a380900
A380 Reliability - What To Expect?
Thu Oct 18, 2007 10:16 pm
A few question about the introduction of the A380 and the introduction of aircraft in general:
What is the expected reliability of a new type? What would be good, what would be worrisome? Airbus is said to have dispatched 20 people to Singapore to check on the plane. Can that last for long?
What types have had the most serious teething problems in the last thirty years? How long to they last?
Due to the ever changing configuration of the A380 until msn 26, should we expect much longer teething problems?
How long before a plane reache its long term dispatchability rate? How high can it be ?
Thank you to all the knowledgeable people who can shed some light on this.
flysherwood
RE: A380 Reliability - What To Expect?
Thu Oct 18, 2007 10:20 pm
I have read that the SIA pilots that have flown it are really impressed with the A380.
KFLLCFII
Thu Oct 18, 2007 11:19 pm
Quoting Flysherwood (Reply 1):
What have the SIA maintenance folks said?
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
EI321
Fri Oct 19, 2007 12:18 am
Quoting KFLLCFII (Reply 2):
Its really too early to know. Even though they have presumably been trained on the aircraft, we will have to wait until the aircraft enters revenue service to get a picture. It has however been tested more than any other airliner to date so I cant forsee many issues arising outside the usual [and expected] teething ones.
Stitch
Fri Oct 19, 2007 12:30 am
With all the time these birds have spent in the air during the past two years, I expect the airframes to be very reliable.
If anything breaks, it will likely be customer-sourced equipment (seats, IFE, galleys and lavs, etc.).
redflyer
Fri Oct 19, 2007 1:31 am
Quoting Stitch (Reply 4):
Indeed, I would think the dispatch reliability of the A380 will set a record for a new-in-service aircraft type.
I would think even those things will be pretty reliable. The vendors have had ample time to tweak the equipment, albeit perhaps not in a real-world setting.
I'm going to guess that any reliability issues will stem from ground maintenance crews either creating dispatch issues or being unable to prevent dispatch issues as a result of their lack of real-world experience on the birds. But I think even those will be put behind them quickly.
My other home is in the sky inside my Piper Cherokee 180.
kaitak744
Fri Oct 19, 2007 1:35 am
Quoting RedFlyer (Reply 5):
I believe the best record for reliability of a new type is held by the 777-300ER?
If not, which aircraft is it?
tdscanuck
Fri Oct 19, 2007 1:45 am
Quoting A380900 (Thread starter):
The expected reliability goes somewhat inversely with size, so even a mature A380 will probably have a lower reliability than an A320 or 737. That's mostly due to complexity.
Dispatch reliability over 95% initially would probably be considered good. Under 90% would be bad. The grey area in the middle is hard to fathom.
I doubt they'll keep 20 people in Singapore for a long time, but certainly until they get their 3rd airframe. Until then, there's no backup so they need to fix anything and everything that goes wrong on overnights. Apparently, they'll actually have a Panasonic engineer onboard to make sure the IFE plays nice.
747-400 had a very rocky start in getting all the avionics and BITE to talk to each other. A320 had major issues with the FBW system at first. Given that we only get a new plane from each OEM about every 10-15 years, there are always a bunch of new technologies and they never work exactly like they're supposed to.
I doubt it. The final configuration of MSN 0001-0026 should end up pretty close to the production configuration once all is said and done. Plus, all of the little faults that come about during production should have been eliminated on the early airframes long before they get into a customer's hands.
I'm not sure how long it will take. Given the low build rate on the A380, several years is probably normal. Dispatch reliability can hit 99.7-99.8% on a narrow body, but I don't think any widebody fleets get that high.
Tom.
redflyer
Fri Oct 19, 2007 2:56 am
Quoting Kaitak744 (Reply 6):
I'm not sure a variant would be good to compare to a completely new type. However, the original 777 had a dispatch reliability rate in its first 3 months with UA of 97.7%, which I think was a record at the time and probably still is for a widebody.
In its first three months of revenue service, United Airline's 777 fleet has experienced a cumulative schedule reliability of 97.7 percent, he said. Schedule reliability is the industry measure for the percentage of time an airplane is free of mechanical delays and able to leave a boarding gate within 15 minutes of scheduled departure. This is a dramatic improvement over the introductions of the 767 and the 747, which achieved this level at 18 months and 38 months respectively.
http://boeing.com/commercial/777fami...news/1995/news.release.951030.html
With all the flight testing the A380 has undergone during the past 2 1/2 years, not to mention its more advanced design, I would think it should have no problem achieving a similar dispatch rate even though it is a quad and much bigger.
RayChuang
Fri Oct 19, 2007 3:07 am
Given the much longer testing period, I expect the A380-800 to be quite reliable.
starrion
Fri Oct 19, 2007 4:29 am
isn't it going to be difficult to get a statistically meaninful dispatch rate with only a couple aircraft in service?
One aircraft has a persistant oddball reading and the dispatch rate could be thrashed.
Knowledge Replaces Fear
wjcandee
Fri Oct 19, 2007 4:56 am
Didn't the 753 have an extraordinarily-good dispatch reliability when it was introduced? I thought that Condor had it up near 99% very quickly. Of course, that's a variation on an already-very-reliable airplane.
United787
Fri Oct 19, 2007 7:08 pm
Didn't the EMB-175 have a lot of teething problems at AC; something with the electrical system?
474218
Sat Oct 20, 2007 1:57 am
Quoting Tdscanuck (Reply 7):
Modern airliners have a dispatch reliability of 98% or better. Dropping to 97% or lower raises all kind of read flags at the manufacture and operator.
tdscanuck
Sat Oct 20, 2007 2:41 am
Quoting 474218 (Reply 13):
That's definitely true for a mature program but service-entry is a whole different ballgame. I'd be very surprised if any new type entered service at 97%+.
Tom.
