Transpac787
United 757 Fleet
Mon Sep 24, 2007 1:47 pm
Hey all,
Just had a couple questions about the UA 757 fleet. How many ETOPS certified frames does UA have?? And, does anyone know the tail / fleet numbers?? Same for the 3-cabin Premium Service frames....how many, and what are the tail / fleet nums??
Thanks in advance for all replies!!
LAXintl
RE: United 757 Fleet
Mon Sep 24, 2007 1:56 pm
13 p.s. nose numbers 57xx
16 ETOPS 55xx
13 Overwater 56xx
55 Regular 54xx
97 Total
p.s and Etops aircraft will be getting winglets starting next month and will be reasigned new nose numbers
dalb777
Mon Sep 24, 2007 2:08 pm
Quoting Laxintl (Reply 1):
16 ETOPS 55xx
13 Overwater 56xx
What's the difference between the two? If you are going to be over water for a certain amt. of time, you're going to need to have ETOPS.
Geaux Tigers! Geaux Hornets! Geaux Saints! WHO DAT!!!
Transpac787
Mon Sep 24, 2007 2:19 pm
Quoting Dalb777 (Reply 2):
There would be other members far more knowledgeable about it than myself, but to my understanding twins can be flown overwater up to 90 minutes, without having ETOPS rules applied, just "overwater" rules. Beyond that, you need ETOPS. Like I said thought, take that with a large grain of salt!!
16 ETOPS 55xx
13 Overwater 56xx
55 Regular 54xx
97 Total
Thanks for the reply. I knew the 55XX fleet nums were the ETOPS birds, but I never knew what the 56XX designation meant.
What will the new designation be?? 58XX?? And, will it just be the 55's, or will the 56XX's be getting the winglets too??
LAXintl
Mon Sep 24, 2007 2:26 pm
Very different...
Many US airlines have overwater equipped planes that allow operations in areas such as across the Gulf, up and down the East Coast away from the shoreline (>50nm)... The over water equipped planes have supplemental emergency equipment to allow for the off shore routings however not any of the added systems nor operating restrictions of ETOPS planes.
There were a couple threads on the subject last year when Southwest overwater equipped its 737 fleet. SWA Extended Overwater Operations (by PlanenutzTB Jun 1 2006 in Civil Aviation) Something New On Southwest... (by OPNLguy Feb 6 2006 in Civil Aviation)
dalb777
Quoting Transpac787 (Reply 3):
So possible overwater means flights over the Caribbean Ocean or Gulf of Mexico where ETOPS would not be required?
dalb777
Mon Sep 24, 2007 2:27 pm
Quoting Laxintl (Reply 4):
Thanks, thats what I was guessing.
UA772IAD
Mon Sep 24, 2007 2:31 pm
You are correct. It also has to do with the emergency equipment carried on board. Overwater 757s have a bigger slide raft capacity, in addition to additional life rafts. 54XX planes are not equipped with these devices.
I believe the two will have separate designations, since the P.S. fleet warrents its own code for internal purposes: I.E.: Fueling, operations, maintenence, dispatching, ramp, etc.
As for the other 757s, it's my understanding that they will not receive wingletts, as these "ordinary" 57s also fly plenty of short hops, such as ORD-LGA/DCA, or DEN-RNO, in which wingletts are less economical on shorter legs.
Transpac787
Mon Sep 24, 2007 2:32 pm
Quoting Dalb777 (Reply 5):
http://gc.kls2.com/
Just check "90 minutes" and generate the map. According to that, the entire Gulf coast region can be flown under "overwater" rules, not full ETOPS.
LAXintl
Mon Sep 24, 2007 2:36 pm
As of now only 29 winglets planned... p.s. and ETOPS birds, however dont be surprised to see some other UA 757 subfleet changes as we move into 2008.
Transpac787
Mon Sep 24, 2007 3:07 pm
Quoting Laxintl (Reply 9):
Like what?
tdscanuck
Mon Sep 24, 2007 5:35 pm
16 ETOPS 55xx
13 Overwater 56xx
ETOPS has no direct connection to time over water. It's based on time to a suitable diversion airport. It's possible to spend any amount of time you want over water and never require ETOPS. It's also possible to spend the whole flight over land and require ETOPS.
Tom.
UAXDXer
Mon Sep 24, 2007 6:58 pm
Quoting Tdscanuck (Reply 11):
You are correct... Any flight that is over 60 minutes away from a suitable airport will require an ETOPS flight plan.
It takes a bug to hit a windsheild but it takes guts to stick
ConcordeBoy
Mon Sep 24, 2007 11:26 pm
 checkmark
Also, it's possible to fly routes that are non-ETOPS at some times of the day, but are ETOPS-required at night. Africa is full of 'em. Some parts of South/Central Asia as well.
dalb777
Tue Sep 25, 2007 1:38 am
Quoting ConcordeBoy (Reply 13):
Ha, interesting, thanks for the info. I guess I never realized how ETOPS could be required over land in some circumstances, but it all makes sense now.
