWorld
Fri Sep 21, 2007 4:47 am
A.net B707-400 pictures
This was in service for at least 21 years.
Photo © Paul Kipping
Photo © Simon Thomas
Photo © Michael Fabry
da man
Fri Sep 21, 2007 4:51 am
Quoting OceansWorld (Reply 8):
I do believe that the one at Cosford was scrapped.
War Eagle!
Aleksandar
Fri Sep 21, 2007 5:00 am
Quoting LTU932 (Reply 5):
 yes
Quoting OceansWorld (Reply 6):
Well, I tried to type fast and made few mistakes, so when I mentioned engines I had JT3D in mind and when I mentioned -320 version, I definitely had 320B in mind.
R-E-S-P-E-C-T
OceansWorld
Fri Sep 21, 2007 5:26 am
Quoting Da man (Reply 9):
You right. Too bad.
http://forum.planetalk.net/viewtopic.php?t=1233
jetjack74
Fri Sep 21, 2007 8:01 am
Actually, BA was forced to take the -420 instead of waiting it out for the 336B/C by the British gov't. The British gov"t wanted a 707 with British powerplants so it could be called a British 707. BA was initially unhappy about the -436 because of the handling problems at cruise altitude, due to the short empanage. It was grossly underpowered and less efficient than the VC10. When the -300's began arriving, the -420's were relgated to less lucretive routes in Europe, North Africa and the eastern US until they were transferred over to Airtours in 72-75 timeframe. Most were sold off by 1976.
Correction, they had 20 -420's for BA and 2 -465's were operated by British/Cunard Eagle which eventually migrated to BEA/British Airtours. I believe 2 were lost, G-AWRE in a ground fire at LHR and G-APFE which broke up in flight after take-off from HND in 1966.
Made from jets!
sovietjet
Fri Sep 21, 2007 8:29 am
Were the Conways used on -400s the same as on the VC-10? Did they sound the same? They look different physically to me...there are those "hush pipes" at the end of the Conways on the 707. If they are the same then seeing a VC-10 today is like seeing a Conway powered 707...more or less  Smile
Viscount724
Fri Sep 21, 2007 9:14 am
Quoting MEA-707 (Reply 7):
Sorry that's not correct. The RR Conway was the world's first turbofan, although it had a very low bypass ratio.
In addition to the ex-LH -430 at HAM there is also an ex-LY -458 at TXL. It's been there about 20 years. Although painted in LH livery it's an ex-LY aircraft and was never operated by LH. The photo of it below is fairly old but I saw it there about a year ago in rather poor condition. The ex-LH one at HAM is very well-kept.
Photo © André Oferta
Photo © Axel J.
I think it was 32 -- 15 for AZ, 11 for AC, 6 for CP.
OceansWorld
Fri Sep 21, 2007 3:11 pm
Quoting Jetjack74 (Reply 12):
I meant new from the manufacturer. BOAC has ordered and received 18 B707-436s, while Cunard's order was for two B707-465s. The later only received one under the Cunard Eagle brand, while the second was delivered under the BOAC/Cunard name, which is the 19th. But in all BOAC's B707-400s grew to twenty indeed.
Quoting Viscount724 (Reply 14):
I think it was 32
Yes, that's it. I made a typo.
sovietjet
Fri Sep 21, 2007 4:38 pm
Are you sure? The Tu-124 first flew in 1960 and had turbofan D-20s. I can't find exact dates but I know that Conway 707s and Tu-124 both first flew in 1960.
MD11Engineer
Fri Sep 21, 2007 5:01 pm
The 707 parked beside the runway in TXL is also a 420 (originally built for El Al, it is actually the only plane, which survived the Fatah hijeckings in 1970, where several planes got blown up).
The Conway was a turbofan engine, albeit with a lower bypass rate than the JT3D.
Jan
CV990
Fri Sep 21, 2007 8:43 pm
Hi!
I think that the 707-400 had an interesting lifespan. I was looking at the flying hours of the operators that used the 400 model and most had between 50.000 and 60.000 hours, so quite the average of other 707 models and also they lasted between 15 to 20 years except those that crashed. Here is the list of those 707-400 that were w/o:
G-APFE - 1966/03/05 - Mount Fiji
G-APFK - 1977/03/17 - Prestwick
G-ARWE - 1968/04/08 - Heathrow
VT-DJI - 1971/01/23 - Bombay
VT-DJJ - 1982/06/22 - Bombay
VT-DMN - 1966/01/24 - Mt. Blanc
PP-VJB - 1962/11/27 - Lima
Photo © Mel Lawrence
Photo © John Kelley
Photo © John F. Ciesla
Photo © F. de Ruiter
Only VT-DMN is not here!
CV990, the Maserati of the skies!
Viscount724
Sat Sep 22, 2007 11:01 am
Quoting Sovietjet (Reply 16):
The distinction may be that the Conway was the first turbofan "to enter airline service". Rolls-Royce includes that wording for the Conway in their history timeline.
http://www.rolls-royce.com/history/timeline/1940-1959.jsp
sovietjet
Sat Sep 22, 2007 1:03 pm
Quoting Viscount724 (Reply 19):
Ahhh I see, in that case yes, the Tu-124 entered service in 1962.
