phil747
BA777 Scary Landing At LHR Last Night
Fri Oct 05, 2007 1:16 pm
Landing on a BA777 on BA164 ex TLV at LHR on the south runway, the pilot aborted the landing at what seemed to be only a few feet above the runway, (we had certainly passed the BA maintenance base) pulled up sharply on full power and did a 30 mile go around before landing 15 minuted later. He claimed that ATC had not given him clearance to land. My question is how could he h
rfields5421
RE: BA777 Scary Landing At LHR Last Night
Fri Oct 05, 2007 1:22 pm
Old question - probably the same answer.
Clearance to land was given to the pilot - but it was based on the landing aircraft ahead clearing the runway in a timely manner, or some aircraft crossing the runway clearing the runway.
Near touchdown the ATC and/ or pilot - determined the other aircraft had NOT cleared the runway as expected - so a missed approach/ go-around was necessary.
Not scary - happens many times each day around the world at busy airports.
Good pilots are always setup for a go-around on every approach. They main priority is executing a normal go-around which you describe.
Landing is an optional bonus.
chrisnh
Fri Oct 05, 2007 1:31 pm
That happened to me many years ago on a TWA L-1011 going from Boston to St. Louis. We weren't as close to the ground as you were, but we were mere seconds from touching down. Same thing: Power spooled up, and we zoomed around to try again. Cause: an F-16 landed ahead of us and hadn't cleared the runway.
Later that same year, also STL and also a TWA L-1011. This one inbound from SFO. We were only a few seconds from touching down, but there was a decided 'list' to the plane on the right side--our side. I was on the window and realized that our right gear were going to slam onto the runway real hard at the angle we were at. Pilot spooled up and flew us on a REAL tight circuit around St. Louis Airport. Felt like a fighter jet, the tightness of the loop we made in order to save our slot.
Chris in NH
BlueShamu330s
Fri Oct 05, 2007 1:36 pm
Quoting RFields5421 (Reply 1):
Such a clearance can't be issued at night. I therefore presume the landing was expecting a very late landing clearance which turned into a very late go-around due to an aircraft or vehicle on the runway not vacating in time.
Shamu
So I drive a 4x4. So what?! Tax the a$$ off me for it...oh, you already have... :-(
BA777ER236
Fri Oct 05, 2007 1:45 pm
Quoting Phil747 (Thread starter):
Sounds like a perfectly normal 'go-around' at a busy LHR. The runways at LHR are worked to capacity at some times of the day, and occasionally, for a variety of reasons, the preceding aircraft does not clear the landing runway in time, and a go-around results. These manoeuvres, whilst they may be alarming to some passengers, are perfectly safe and practised, and if you don't do one in 6 months of actual flying, you certainly then do a few in the simulator every 6 months - many of them on one engine!
It looks from your post as if you didn't believe the Captain's PA, but there is no reason to doubt what he said, and no reason for him to falsify the information given to you.
You would be correct in the US, however, in Europe, landing clearance is only given when the runway is clear, unless a 'land after' clearance is given (strict separation criteria). 'Land after' clearances are not given at night. In this particular case, a go-around would have resulted from a lack of clearance to land by ATC, or a positive instruction to 'GO-AROUND' by them. This sometimes happens at very low altitude, as described by Phil747.
 Smile
Flying would be easy if it wasn't for the ground
VgnAtl747
Fri Oct 05, 2007 1:48 pm
Missed approaches are very common and you shouldn't worry about it. It's a normal procedure, and has been said, pilots are always prepared and setup for it.
There is a video out there somewhere of a VS atlantic crossing, one of those actual produced retail videos where they film the flight from the flightdeck. The captain actually explains how they setup the go-around procedure just in case...
Work Hard. Fly Right. Continental Airlines
JCS
Fri Oct 05, 2007 1:58 pm
I got it also some time ago at LUT onboard an Easyjet flight.
It was easy down and as easy up again. The pilot was laughing a bit and making some kind of comment like 'there was another bird at our spot'.
beechnut
Fri Oct 05, 2007 2:08 pm
I've been through numerous airliner go-arounds. A bunch of them were weather related (runway not in sight at minimums, or in sight but unstabilized approach), at least two were related to traffic not clearing the runway fast enough (once in a Dash 8, the other time in a 767-233). One was in a 737 in Kunsan, Korea, on very short final, because an F-16 behind had declared an emergency (low fuel I suspect) and we went around to let him in.
There is nothing "scary" about a go-around. It is a well-trained, non-emergency procedure and in fact is a viable option on any approach if circumstances (traffic, weather, etc) dictate one. The only thing I dislike about a go-around is that from a pax perspective, it is a pain in the a$$; setting up for a new approach takes time. The 767 go-around was on my very last leg, late at night, of a long trip from Korea and I was eager to get home; fortunately the captain pulled off his very best C150 pilot imitation, and we did a very tight visual circuit on 24L at YUL, coming back to land, cutting the extra time to a minimum. Fortunately it was late at night and there was little traffic (except for the bugger ahead of us who dawdled clearing the runway).
Beech
cloudyapple
Fri Oct 05, 2007 6:03 pm
Passing the BA mantenance hanger is roughly half a mile from touch and you should be at 160ft, 13-15 seconds from touchdown.
There is on average 1 go around per day and touch luck you were on that one of the day. Nothing special about it.
Big version: Width: 734 Height: 458 File size: 480kb
Quoting BlueShamu330s (Reply 3):
 checkmark  Conditional clearances are only issued in visual conditions.
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
Jerald01
Fri Oct 05, 2007 6:26 pm
The only go-around that I have experienced on a commercial flight was as a pax in a Continental Airlines Electra back in the 60's. IIRC we were landing in daylight at Phoenix, AZ. On VERY short final the pilot executed a VERY steep 360 at VERY low altitude, and during the turn we pax heard four distinct "whoosh" sounds that seemed to come from outside the aircraft.
After a quick roll-out from the 360 the pilot (almost immediately) literally slammed the aircraft onto the runway, giving everyone a pretty good jolt. After turning off the runway and while taxiing in, the pilot made an announcement something like this:
"Ladies and gentlemen, we, and the Navy Blue Angels who were doing barrel rolls down the runway while we were trying to land, wish to welcome you to Phoenix."
Talk about an ATC screw-up!
Well, that wasn't the end of it. After we departed the gate for the outbound flight we were taxiing alongside the runway (at a pretty good clip, I might add), when, all of a sudden, the pilot makes an abrupt stop. He turns the plane around, and, during the turn, we pax got a good view of WHY he had stopped: there was a trench dug completely across the taxiway!
I wouldn't have wanted to have been in that tower when the pilot got finished chewing out some controllers....
"There may be old pilots, and there may be bold pilots, but there are darn few green cows"
ikramerica
Fri Oct 05, 2007 6:37 pm
Your go around sounds routine. I've been on a less routine one, though I hear not uncommon, at LGA. Due to winds, the 757 "floated" a bit on landing and hit too far down the runway, so the pilot did a touch and go and we landed like 10 minutes later. He said it was preferable to stopping in the river. Seemed reasonable!  Wink
RIXrat
Fri Oct 05, 2007 6:56 pm
A few years ago I was coming in from LHR to RIX on a BA A320 and we were lined up perfectly for the landing. This was at about 2330 and we were about 10 feet off the ground, when the pilot suddenly applied the throttle to take us around again. While doing the circle, he came on the intercom and said, "Whoops!" That's it.
I was going to ask what had happened after we landed safely, but the cockpit door remained shut. I couldn't see any other active traffic at the airport. Strange.
jacobin777
Fri Oct 05, 2007 7:09 pm
..happens occasionally..
Here is an aborted flight I had on an AA MadDog-80....take a look at how low we got to..... Smile
"Up the Irons!"
kaitak
Fri Oct 05, 2007 7:10 pm
I guess people could expect to get a little more than "whoops" after something like that, but as has been said earlier in the thread, it's a perfectly normal occurrence. In the old days, when flying was fun and you could get jump seats for landing, I regularly heard crews being told to "expect late clearance for landing", because of other aircraft on the runway; we always got down, but the aircraft is always set up for whatever the G/A procedure is and should the need arise, the aircraft will go around, and this can often be at the direction of ATC.
So, don't worry about it ... two approaches for the price of one; you did well!
tsaord
Fri Oct 05, 2007 7:14 pm
Well to non airline enthusiast who don't fly everyday and do not know what a "go around" is just going back up in the air may seem odd. Might not be scary but it may seem odd and start some mumbles.
RIHNOSAUR
Fri Oct 05, 2007 7:35 pm
hi,
just to add to the discussion, it does not only have to be another aircraft involved to created a missed approach, I for one, was was landing at SJO (which is notorious place for wet and foggy conditions),...we were coming down on AA's A300 bird and i saw out the window how we had just descended just below the cloud celling and actually saw what seemed to be the ground....it was night so it was shard to see
but we all of a sudden pulled back up.....I have never experienced so many g's ...the pilot really "stepped on the gas" (or pressed on the lever i shall say) and we quickly got out of there and began to circle for a while...
the weather was so bad ... to make the story short we landed in LIR Liberia.....
we had to spend the night there....it was a mess...and it was awkward since LIR was NOT prepared to take A300 maxed out on people ......
needles to say.. they couldn't even get a tall enough ladder to get us out.....that was so fun!!!!...
to make matters worse... a delta 737 (or maybe 757) and a continental 737 and a white cargo A300 (which I have seen the pictures of around anet somewhere but I can't remember the carrier's name) had to land there as well...
these planes which came later...were able unload before we did cause they did have ladders that reached their height! people were so confused....hahahah but I wasn't...sorry (self gloss)
The cool thing is that, the next day, it turned to be my first trip ever from Guanacaste to San Jose in such style....
30 min trip from LIR to SJO in an A300!!!!! talk about class and what a unique experience...I had never traveled that fast from city to city in Costa Rica
sorry to get of topic..but the point was that weather can also cause a missed approach
particles and waves are the same thing, but who knows what that thing is...
FiveMileFinal
Fri Oct 05, 2007 8:07 pm
Hell, that happens in London all the time. I'm surprised it doesn't happen MORE often, I've heard us getting landing clearance when we're practically over the threshold!
Quoting Jacobin777 (Reply 12):
I love how the baby starts crying on cue when the Mad Dog goes TOGA. Hilarious.  Smile
You goin'? We fly you dere! You been? We done already flew up in dere!
beechnut
Fri Oct 05, 2007 9:41 pm
Interestingly in my own plane (Beech Sundowner), I have only had one non-intentional go-around (that is, not for practice) since I bought it in 2003, and maybe only 1 or two since 1999 when I resumed flying after a hiatus of many years. The last one was on a crosswind landing. Crosswinds aren't too much of an issue but this one was gusting from slightly headwind to slightly tailwind for the single available runway. When I began my flare, the wind shifted from slight head to fairly significantly tail, and the sudden loss of airspeed caused my plane to start sinking like a stone, while at the same time I was dancing on the rudder pedals to keep lined up. I applied full throttle and got the hell out of there, and came 'round and landed on 23 instead of 05, with no further problems.
Go-arounds are nothing special, just a bit out of the ordinary.
Beech
SAS330GOT
Fri Oct 05, 2007 10:29 pm
Since this thread has become something like a forum to tell your best fishing-tale (it was thiiiis big.. Wink) I'll just give my contribution.
I've experienced quite a few go-arounds, one of the funniest was landing in malta where it actually became more of a touch and go when the pilot came on the PA and said something like "sorry for the inconvenience but there was a helicopter that decided he had the right of way".
I had a quite scary go around on a BA flight from LHR to GOT one early february morning though that actually scared me. GOT is only a CAT II listed airport so minimums are quite tight and mornings are often quite foggy. This time around it was foggy and very windy with gusts at galeforce. It had bee quite a jumpy decent and the final really tossed the poor plane around and just before the flare we got a really strong crosswind gust that more or less threw the plane towards the grass (all I could see through my window was the lawn) and the pilot reacted with full thrust and up we went again. That is actually the only time I've been scared on a plane. I thought that we were about to land on the grass. But around we went and landed safely.
I kinda enjoy go arounds.. Just fun with something out of the ordinary. And I do imagine the pilots enjoy it to since they actually have to do something out of the ordinary.. Or am I wrong?
cheers
awthompson
Fri Oct 05, 2007 11:00 pm
The video raises a major question for me. It does not seem to be a routine go around.......
He turned left directly into the path of the parallel landing aircraft almost immediately after positive rate of climb!
What if the parallel traffic had also decided to execute a late go around? It doesn't look good to me. Was he avoiding something quite close ahead and had no choice in the direction of his turn? This cannot have been the published go-around course?
With workload on the flight deck and the short time period before the left turn, it is unlikely that the captain looked back over his left shoulder to ensure that the parallel traffic had landed. The only possibility is that the tower controller called the go-around and gave the pilot that left turn instruction having verified that the parallel traffic had landed successfully.
Boston92
Fri Oct 05, 2007 11:14 pm
Being a controller at busy airports is a true art form. At a place like LHR, the controller does everything he/she can to separate the aircraft with just the right amount of space and time, but things don't go right sometimes and a go around is necessary.
"Why does a slight tax increase cost you $200 and a substantial tax cut save you 30 cents?"
threeifbyair
Fri Oct 05, 2007 11:15 pm
Sweet video! Looks like 27L at ORD.
Judging by when you can see the 32R markings, you must have been roughly over the 27L numbers before the go-around. What would make the pilots decide to abort landing only feet above the runway? Surely an airplane would be noticeable from further away and I can't imagine ramp vehicles or the like roaming the runway at a major airport.
ORD diagram: http://204.108.4.16/d-tpp/0709/00166AD.PDF
Boston92
Fri Oct 05, 2007 11:22 pm
Quoting ThreeIfByAir (Reply 21):
Well judging that that diagram is to scale, it may be that they were not lined up correctly on 27L...seems to me the 32R markings were just to close...but what do I know?  Smile
hmmmm...
Fri Oct 05, 2007 11:48 pm
Quoting BeechNut (Reply 7):
It is not scary to a pilot, but it certainly is to a passenger who has no clue why the airplane is doing something it normally wouldn't be doing at that point in time. Anytime a plane does something that it normally doesn't do, it is very concerning to the passengers. As far as the passengers know, their airplane could be performing an evasive maneuver to avoid a collision.
An optimist robs himself of the joy of being pleasantly surprised
jacobin777
Fri Oct 05, 2007 11:55 pm
Quoting FiveMileFinal (Reply 16):
LoL...when the baby grows up, it will have nightmares about flying on a MadDog for rest of its life after that "traumatic" experience..
Quoting Awthompson (Reply 19):
...actually I was spotting @ ORD about 10 days ago and I did indeed see an aborted flight in that nature...it was an AA B763ER...
...the plane parallel to us (arriving on 27L) was a MX A32X....it landed after the aborted flight so even if that plane had to abort, we wouldn't have had too much of a problem...I suspect ATC would have made the MX take lower rate of climb and/or make it take a more extreme left bank.....
..thanks.. Smile got lucky on that one! Actually, it was 27R.... Wink
Quoting Boston92 (Reply 22):
...what happened was there was a NW A319 which still hadn't cleared the runway in front of us.....the pilot actually stated "an NW A319 on the runway hadn't cleared"...
"Up the Irons!"
Boston92
Sat Oct 06, 2007 12:53 am
Quoting Jacobin777 (Reply 24):
..thanks.. got lucky on that one! Actually, it was 27R....
27L now. The new 27R is under construction. The old 27L is 28. Hard to understand?:
http://www.flychicago.com/ohare/runways/PhaseIIFlier.pdf
[Edited 2007-10-05 17:54:16]
rfields5421
Sat Oct 06, 2007 1:15 am
Quoting Hmmmm... (Reply 23):
That's the whole point - a go around is expected, anticipated and a normal part of flying.
It is an essential component of every approach. You do not want to fly with a crew which is not planning a go around on every approach.
If you haven't experienced one or several - you're either relatively new to flying or incredibly lucky. Mine have included going over terminal E and B at DFW from 35C, and about six others.
The most exciting go around was at Danang with engines #1 and #2 feathered on an EC-121N.
But educating people that go arounds and diversions are a normal part of safe flying is something this board can do.
AirWales
Sat Oct 06, 2007 6:18 am
It may me 'normal' but it is a little scary. Had the same experience coming into land on a dark wet december morning on a VS 744 from JFK.
AirWales.
EDICHC
Sat Oct 06, 2007 6:24 am
Mmmm well that is one of the reasons a go-around!  Wink
A300/319/320/346 ATR72 B722/732/3/4/5/6/8/742/4/752/762/3/772/3 BAC111 BAe146 C172 DHC1/6/8 HS121 MD80 PA28
hmmmm...
Sat Oct 06, 2007 5:05 pm
Quoting RFields5421 (Reply 26):
You have totally missed the point. How can the passengers know the reason for the aborted landing? How do they know that the pilot is not performing an evasive maneuver to avoid a mid-air collision? How are they to know the degree of separation? Only the pilot can see that. Passengers have no idea why the plane all of a sudden has radically changed its flight mode. It means something unexpected has happened. How unexpected is what they don't know. They can only speculate, and usually people speculate the worst. CAT is also normal, but it is certainly very scary as well. How do the passengers know the reason why the plane just fell, or if the plane will fall further, or if the plane was damaged in the fall? They don't know.
It's like a cop making a traffic stop. Often they get shot at. But it is still unexpected and still scary. But at least a cop can see where the bullet is coming from. A passenger doesn't even have the benefit of being able to see what's ahead. Not being able to see ahead is the essence of the fear of flying, and the main reason for apprehension. Ever ridden backwards on a bike as a passenger? All of sudden every change of direction is scary.
Boston92
Sat Oct 06, 2007 5:12 pm
Quoting Hmmmm... (Reply 29):
 Confused
I was with you until that metaphor.
jacobin777
Sat Oct 06, 2007 6:22 pm
Quoting Boston92 (Reply 25):
...it was 27R when the incident occurred.....is that too difficult to understand?
"Up the Irons!"
pnwtraveler
Sun Oct 07, 2007 1:14 am
My "BEST" go around was on an AC CRJ-100 from DCA to YYZ. This was before 9/11 and the pilots wife was sitting in the jump seat in the cockpit. The door to the flight deck was open as it gets very crowded in there with the jump seat in use. The plane was full and it was one of those odd occasions when there were two f/a on the plane. Since the CRJ lands in a nose down attitude until it flares at the last moment you get a great view down the aisle. A KLM MD11 was tardy in its take off roll and the AC pilot waited until we were over the valley that the Air France happened to call the go round. He immediately came on the pa and said "courtesy of our dutch friends who decided to stay in Toronto a little too long we are going around for another pass." Everyone chuckled as most on the flight were frequent fliers.
Boston92
Sun Oct 07, 2007 3:44 pm
Quoting Jacobin777 (Reply 31):
Hey jerk, calm down, I was not trying to be a prick, I knew that what I wrote sounded a bit confusing so I added a diagram through the link. I was not sarcastic, completely sincere when I said "Hard to understand".
BTW, when runway numbers change, you are supposed to act like that is the way they have always been...so really, you landed 27L.
