KarlB737
NTSB Officials Investigate Rough Landing At ORD
Wed Oct 10, 2007 10:26 pm
I have only experienced this kind of landing once. It was on an Eastern DC-9 landing at ATL if I remember correctly. In fact I think it was during the brief "New Eastern" period. I have often wondered how many of these unfortunate experiences an aircraft can take. Do any of you have any additional info regarding this specific United flight?
Courtesy: WLS-TV
http://abclocal.go.com/wls/story?section=local&id=5700736
bond007
Wed Oct 10, 2007 10:33 pm
KELPkid
Wed Oct 10, 2007 10:38 pm
Quoting Bond007 (Reply 1):
Top of this list:
http://icarus.red1aviation.com/jsp/accident.jsp
Jimbo
And then I read from there:
DAMAGE TO THE AIRCRAFT SUBSTANTIAL, CHICA
At first, I thought it was unusual that the NTSB was investigating this (rather than just an FAA investigation). I think "Subtantial Damage" falls in the realm of NSTB 830... Any word from anyone in the know what the damage was precisely?
Ward86IND
RE: Ntsb Officials Investigate Rough Landing At Or
Thu Oct 11, 2007 1:59 am
"N431UA, UNITED AIRLINES FLIGHT 628, AN AIRBUS A320 AIRCRAFT, LANDED HARD, BLEW A RIGHT MAIN TIRE, WENT OFF THE RUNWAY, RE-ENTERED THE RUNWAY AND TAXIED TO THE GATE, TWO PERSONS ON BOARD SUSTAINED UNKNOWN INJURIES, DAMAGE TO THE AIRCRAFT SUBSTANTIAL, CHICA"
Damn, sounds pretty major. It's gonna be on the local news here in an hour...
Live your dream.
B757capt
RE: Ntsb Officials Investigate Rough Landing At ORD
Thu Oct 11, 2007 3:14 am
The pictures on the news were amazing!!!! the engine looked like the AirTransat L1011 that flew through hail years ago.
Looked like damage to the bottom, like a runway-taxiway light.
The views written by this user are in no manner the views of my employer and should not be thought as such.
QF108
Thu Oct 11, 2007 3:16 am
There's an ATC recording of this incident from liveatc.net
http://www.liveatc.net/forums/index.php/topic,3735.0.html
Blessed are the Cheesemakers !
andrewuber
Thu Oct 11, 2007 7:17 pm
There's another curious incident listed above that one -
"N652DL, A DELTA AIRLINES CARGO BOEING 757 AIRCRAFT, WHILE BEING PUSHED BACK FROM THE GATE TO OVERNIGHT PARKING AREA, HIT ANOTHER TUG CART AND SUSTAINED UNKNOWN DAMAGE TO THE NUMBER ONE ENGINE COWLING, NO INJURIES REPORTED, SEATTLE, WA"
Delta Cargo 757??
I'd rather shoot BAD_MOTIVE
flyorski
Thu Oct 11, 2007 7:55 pm
Quoting AndrewUber (Reply 6):
Delta Cargo 757??
That has got to be a mistake.
"None are more hopelessly enslaved, than those who falsly believe they are free" -Goethe
rfields5421
Thu Oct 11, 2007 8:08 pm
Those FAA incident reports are filled with errors quite often. Wrong aircraft type, wrong airline, wrong registration, wrong airport, etc.
Secondly such incidents are pretty common - though it has been a relatively quite past two weeks (the live data on the FAA web site)
10/3 - Mexiana A320 hit by a deck loader in LA
9/30 - Comair5292 - CRJ - left wingtip struck the rear view mirror of a fuel truck while taxi to gate - BOS
9/28 - Falcon 50 at TEB - while taxi left wingtip struck and airport steam roller
The more exciting ones were:
10/8 - FLG2997 CRJ two bird strikes on approach at XNA minor damage
9/29 - Aloha B732 blew a main gear tire on departure - rtn to HNL
9/29 - ATA B737 bird strike on departure collapsed windshield with minor injures to one cockpit crew - rtn to PHL
9/27 - DAL B757 discovered after landing main tire blown with "unknown damage" to wing.
BoeingBoy
Thu Oct 11, 2007 10:12 pm
The NTSB does not investigate HARD Landings
10% is the best we can do
midway7
Thu Oct 11, 2007 11:15 pm
Quoting QF108 (Reply 5):
http://www.liveatc.net/forums/index.....html
What do you click on at the liveatc website to play the audio? I've tried several links, but for some reason cannot listen to it. Do you have to be a member?
Thanks in advance.
Midway7
QF108
Fri Oct 12, 2007 1:13 am
Quoting Midway7 (Reply 10):
Midway,
Yes I think you do have to register to hear the file, its free and is an excellent website. The file will appear once you login.
KELPkid
Fri Oct 12, 2007 1:25 am
Quoting BoeingBoy (Reply 9):
They do if the HARD landing results in SUBSTANTIAL damage, this is a notification item in NTSB 830  Wink
http://frwebgate.access.gpo.gov/cgi-...LE=49&PART=830&SECTION=5&TYPE=TEXT
TITLE 49--TRANSPORTATION
CHAPTER VIII--NATIONAL TRANSPORTATION SAFETY BOARD
PART 830_NOTIFICATION AND REPORTING OF AIRCRAFT ACCIDENTS OR INCIDENTS AND
Subpart B_Initial Notification of Aircraft Accidents, Incidents, and
Overdue Aircraft
Sec. 830.2 Definitions.
As used in this part the following words or phrases are defined as
follows:
Aircraft accident means an occurrence associated with the operation
of an aircraft which takes place between the time any person boards the
aircraft with the intention of flight and all such persons have
disembarked, and in which any person suffers death or serious injury, or
in which the aircraft receives substantial damage.
(Emphasis mine)
Sec. 830.15 Reports and statements to be filed.
(a) Reports. The operator of a civil, public (as specified in Sec.
830.5), or foreign aircraft shall file a report on Board Form 6120.1/2
(OMB No. 3147-0001) 2 within 10 days after an accident,
freshlove1
Fri Oct 12, 2007 2:28 am
Quoting B757capt (Reply 4):
Anyone got a link to the pictures?
jogales
Fri Oct 12, 2007 4:19 am
Quoting RFields5421 (Reply 8):
That was actually TRS.
bond007
Fri Oct 12, 2007 12:57 pm
They do and they are!
All depends on the damage, as discussed.
Jimbo
joness0154
Fri Oct 12, 2007 1:20 pm
Yes, if the NTSB believes it is a safety of flight issue, it will be investigated. You are only required to report the accident or incident if it falls under Part830, but every morning when I interned at the NTSB we got a fax from the FAA that would list almost any deviation that happened the previous day (altitude, airspace bust, aircraft damage, etc) and we would call and investigate if we believed that it involved a safety of flight issue.
Last summer, I assisted in the (very limited) investigation of severe altitude deviations by commercial airliners, the 777/MD-80 collision at ORD, and some other airline related stuff, along with actual accident investigation.
I don't have an attitude problem. You have a perception problem
ltbewr
Fri Oct 12, 2007 1:40 pm
Sounds like the original topic situation of a UA flight landing at ORD would qualify for being a 'substantial' incident requiring the NTSB to investigate. A tire blew out, the aircraft went off the runway, damaging the engine cowlings and possibly the landing gear. It will be unflyable for now, will be out of service for at least several days and a number of parts may have to be replaced. There could be further and serious damage to the engines and landing gear that could put the a/c out for at least a week or more. One thing in favor of this a/c was that this incident occurred at a major airport and one that is a hub for UA, so I suspect they have the mx staff and facilities to do much of the work there. Of course, they could just do a temp patch job at ORD and do a deadhead flight to UA's main mx facilities.
