7e72004
Cape Air Flight On 11/13 From IND-SBN
Sun Oct 14, 2007 11:33 pm
Hello all...it has been a while since i have posted anything on the website...i think almost an entire year  Smile Anyway, i am on the first flight from IND-SBN on Caper Air on 11/13. Since those planes are pretty small and the passengers can see out the cockpit window, what are the chances that i would be able to get a couple of pictures? THis would be the obvious prime opportunity to get a few "bird's eye" view shots of landing, etc. thanks and cheers  Smile
The next generation of aircraft is just around the corner!
DeltaAVL
RE: Cape Air Flight On 11/13 From IND-SBN
Mon Oct 15, 2007 12:07 am
I'm sure they wouldn't mind a bit. Have fun on Cape Air; I've heard the crews are very nice and accommodating.  Smile
"We break, We bend, With hand in hand, When hope is gone, Just hang on." -Guster
ERJ170
Mon Oct 15, 2007 12:09 am
So, who approached whom for these flights?
Aiming High and going far..
7e72004
Mon Oct 15, 2007 12:29 am
I believe that IND, SBN, EVV approached Cape Air. I believe that the federal funding that was available to the airports would have to be returned, or something unless it was used for air service between IND-EVV, SBN. Obviously, the prior airline (ATA Connection) pulled out of those flights after a pretty short time. This time around, i think the flights will be successful-considering there are only 9 passengers that can fit onto the planes, so it should be easier to fill them up.
