nra-3b
AC 767 Incident At YYZ Right Now?
Tue Sep 25, 2007 8:49 am
I just got a text message from my son, Kevin. He just landed at YYZ and said there is an AC 767 on the runway (didn't say which) with fire trucks all around. He also said he was in atc holding for 10-15 before landing. Anybody see anything about this on the news yet?
Bob
lrdc9
RE: AC 767 Incident At YYZ Right Now?
Tue Sep 25, 2007 8:57 am
Flightaware said a AC 762 just landed from flight 423 from YUL. It landed about 20 min. ago as of this post. Probley just some glitch. It looks like it may have circled the airport because it departed 30 min. late, but arrived 1.5 hrs late. Bottom line, all a/c might of been going in to holding patterns and the a/c could of started to run out of fuel. Maybe. Theres nothing in the media about it so it can't be to bad. Also, this flight usually seems to run late. Hope this helps. Peace Out.
Just say NO to scabs.
nra-3b
Tue Sep 25, 2007 9:05 am
Just talked to Kevin a moment ago, He said the aircraft is still on the runway, and the ground crew was fussing around, probably trying to move it. That's all he could tell me right now, they were busy putting their airplane to bed. He will let me know more later if he can....
Bob
sebring
Tue Sep 25, 2007 9:18 am
It looks like AC878 to Zurich, a 763, turned around over Quebec and went back to YYZ.
http://flightaware.com/live/flight/ACA878
Boeing744
Tue Sep 25, 2007 11:07 am
This is interesting. If there was some sort of issue why did they turn back to YYZ instead of just going to YUL or YOW?
MattRB
Tue Sep 25, 2007 11:41 am
Quoting NRA-3B (Thread starter):
Saw this as I was coming off shift at 1930 tonight. It was either sitting on 33R/15L or the Echo taxiway. At least three fire trucks (that I could see) as well as various other emergency and airport authority vehicles surrounding it.
Aviation is proof that, given the will, we have the capacity to achieve the impossible.
Viscount724
Tue Sep 25, 2007 12:02 pm
Quoting Boeing744 (Reply 4):
Possibly because AC has more late departures from YYZ to several other points in Europe (FRA/CDG/LHR) than from YUL which may have made it easier to reroute passengers if the ZRH flight had to be cancelled. ZRH is one of their earlier departures from YYZ I believe.
If they went to YUL or YOW the passengers might be stuck overnight. Obviously in an emergency they would divert to the nearest suitable airport.
sebring
Tue Sep 25, 2007 12:03 pm
Burn off a bit more fuel, perhaps?
pnwtraveler
Tue Sep 25, 2007 12:11 pm
Yes it would be quite easy to be put on one of the late flights to LHR and connect through to ZRH. However if it is still on the taxiway, for that to happen though the passengers would have had to deplane on the taxiway and their baggage removed the same way. Availability of spare aircraft, crew's home base and a number of other factors could have come into play in choosing to return to YYZ. Obviously not a serious enough problem to warrant an immediate landing. Any landing with warning lights etc. of sufficient nature require the firetrucks to be dispatched.
lailaiyyz
Tue Sep 25, 2007 10:31 pm
It should be ACA084. It landed about 6:30pm-ish EDT.
I was listening to ATC while driving home from work. ACA1130 flying above it reported some trail of smoke (as far as I can recall listening). It landed on Runway 15 (probably 15L). I worked under the approach path of runway 15 however, I just leave workd 15 minutes before it happened.. Missed seeing what had happened on the plane.
MattRB
Tue Sep 25, 2007 11:15 pm
Listening to the liveatc archives last night for 2200-2300z. Apparently, from what I can piece together, ACA084 had, what the tower termed as a "considerable amount", a fuel spill as it departed 24R last night. The runway was subsequently closed for a while and arriving traffic diverted to 15R while the runway was inspected.
You can here ACA084 make a call about having the emergency vehicles available in case they were still venting fuel here: http://archive-server.liveatc.net/cy...CYYZ-Toronto-Sep-24-2007-2230Z.mp3 (at the 5:03 mark he makes the call).
DAYflyer
Wed Sep 26, 2007 1:27 am
How often do aircraft "vent fuel"? I have heard of dumping to fuel to meet landing weights in an emergency, but not this.
One Nation Under God
LXA340
Wed Sep 26, 2007 3:25 am
The aircraft arriving from YYZ today was C-FMWV with more than 5 hours delay. Is it the same aircraft that had the incident or was there an equipment change after all?
chrisa330
Wed Sep 26, 2007 5:55 am
The incident involved AC084 which is not YYZ-ZRH but rather YYZ-TLV.
sebring
Wed Sep 26, 2007 6:10 am
Quoting ChrisA330 (Reply 13):
Well, why did the Zurich flight turn around?
chrisa330
Wed Sep 26, 2007 6:28 am
Quoting Sebring (Reply 14):
No idea - however the incident that the thread is referring to is AC 084. Or perhaps I should say the flight that left a considerable amount of fuel on the departure runway, circled back, requested emergency services and landed on 15L is AC084.
JAGflyer
Wed Sep 26, 2007 11:36 am
Perhaps the considerable amount of fuel for a YYZ-TLV flight caused a pipe/tank to crack and leak?
If you flew today, thank a Flight Dispatcher!
sstsomeday
Wed Sep 26, 2007 2:28 pm
Quoting MattRB (Reply 5):
I saw this as well - I was on an AA 737 waiting to depart YYZ-LAX. We were taxing northbound to the northern most East-West Runway, when we first noticed several emergency vehicles of various shapes and sizes waiting side by side on our right, all flashing many red lights, as if they were waiting to see if they would be summoned to the emergency. We sat there for about 10 minutes before moving again.
Then two fire trucks raced past us on our left, southbound down either RW33 or the taxiway next to it. I couldn't see where they were going until we lined up facing west to take off. As we took off I could see the large twin in the distance in AC colors with many emergency vehicles around it. It did not seem to be moving. I thought it was a 330 because it looked larger than a 767, but it was several thousand feet away. It was dusk by this time.
I figured there would be a post about this once I got back to L.A.
Ironically, when my flight landed, we landing on 24R (is that correct - the Northern most runway?) and we waited quite a while before making our way to the gate. Finally the captain said they were waiting for ground crews to "move an emergency A/C," whatever that means...
I come in peace
ATHYEG333
Wed Sep 26, 2007 7:29 pm
sorry but I am a little confused!
can anyone tell us EXACTLY what happened?
MattRB
Wed Sep 26, 2007 9:04 pm
Quoting SSTsomeday (Reply 17):
That would be RWY 23. RWYs 24R & 24L are both situated at the south end of the field
LXA340
Wed Sep 26, 2007 11:29 pm
Maybe this flight was only delayed on the ground due to technical problem with the aircraft / late arrival etc and didn't take off before?
psyops
Wed Sep 26, 2007 11:47 pm
From Transport Canada report:
"The Air Canada Boeing 767-300 series aircraft (operating as ACA084) was departing on a scheduled IFR flight from Toronto (LBPIA) (CYYZ) to Tel Aviv (Ben Gurion) International Airport (Israel) (LLBG). Shortly after departure (2224Z) from Toronto (LBPIA) runway 24R, it was determined that the aircraft was leaking/venting fuel even before departure. Air Traffic Control (ATC) cleared the aircraft into a hold at 5 ,000 feet to burn more fuel before returning to the point of departure. ACA084 landed without incident on runway 15L at Toronto (LBPIA) at 2254Z (winds were 170º at eight (8) knots). Some tires blew during the landing and the aircraft stopped on the runway. The passengers were deplaned with airstairs and taken by bus to the terminal. ATC and the Greater Toronto Airport Authority (G.T.A.A.) handled the situation as a declared emergency."
Viscount724
Thu Sep 27, 2007 9:05 am
Quoting Psyops (Reply 21):
Could you please advise the link to the Transport Canada incident reports site where you obtained that AC incident report. I often refer to the US FAA and NTSB incident/accident report sites but have never been able to find the equivalent Transport Canada site (except the TSB site with final reports of major accidents). Thanks for the information.
Users browsing this forum: 737mnn, A333fan, ADL77W, ASMD11, Delta777Jet, Gasman, Google Adsense [Bot], hongkongflyer, Jerseyguy, kitplane01, kunta67, MCO2BRS, michman, MrBretz, qf002, QuawerAir, Quint1, steex, stevend08, transit, XRadar98 and 216 guests
