JerseyFlyer
738's "not Viable" For Jersey Routes
Tue Oct 09, 2007 12:53 pm
According to this from the BBC, Thomsonfly are reducing their services to JER because its new aircraft (738s) are not commercially viable, due to the "operational limitations" at Jersey.
Apparently they need a longer runway. The flights are only a few hundred miles long so this does not seem right to me. A more obvious explanation would be that the new aircraft are bigger than those being replaced and so more difficult to fill.
Does anyone have more insight on this?
http://news.bbc.co.uk/1/hi/world/europe/jersey/7033959.stm
[Edited 2007-10-09 05:56:03]
ManchesterMAN
RE: 738's "not Viable" For Jersey Routes
Tue Oct 09, 2007 1:01 pm
Interesting. I was in JER a few weeks ago and saw a 738 of XL Airways and I bet they weren't flying out empty...
Certainly what TOM mean is that they can't fill a 738. I don't see any other reason.
Flown: A300,A319,A320,A321,A330,A340.A380,717,727,737,747,757,767,777,DC9,DC10,MD11,MD80,F100,F50,ERJ,E190,CRJ,BAe146,Da
Pe@rson
Tue Oct 09, 2007 1:18 pm
JER's runway is 5,597ft. Didn't BA use 752s from LHR to JER? I believe that the 752 generally has a better climb-out rate. Perhaps SpeedbirdEGJJ could tell us whether the 752s were payload restricted.
I believe that FR will have payload restrictions on flights from BHD (6,000ft).
I wonder what restrictions CO has on its 73G-operated non-stop flights from SNA to EWR - considering SNA's 5,701ft runway and that SNA-EWR would be 4 1/2+ hours.
WN and XL/P9 used to fly 737s from DET - and that has a 5,090ft runway. Anyone know whether the flights were load restricted?
[Edited 2007-10-09 06:21:36]
CHRISBA777ER
Tue Oct 09, 2007 2:10 pm
Quoting Pe@rson (Reply 2):
BA used to use the Tristar in there believe it or not.
I took a BA 735 in and out of there in June and can confirm - it is VERY short.
What do you mean you dont have any bourbon? Do you know how far it is to Houston? What kind of airline is this???
Pe@rson
Tue Oct 09, 2007 2:47 pm
Quoting CHRISBA777ER (Reply 3):
I've flown a BA 735 from there too.
speedbirdegjj
Tue Oct 09, 2007 3:03 pm
Hello James, No the 757's were not payload resticted mainly due to the relatively light take off weight - that and the fact they clim like a rocket  Wink
Its interesting to note that FR used to operate a 732 service from DUB on a summer saturday but stopped for the same reasons that TOM have cited.
XL have infact operated 738's out of JER, as did Helios for a while and HV, but they stop for fuel enroute for anything longer than PMI etc. Infact the breaking point for an Astreaus operated 73G charter series to Banjul was the fact it had to stop both ways.
Chris once and only once an L1011 came here, it way to clear the backlog after a period of heavy fog - well before my time i might add, but i believe they had a whole host of problems with infrastructure etc. This was the main reason behind SATA been refused A310 ops in here during the busy Christmas period in 2005.
Quoting ManchesterMAN (Reply 1):
Not really - its the same reason we (BA) pulled out of GCI, TOM cant operate a 738 out of here year round without payload restrictions that hamper the routes performance, likewise we couldn't send a 735 to GCI.
Pe@rson
Tue Oct 09, 2007 4:00 pm
SpeedbirdEGJJ: taking your experience in Jersey and the restrictions, what would you say would be the answer to the following, including the hot temperature during the summer:
Ryanair737
Tue Oct 09, 2007 5:21 pm
It’s probably more due to the braking distance for the 738 at JER rather than takeoff performance. B738 has quite limiting braking factors on shorter runways with heavier loads, it was a problem at LBA a few years ago when then Britannia used to operate short hauls which led them to withdraw the 738 from LBA, mainly due to available landing distance and sufficient brake temperature warm-up in the summer with high loads. Ryanair don't have a problem at LBA due to the lighter weight of their short distance flights to/from DUB.
TOM have CFM56-7B27 rated engines on their 738s which I'm sure could get them out of JER with not too much trouble, I believe its mainly the stopping distance on the landing run with the 738 that is the main factor at JER.
LAST FLIGHTS= Ryanair LPL-BGY-LPL - EI-DPS/DWV - MAY 08 // NEXT FLIGHTS= TBC
captainsimon
Tue Oct 09, 2007 5:31 pm
The B738 should be able to technically handle Jerseys runway within SOP for both T/O and landing.
I don't think this pull out of Jersey is due to the abilities of the aircraft.
Viscount724
Wed Oct 10, 2007 6:13 am
Quoting Captainsimon (Reply 8):
737-800s operate from SDU in Rio de Janeiro, although only on the 198 nm sector to CGH. The SDU runway is only 4341 ft., more than 1000 ft. shorter than JER's 5597 ft, and ends in water at both ends. And Rio is usually a little warmer than JER.
Photo © André Martinis
Photo © Fabio Laranjeira - Contato Radar
ikramerica
Wed Oct 10, 2007 7:58 am
Quoting Ryanair737 (Reply 7):
BUR is higher and often much hotter than Jersey, and the runway used for landing is almost as short. A320s, 737NG, MD80, 737 classic, RJs and cargo A310s land there. Can't see the 738 being runway limited at JER in terms of landing, but there may be some geographic reasons?
speedbirdegjj
Wed Oct 10, 2007 8:39 am
Quoting Ikramerica (Reply 10):
I really dont know then. All I can add is that those of you who have experienced JER know how tight its appears at times, certainly on those beloved wet windy nights landing towards the sea. Likewise a full -400 seems to take up plenty of runway on departure in the summer. However im not a pilot, nor an engineer so as to whether or not its technically possible I dont know, but as verteran of over 250 landings at JER, IMHO it would get a little 'sporting' in a full -800 in the wet.
AndyEastMids
Wed Oct 10, 2007 9:26 am
When I worked at BMA/BA years ago, the DC-9-10s were operated into JER with an exemption from the CAA. The -30s were OK because they were a little slower over the hedge due the leading edge slat and they had upgrade brakes, but the -10s were an issue. If I remember correctly, the CAA wouldn't allow the use of reversers to be considered when calculating landing / accellerate/stop distances and this was an issue with JER's length on a wet runway for the -10. This was one of [many] factors that influenced the selection of the 737-300/-400 over the MD-80 series to replace the DC-9. Even so, again if I remember correctly the -400 was payload restricted to the further destinations like GLA and EDI. Ironically, after BM decided the MD-80 was not viable for JER ops, Transwede started operating MD-80s to ARN - but of course, they operated under a different authority!
I suspect that the 738 has some sort of issues at JER, broadly similar to those above.
A
757lgw
Wed Oct 10, 2007 9:39 am
Yes this is correct there is no way we can get out of BHD with a full load of passnegers it is the same at LDY which is 80ft longer than BHD, at LDY we can have an absolote maximum of 141 passengers out of the 189 seats.
We i disagree with you , i see the probelms we have with our -800 on runways that are longer than JER so i can completly see how the -800 is impractical for JER, it would have to go near on empty. I beleive the breaking distances are the main problem with the -800. While it can get airbourne with higher weights on shorter runways it can not land and succesfully break on them.
Ryanair737
Wed Oct 10, 2007 11:12 am
BUR has 6,886 feet of runway, JER has 5,597 feet. JER has more than 1000 feet less in runway length than BUR so therefore your statement is void.
Quoting 757lgw (Reply 13):
Yep that is correct. That is the reason which I said before that Britannia pulled out of LBA a few years ago with the the 738, it was the the very same reason and they were operating on full loads during the summer. LBA has even more runway length available than JER so you can see why JER has problems with the 738.
captainsimon
Wed Oct 10, 2007 4:11 pm
Quoting Speedbirdegjj (Reply 11):
You want to land at Blackpool then in the rain with a crosswind! LOL
Ryanair737
Wed Oct 10, 2007 4:21 pm
Quoting Captainsimon (Reply 15):
I think RYR are pax restricted to GRO from BLK as well, although I could be wrong - that is what I heard.
[Edited 2007-10-10 09:23:49]
Falcon Flyer
Wed Oct 10, 2007 4:35 pm
I agree. Is it possibly related to JER being a lower yield destination ? Maybe some our Channel Island friends can jump in.
My definition of cool ? Not trying so hard to be cool.
ikramerica
Wed Oct 10, 2007 4:59 pm
Quoting Ryanair737 (Reply 14):
Sorry, but typically planes land on the 5801 foot runway (8/26), NOT the 6800 footer (15/33). It is only reversed during adverse wind conditions.
http://en.wikipedia.org/wiki/Bob_Hope_Airport
And 8/26 has a pesky 7000 foot mountain range at the far east end of it, just for fun, so an aborted landing needs a pretty decent climbout performance.
Don't "void" people's statements before doing a little research to see if you are right. Saves embarrassment...
edit: fixed link
[Edited 2007-10-10 10:00:11]
bananaboy
Wed Oct 10, 2007 5:32 pm
Also saw XL 757 on a charter to RHO from there - looked pretty full. Incredible performance, when you think about it.
N1120A
Wed Oct 10, 2007 10:11 pm
Remember, those flights were both short haul and using lighter aircraft.
None that I know of, but that is the -700, not the -800. AQ also flies SNA-OGG/HNL with the 73W, which requires even higher weights because of the jet stream.
The statement was about the landing, not take off runway.
speedbirdegjj
Thu Oct 11, 2007 8:11 am
Quoting Falcon Flyer (Reply 11):
JER itself isnt a low yielding destination, Its more a case of the LCC's chasing volume which has forced the markets price expectations down. I use the TOM DSA route quite often when returning home to watch football and have never paid more than £50 rtn including tax. The aircraft is however always busy, but im not sure how this yield/volume ratio stacks up against some of their other routes.
On the other hand JER is very high yielding for BA, with often as many as 20-30 people paying the full J rate on the 7am departure (£415 inc) so it cant really be argued that the Island itself is low yielding.
I did post a lengthy reply on my thoughts on this yesterday but it appears to have dissappeared, but in summary I basically concluded that I have no doubt you would struggle to operate a -800 year round (i've got 8 years airlines experience in JER in both ops and commercial). However, this factors aside I am also sceptical as to whether TOM could profitably operate and aircraft that large on a routes that are low yielding, albeit as a result of the benchmarks they set themselves.
XT6Wagon
Thu Oct 11, 2007 8:38 am
Sounds like they don't want to operate the full short field package on thier 738... I'm assuming that the recently built ones have atleast the parts of the package Boeing found to be "free" performance additions. Which just leaves things like the sealed flaps and some other small bits for the "costs more MX time and money, for more takeoff/landing performance" IIRC. Certainly makes sense as a subfleet of special 738's just adds cost and headaches, for all that its "possible" to get a good bit better field performance.
But yes, its likely that the airport has a nasty problem of flights you can do with the 738 from it... would be better done by oh say Q400/RJ service with higher frequency and easier control over loads (easier to dump one flight a day rather than 1/3 of a 737). The flights better done with the 738... are not possible w/o higher MTOW under those conditons.
