USAirALB
Why Does DL Switch Between Mainline And Connection
Fri Sep 21, 2007 5:35 am
DL always seems to switch mainline and connection at Select cities. For example, ALB had 1 daily flight on a 73g then they switched to connection. Then, they brought back 2 daily mainline flights on a 737-200. The 737-200 were retired and then switched again to connection. Then again, they brought back a daily mad dog. Now currently ALB has no DL mainline. They were supposed to bring back service this fall, but that isn't happening. I checked the schedule from this August and even in Aug. ALB will still have no mainline. When will DL bring mainline back to ALB?
RJ85, F70, E135, E140, E145, E70, E75, E90, CR2, CR7, CR9, 717, 732, 733, 734, 735, 73G, 738, 739, 752, 753, 762, 772, 77W, 319, 320, 321, 332, 333, 343, 388
pilotboi
RE: Why Does DL Switch Between Mainline And Connection
Fri Sep 21, 2007 5:40 am
Only thing I can think of is demand. As most cities have peak travel periods and low travel periods. Schedules are adjusted accordingly and the Connection planes are usually smaller so they are used for the low periods.
JBo
Fri Sep 21, 2007 5:51 am
Quoting Pilotboi (Reply 1):
Pilotboi nails it on the head ... an airline isn't going to send a mainline aircraft to a city if there isn't enough demand to make money on the flight.
A smaller aircraft requires less demand to make money ... it's a much better alternative to either losing money on the route or closing it altogether.
I'd take the awe of understanding over the awe of ignorance any day.
SANFan
Fri Sep 21, 2007 5:52 am
Another example for you: SAN has seen a mix of mainline and Connection/Express flights for a few years now. This fall, they have returned to all mainline (well, except a couple of weaker days of the week on 2 flights) -- 5 flights on 738s and M90s. (In this case, it could be a competitive thing with B6 starting SAN-SLC a month or so ago.)
bb
USAirALB
Fri Sep 21, 2007 5:57 am
its weird though every time mainline comes back, its full
SLCUT2777
Fri Sep 21, 2007 5:58 am
Quoting JBo (Reply 2):
In the instance of DL, they have a shortage of mainline aircraft, so they have to VERY carefully evaluate the needs of mainline MDD/738/752 vs. CRJs. Right now I'm sure it's like pulling teeth without anaesthesia at DL headquarters at ATL.
Quoting SANFan (Reply 3):
 checkmark  DL has worked hard to maintain frequency and available seats between SAN-SLC. They've managed to keep WN out of the mix, but B6 has come swooping in to make this a competitive route.
DELTA Air Lines; The Only Way To Fly from Salt Lake City; Let the Western Heritage always be with Delta!
delta767
Fri Sep 21, 2007 6:15 am
As USAirALB mentions when mainline does return to certain cities like ALB it's full...dont the load factprs rise and fall according to the number of seats offered hence the number of lower fares that can be offered. I dont understand how DL can move a mainline aircraft away from a city like ALB where there is significantly less competition and send it to a city like DCA or ORD (for example) where there is more competition and they will have to lower fares. In the end, they could have charged a bit more at ALB, made more money, and become the "market leader" with larger aircraft.
It's like the chicken and the egg scenario!
kstateinALB
Fri Sep 21, 2007 9:08 am
I'll just say, and absolutely Delta 767 hit it out of the park. Not having any competition is most likely the reason why. Yes, mainline flights are going out full. Yes, it sucks for us not being able to take mainline to ATL. However, if and when FL decides to come in is when DL will bring back mainline. I don't believe thats even a question as to when if FL came in.
ALB, DTW, ORD, MDW, MCI, JFK, LGA, LHR, MAD, MSP, IAD, DCA, MCO, ATL, CVG, TUL, MHK, PHL, PIT, DFW, DAL, CLT, IND, AUS,
pilotboi
Fri Sep 21, 2007 9:21 am
Quoting Delta767 (Reply 6):
Not really - It's not as much supply and demand as it is demand and supply.
If it were like you said, then that means if an airline wants to make more money via a certain city, they just up the number of flights to that city. While this does make sense, it only works up to a certain point. Once you start offering more seats then are actually sold, it's just silly to add more flights, as this won't generally attract more people.
toltommy
Fri Sep 21, 2007 9:51 am
Quoting USAirALB (Reply 4):
You appear to be fairly new here, so I'll give you the standard reply to your statement....
"Full doesn't always equal profitable"
If low yielding fares are needed to fill seats, that mainline aircraft will be moved to a more profitable market.
floridaflyboy
Fri Sep 21, 2007 9:59 am
Bullseye! For example, in BIL, they usually run 4-6 CRJ, and 2-3 CR7 to SLC during the peak season (Mid-May thru Mid-August), while during the slower winter season, it usually stabilizes at about 5-5 CRJ. At one point, they even had Daily CR7 on Comair to Cincinnati during the peak summer season, and nothing during the low winter. However, that didn't return after the CVG downsize. Good route at the time, though.
Good goes around!
Evan767
Fri Sep 21, 2007 10:11 am
So that explains why Richmond has gotten 3x daily 757's ever since FL and B6 came in...
delta767
Sat Sep 22, 2007 5:10 am
Quoting Pilotboi (Reply 8):
I guess it depends on whether the city is close enough to other DL cities where pax will make the decision to drive to neighboring cities based on price. For example, GSO and RDU and CLT. GSO pax drive to RDU and CLT to take DL flights at lower fares, but they would stay at GSO if the fares were lower. When they were lower over the past couple of years, pax filled 5-7 mainline aircraft a day, now they pack in to 1-2 mainline per day and 7 RJs. Not trying to change the subject of this thread, but simply to give an example where sometimes supply does lead to demand. GSO pax are providing the demand, but the supply is consistently being diminished by DL.
gsoflyer
Sun Sep 23, 2007 1:35 am
Quoting Delta767 (Reply 12):
I guess it depends on whether the city is close enough to other DL cities where pax will make the decision to drive to neighboring cities based on price. For example, gso and RDU and CLT. gso pax drive to RDU and CLT to take DL flights at lower fares, but they would stay at gso if the fares were lower. When they were lower over the past couple of years, pax filled 5-7 mainline aircraft a day, now they pack in to 1-2 mainline per day and 7 RJs. Not trying to change the subject of this thread, but simply to give an example where sometimes supply does lead to demand. gso pax are providing the demand, but the supply is consistently being diminished by DL.
You can drive demand elsewhere by numbers (ie making people drive to other cities) while driving up costs locally to reap the benefits of gouging businesses for the service.
