747400sp
LH Flights To Charlotte N.C.
Tue Oct 09, 2007 11:21 pm
This past weekend I was in Charlotte N.C. and I saw a Lufthansa A330 climbing out of Charlotte Airport. Was this a charter flight, or do Lufthansa have flights to and from Charlotte Airport using Airbus A330?
Flighty
RE: LH Flights To Charlotte N.C.
Tue Oct 09, 2007 11:25 pm
They do have a scheduled flight: CLT-MUC, which has been around for years. It may not be daily right now... depends.
CIDFlyer
Tue Oct 09, 2007 11:28 pm
yes, the LH CLT-MUC flights connect the two Star Alliance hubs
Bicoastal
Tue Oct 09, 2007 11:50 pm
It's affectionately known as the BMW Express. Large BMW facilities in the American south need a lifeline to HQ in Munich.
Airliners.net has many forums. It has spell check and search functions. Use them before posting!
doug_or
Wed Oct 10, 2007 12:05 am
Up until last year I tihnk it was conducted by A340
When in doubt, one B pump off
GBan
Wed Oct 10, 2007 12:25 am
Quoting Doug_Or (Reply 4):
According to the LH flight plan (http://www.lhtimetable.com/LH.pdf) CLT-MUC is a 343 during winter (Wednesday through Sunday daily) and a 333 in summer (daily except Tuesday).
deltadawg
Wed Oct 10, 2007 12:36 am
Quoting Bicoastal (Reply 3):
It's not just BMW, it's also Siemens & ABB in Charlotte, Greenville and many other smaller companies such as Treutzler (textile machinery - Gastonia, NC). I used to think it was a dumb route for LH but it has been around much longer than the BMW plant and the 2 times I flew it it was about 90%+ full. The winter ski season is just a great by-product but the real meat is as you say, the German corporate pipeline.
GO Dawgs, Sic' em, woof woof woof
RDUDDJI
Wed Oct 10, 2007 1:09 am
Quoting DeltaDAWG (Reply 6):
False, the BMW plant has been there (GSP) at least 10 years. The LH flight has only been around 2-3 years. As mentioned above, the flight is to connect the two *A hubs.
Sometimes we don't realize the good times when we're in them
earlynff
Wed Oct 10, 2007 11:35 am
Quoting RDUDDJI (Reply 7):
LH had the first CLT-FRA service many years ago. I think they discontinued, when US also started this route, that was even before *A-times, IIRC
Cubsrule
Wed Oct 10, 2007 4:46 pm
Quoting GBan (Reply 5):
I wonder if they were having performance issues with the 343 in the summer. 10,000 feet should be plenty of runway, but CVG-CDG on an AF 343 routinely takes (took?) 8000 or 9000 feet in the summer even when it wasn't particularly hot.
earlynff
Wed Oct 10, 2007 5:57 pm
I had put a post here couple of hours ago, were did it go, to the wastebox??
Not quite true: LH had the first non stop service to CLT many years ago, from FRA. They discontinued that service when US discovered this segment. All that was long before *A-times, IIRC
earlynff
Wed Oct 10, 2007 5:59 pm
really funny, now it´s showing up again!!??
MSYtristar
Wed Oct 10, 2007 6:01 pm
Quoting EarlyNFF (Reply 9):
I'm pretty sure they flew either DFW-CLT-FRA or IAH-CLT-FRA with the 74M...can't remember which one.
earlynff
Wed Oct 10, 2007 6:09 pm
Quoting MSYtristar (Reply 12):
with the 74M...
must have been B742. Not B744.
MSYtristar
Wed Oct 10, 2007 6:13 pm
Yes it was the B742. I remember seeing those flights in the OAG's. I think they used the 74M code...pretty sure of that. This was in the early 90's.
Adam T.
Wed Oct 10, 2007 6:57 pm
Quoting MSYtristar (Reply 11):
I knew about the LH CLT-FRA flight but I did not know it continued to service to DFW or IAH.
N1120A
Wed Oct 10, 2007 7:08 pm
Not just the South, but specifically in Spartanburg, SC. Further, you add other German interests, a major banking center and the only true STAR hub in the South Eastern US and you have good reason for the flights.
Quoting Cubsrule (Reply 9):
Absolutely not. That route is not even at half of the A343's range band. The A333 is used likely because it is more fuel efficient and because the A343 is wasting tons of range.
Quoting MSYtristar (Reply 14):
Initially, about half of LH's 744s ordered were combi aircraft. All were eventually converted to full PAX.
Cubsrule
Wed Oct 10, 2007 7:13 pm
Quoting N1120A (Reply 15):
Not a range issue, a runway performance issue. 343s have lovely range, but they hog runway like crazy, and CLT, though it's not very high, can get plenty hot in the summer.
vega
Wed Oct 10, 2007 8:35 pm
Since he's talking about CLT-MUC (the only existing LH flight), EarlyNFF is correct.
CLT-MUC service started March 26, 2004 - a little over 3 years ago.
CLT-FRA service started August 1991 and ended October 1992 (14 months) with a 747. Was advertised as discontinued due to poor revenue,
We are but a moment in this vast Universe and when gone we will never have existed.
N1120A
Wed Oct 10, 2007 9:46 pm
Quoting Cubsrule (Reply 16):
The A343 has plenty of runway performance for their mission. The climb may not be impressive looking, but they get off the ground in a reasonable time. If the aircraft can do SXM-CDG non-stop, it can do CLT-MUC.
vega
Wed Oct 10, 2007 10:17 pm
Quoting Vega (Reply 18):
Sorry, RDUDDJI, I disconnected the reply thread. Should read "Since he's talking about CLT-MUC (the only existing LH flight), RDUDDJI is correct".
Ryefly
Wed Oct 10, 2007 10:55 pm
The route started off as a A340-300 and now is mainly A330-300's. I do see a A340-300's fly over my house every once in a while. A couple of times I even saw the A340-600 fill in for the smaller Airbus.
caspritz78
Wed Oct 10, 2007 11:04 pm
I think it has to do with the general use of the a/c during the summer LH has for example two daily flights from FRA to BOS. In the winter only one. So I just think they need the 343 in the summer for different routes and can't spare it since US has a hub in Charlotte and can take some of the traffic with code share flights.
ILCFII
Wed Oct 10, 2007 11:34 pm
yes, they have service to FRA. Not sure if its daily but atleast 5x a week from what I've seen.
gigneil
Wed Oct 10, 2007 11:35 pm
A340s have fairly decent runway performance - you see pilots taking advantage of whatever is available to them because its good for the engines.
NS
safetyDemo
Wed Oct 10, 2007 11:46 pm
They have regularly scheduled flights to Charlotte. I think its Munich, off the top of my head, for some reason. But it could be FRA. Whichever one it is it leaves just before USAirways own flight to the same destination - which always bewildered me.
Please direct your attention to the flight attendants in the cabin...
AlexPorter
Thu Oct 11, 2007 12:05 am
They have flights to Munich. I don't know why they don't fly to Frankfurt (their bigger hub) instead, but the flight mostly exists because CLT is a Star Alliance hub because of US Airways.
Last Flight: SCX701 MSP-PHX B738 8Jan2008
gigneil
Thu Oct 11, 2007 12:26 am
US Airways serves CLT-FRA already, so this is a fairly good way for LH and US to cover the market.
NS
earlynff
Thu Oct 11, 2007 12:54 am
as I mentioned before, LH started CLT-FRA service around early nineties, no U.S. competitor then. when US stepped in, (a rival then), market was not big enough for both. Now, as *A partners, they share the tarts.
AlexPorter
Thu Oct 11, 2007 5:41 am
Quoting AlexPorter (Reply 26):
Okay, for some reason when I wrote this it seemed as if nobody had replied. As it turns out, this thread is over a day old. Bug alert! Sorry if I repeated information in that case, I thought I was reply 1!
cltguy
Thu Oct 11, 2007 1:37 pm
They still run the A340-300 on the CLT-MUC route on Wednesdays. All other days it is A330-300. The A340-600 has also made an appearance as a substitute aircraft.
Cubsrule
Thu Oct 11, 2007 5:24 pm
Quoting Gigneil (Reply 23):
I'm certainly not asserting that the 343 cannot fly the route. However, given the fact that LH wants to pack as much cargo on the flight as possible (CLT-MUC, like the other CLT-Europe flights, prints money on cargo), I'm simply wondering if the 333 is a better choice in the summer.
vega
Thu Oct 11, 2007 10:06 pm
Quoting Cubsrule (Reply 30):
LH uses the 340-300X daily year round FRA-ATL, which is 200nm further, 250 higher, hotter than CLT and surely would have at least as much cargo as CLT-FRA
