Super80DFW
Delta At DFW
Tue Oct 23, 2007 1:06 am
Back when DL had a big operation at DFW, where did they fly to? Did the fall of DL at DFW effect AA in anyway?
"Things change, friends leave, life doesn't stop for anybody." -- EAT'EM UP EAT'EM UP KSU!!
L1011Lover
RE: Delta At DFW
Tue Oct 23, 2007 5:03 am
In 2001 until the 9/11 attacks Delta and Delta Connection served the following destinations nonstop from it's DFW hub:
ABQ, AEX, AMA, ATL, AUS, BTR, BHM, BOS, CHS, CVG, COS, CAE, DEN, ELP, XNA, FLL, GSO, IAH, HOU, JAN, JAX, ILE, LFT, LAS, LIT, LAX, SDF, LBB, MEM, MOB, MLU, MGM, BNA, MSY, LGA, JFK, OAK, OKC, ONT, SNA, MCO, PHX, PDX, RDU, RNO, SLC, SAT, SAN, SFO, SAV, SEA, SHV, TPA, TXK, TUS, TUL, DCA, PBI, ICT
If you'd be interested I could check one of my old timetables in order to find out if and what the events on 9/11 changed on destinations served from DFW. I can't remember when exactly DL started dismantling it's DFW hub and if some destinations were dropped right after 9/11 (and never resumed).
I remember that until some point in the mid 90's DL served HNL nonstop from DFW, also until the closure of the FRA hub in 1997 DL offered a daily DFW-FRA service.
Hope his helps...
Best regards
L1011Lover
AirlineBrat
RE: Delta At DFW
Tue Oct 23, 2007 5:33 am
I flew FAI-ANC-SEA-DFW-EWR and back on DL a couple of times back in the early 90's. Nothing like flying on DL from Alaska to the Northeast via the Deep South....... spitting distance from the Mexican border, relatively speaking. It was a good way to build up extra miles though. Texans never seemed like us long haired shaggily dressed individualistic Alaskans. I got quite a few stares at times when changing flights at DFW. The old DL terminal (E) at DFW looks pretty empty nowadays. Who uses it? DL for their handful of flights to SLC, ATL and CVG, AS, CO.... who else?
Is the small satellite terminal off of Terminal E still there? I was checking out DFW on Google Maps the other day and it is an old satellite image from when DL still had a hub at DFW. The Satellite terminal had a mix of DL mainline and Express aircraft parked at the gates. I saw a couple of DL L-1011's parked at the E Terminal as well.
I'm leavin on a jet plane. Don't know when I'll be back again....
FlyASAGuy2005
RE: Delta At DFW
Tue Oct 23, 2007 6:14 am
DFW was also a secondary hub for ASA right? I know they had a ton of flights out of DFW back in the day.
What gets measured gets done.
ScottB
RE: Delta At DFW
Tue Oct 23, 2007 6:28 am
Quoting L1011Lover (Reply 1):
Believe it or not, post-9/11 saw a significant expansion in destinations and flights on Delta from DFW; however, mainline departures declined significantly as CRJ's replaced (and in some cases augmented) mainline service. Fall 2003 saw non-stop service on Delta (with additions in italics) to:
ABQ, AEX, AMA, ATL, AUS, BTR, BHM, BOS, CHS, ORD, CVG, COS, CAE, GTR, CMH, CRP, DAB (3 weekly), DEN, DTW, ELP, FLL, VPS, GSO, GPT (5 weekly), HOU, IAH, HSV, IND, JAN, JAX, MCI, TYS, LFT, LAS, LEX, LIT, LAX, SDF, LBB, MLB (1 weekly), MEM, MSP, MOB, MLU, MGM, BNA, MSY, LGA, XNA, OAK, OKC, ONT, SNA, MCO, PFN (5 weekly), PNS, PHX, PDX, RDU, SLC, SAT, SAN, SFO, SAV, SEA, SHV, TLH, TPA, TUS, TUL, DCA, PBI, ICT.
Emblematic of the schedule change was DFW-AUS going from 4 mainline and 1 RJ to 8 RJ's, DFW-MSY from 3 mainline to 8 RJ's, and DFW-SNA going from 2 MD-90's to 2 CRJ-700's.
The handful of dropped routes included JFK, ILE, RNO, and TXK -- and the dropping of TXK & ILE were tied to the phase-out of ASA EMB-120 service at DFW. AFAIK, TXK was primarily kept due to the EMB-120 maintenance being done there, and runway length was an issue for RJ's at ILE. JFK returned in early 2004 and DFW-GUC was also added then. If memory serves, DFW-BPT was added in 2004 shortly before the decision was made in late summer 2004 to close the DFW hub effective January 2005.
The last few times I connected through DFW were positively eerie, as Delta had already started to gut unused gate areas and a once-busy hub (during peak times) had perhaps 15-20 departures, mostly on RJ's.
doug_or
RE: Delta At DFW
Tue Oct 23, 2007 6:48 am
Quoting FlyASAGuy2005 (Reply 3):
yep. Then they closed it and opened SLC. Then they closed that and opened LAX. Then they closed that too.
When in doubt, one B pump off
DFW13L
RE: Delta At DFW
Tue Oct 23, 2007 7:46 am
Quoting AirlineBrat (Reply 2):
It's unused and closed--jetbridges are removed, though most of that happened when ASA took over the terminal. No gates are in use. There's a gate blocking the way to the escalators that would take you down to the moving sidewalks to "Easy Street." On Sunday, Terminal E was used for the Minnesota Vikings, with their NWA 753 charter. (Or they might have been bussed, but the plane was parked at Term E gate 30). Many nights there will be a USAirways 737 parked out there. When AA exeriences an off schedule operation somewhere in the system, they will park a couple planes behind Terminal E, if they have too many unused planes stuck at DFW.
Remember when "Easy Street" opened? That was during the campaign..."Who's #1 at DFW? On Delta, You Are!" That was when they tried for 35% market share at DFW and never got there. They were also bussing planes from gate 4--not talking about Delta Connection, but normal sized 737s and 727s.
See, I knew American Eagle was first class all along!
syncmaster
RE: Delta At DFW
Tue Oct 23, 2007 12:07 pm
AirTran, Alaska, ATA, Continental, Delta, Frontier, Mesa, Midwest, Northwest and US.
-Charlie
ConcordeBoy
RE: Delta At DFW
Tue Oct 23, 2007 12:55 pm
they served it until shortly before the Tritanics were retired in the early '00s.
N702ML
RE: Delta At DFW
Tue Oct 23, 2007 1:14 pm
If it interests you, complete schedules for DFW Airport in 1979, 1983 and 1989 are available on www.departedflights.com
There are also complete Delta timetables for 1979 and 1983.
This may show you some of the various Delta operations out of DFW at different times.
The opinions expressed are my own and do not necessarily reflect those of Southwest Airlines.
SkyyMaster
RE: Delta At DFW
Tue Oct 23, 2007 7:40 pm
Quoting DFW13L (Reply 6):
Having lived in Dallas during the 80's and 90's, I saw the fortunes of Delta come and go at DFW. IIRC, at their peak, they flew in excess of 250 daily departures, PRE-regional jet days, all mainline. They had various EMB's and EM2's from ASA (or thinking further back, various a/c from Rio), but still a hefty number of mainline departures. I used the satellite numerous times for mainline. The original plan called for a second satellite at the opposite corner of 4E, but economics and the reality of the congestion it would cause with aanother aairline next door killed that idea.
N702ML
RE: Delta At DFW
Tue Oct 23, 2007 11:43 pm
Some random samplings (and remember...i am a flight attendant...so don't ctitisize my math if its wrong...lol)....
JUNE 1984
From Dallas/Fort Worth to:
Albuquerque (3x)
Amarillo (3x)
Atlanta (10x)
Austin (6x)
Baltimore (2x)
Baton Rouge (3x)
Birmingam (1x)
Boston (2x)
Chicago O'Hare (4x)
Cincinnati (1x)
College Station (7x via Rio Airways)
Denver (5x)
El Paso (3x)
Fort Lauderdale (1x)
Frankfurt (4x weekly)
Houston Hobby (3x)
Houston Intercontinental (6x)
Jackson (3x)
Jacksonville (2x)
Kansas City (4x)
Killeen (4x via Rio Airways)
Las Vegas (3x)
Little Rock (4x)
Los Angeles (5x)
Lubbock (4x)
Memphis (2x)
Monroe (1x)
Nashville (3x)
New Orleans (6x)
New York LaGuardia (4x)
Newark (2x)
Oklahoma City (6x)
Ontario (3x)
Orlando (2x)
Philadelphia (3x)
Phoenix (3x)
Portland OR (1x)
Salt Lake City (1x)
San Angelo (7x via Rio Airways)
San Antonio (5x)
San Diego (3x)
San Francisco (4x)
Seattle/Tacoma (2x)
Shreveport (6x)
Tampa (2x)
Temple (5x via Rio Airways)
Texarkana (5x via Rio Airways)
Tulsa (3x)
Waco (7x via Rio Airways)
Wichita Falls (8x via Rio Airways)
TOTAL DESTINATIONS: 50
TOTAL FLIGHTS: 186
JUNE 1, 1985
Albuquerque (5x)
Amarillo (4x)
Atlanta (10x)
Austin (8x)
Baltimore (2x)
Batron Rouge (5x)
Birmingham (1x)
Boston (3x)
Bryan/College Station (7x via Rio Airways)
Chicago O'Hare (5x)
Cincinnati (2x)
Denver (5x)
Detroit (3x)
El Paso (5x)
Frankfurt (1x)
Honolulu (1x)
Houston Hobby (5x)
Houston Intercontinental (7x)
Jackson (4x)
Jacksonville (2x)
Kansas City (5x)
Las Vegas (3x)
Lawton (7x via Rio Airways)
Little Rock (4x)
Los Angeles (5x)
Louisville (2x)
Lubbock (4x)
Memphis (4x)
Monroe (1x)
Nashville (3x)
New Orleans (6x)
Newark (3x)
Oklahoma City (7x)
Ontario (3x)
Orlando (3x)
Philadelphia (3x)
Phoenix (4x)
Raleigh/Durham (2x)
Salt Lake City (1x)
San Angelo (9x via Rio Airways)
San Diego (2x)
San Francisco (5x)
Seattle/Tacoma (2x)
Shreveport (7x)
Tampa (3x)
Temple (4x via Rio Airways)
Tulsa (6x)
Waco (9x via Rio Airways)
West Palm Beach (1x)
TOTAL DESTINATIONS: 54
TOTAL FLIGHTS: 225
JULY 15, 1986
Albuquerque (5x)
Amarillo (3x)
Atlanta (10x)
Austin (7x)
Baltimore (2x)
Baton Rouge (5x)
Birmingham (1x)
Boston (3x)
Bryan/College Station (4x via Rio Airways)
Chicago O'Hare (5x)
Cincinnati (2x)
Denver (6x)
Detroit (2x)
El Paso (5x)
Fort Lauderdale (2x)
Frankfurt (5x weekly)
Honolulu (1x)
Houston Hobby (4x)
Houston Intercontinental (5x)
Jackson (4x)
Jacksonville (1x)
Kansas City (4x)
Killeen (8x via Rio Airways)
Las Vegas (3x)
Little Rock (4x)
Los Angeles (5x)
Louisville (2x)
Lubbock (4x)
Memphis (4x)
Monroe (1x)
Nashville (3x)
New Orleans (6x)
Newark (2x)
Oklahoma City (5x)
Ontario (3x)
Orlando (3x)
Philadelphia (3x)
Phoenix (5x)
Portland, OR (1x)
Raleigh/Durham (2x)
Salt Lake City (2x)
San Angelo (5x via Rio Airways)
San Antonio (7x)
San Diego (3x)
San Francisco (5x)
Seattle/Tacoma (2x)
Shreveport (7x)
Tampa (3x)
Tulsa (5x)
Waco (6x via Rio Airways)
Washington Dulles (3x)
Wichita Falls (6x via Rio Airways)
TOTAL DESTINATIONS: 156
TOTAL FLIGHTS: 214
JULY 1, 1987
Abilene (8x via ASA)
Albuquerque (5x)
Amarillo (4x)
Atlanta (11x)
Austin (8x)
Baton Rouge (5x)
Beaumont (5x via ASA)
Birmingham (1x)
Boston (3x)
Chicago O'Hare (4x)
Cincinnati (4x)
Denver (5x)
Detroit (3x)
El Paso (5x)
Fort Smith (4x via ASA)
Frankfurt (6x weekly)
Honolulu (1x)
Houston Hobby (5x)
Jackson (4x)
Jacksonville (1x)
Kansas City (5x)
Killeen (7x via ASA)
Las Vegas (4x)
Lawton (8x via ASA)
Little Rock (5x)
Long Beach (2x)
Los Angeles (5x)
Louisville (3x)
Lubbock (4x)
Memphis (5x)
Midland (5x via ASA)
Monroe (1x)
Nashville (4x)
New Orleans (6x)
New York LaGuardia (5x)
Newark (2x)
Oklahoma City (7x)
Ontario (3x)
Orlando (4x)
Philadelphia (3x)
Phoenix (5x)
Portland OR (1x)
Raleigh/Durham (2x)
Salt Lake City (6x)
San Angelo (7x via ASA)
San Antonio (9x)
San Diego (4x)
San Francisco (5x)
Seattle/Tacoma (2x)
Sheveport (7x)
Tampa (4x)
Texarkana (4x via ASA)
Tulsa (7x)
Tyler (6x via ASA)
Washington Dulles (2x)
Washington National (4x)
Wichita Falls (8x via ASA)
TOTAL DESTINATIONS: 60
DESTINATIONS SERVED: 262
APRIL 3, 1988
Abilene (7x via ASA)
Albuqeurque (5x)
Alexandria (3x via ASA)
Amarillo (4x)
Atlanta (10x)
Austin (7x)
Baltimore (2x)
Baton Rouge (5x)
Beaumont (4x via ASA)
Birmingham (1x)
Boston (3x)
Chicago O'Hare (5x)
Cincinnati (4x)
College Station (7x)
Denver (5x)
Detroit (3x)
El Paso (5x)
Fayetteville AR (2x via ASA)
Fort Smith (4x)
Houston Hobby (5x)
Jackson (4x)
Kansas City (5x)
Killeen (8x via ASA)
Lafayette LA (3x via ASA)
Las Vegas (4x)
Lawton (9x via ASA)
Little Rock (5x)
Long Beach (2x)
Longview (6x via ASA)
Louisville (3x)
Lubbock (4x)
Memphis (5x)
Monroe (1x)
Nashville (4x)
New Orleans (6x)
Newark (2x)
Oklahoma City (8x)
Ontario (3x)
Orange County (2x)
Orlando (4x)
Philadelphia (3x)
Phoenix (5x)
Portland OR (1x)
Raleigh/Durham (2x)
Salt Lake City (5x)
San Antonio (9x)
San Diego (4x)
San Francisco (5x)
Seattle/Tacoma (2X)
Shrevrport (7x)
Tampa (4x)
Tulsa (6x)
Tyler (7x via ASA)
Waco (7x via ASA)
TOTAL DESTINATIONS: 62
TOTAL FLIGHTS: 275
JUNE 1, 1989
Acapulco (1x)
Albuquerque (5x)
Amarillo (4x)
Atlanta (12X)
Austin (7x)
Baltimore (2x)
Baton Rouge (6x)
Beaumont (5x)
Birmingham (1x)
Boston (2x)
Chicago O'Hare (5x)
Cincinnati (4x)
College Station (6x via ASA)
Colorado Springs (2x)
Denver (5x)
Detroit (2x)
El Paso (5x)
Fayetteville AR (3x via ASA)
Frankfurt (1x)
Houston Hobby (6x)
Huntsville (1x)
Indianapolis (2x)
Jackson (4x)
Jacksonville (1x)
Kansas City (5x)
Knoxville (2x)
Las Vegas (4x)
Lawton (9x via ASA)
Little Rock (5x)
Long Beach (2x)
Longview (5x via ASA)
Los Angeles (5x)
Louisville (3x)
Lubbock (4x)
Memphis (5x)
Mexico City (2x)
Miami (3x)
Monroe (1x)
Nashville (4x)
New Orleans (6x)
Newark (2x)
Oklahoma City (8x)
Ontario (3x)
Orange County (2x)
Orlando (3x)
Philadelphia (3x)
Phoenix (5x)
Portland OR (1x)
Raleigh/Durham (2x)
Sacramento (3x)
Salt Lake City (5x)
San Angelo (6x via ASA)
San Antonio (9x)
San Diego (4x)
San Francisco (5x)
Seattle/Tacoma (3x)
Shreveport (6x)
Tampa (4x)
Tucson (3x)
Tulsa (6x)
Tyler (7x via ASA)
Waco (5x via ASA)
Wichita (4x)
TOTAL DESTINTIONS: 75
TOTAL FLIGHTS: 311
(3 additional nonstops to San Jose, CA flights were effective August 1, 1989)
[Edited 2007-10-23 16:44:50]
[Edited 2007-10-23 16:44:57]
[Edited 2007-10-23 16:45:02]
[Edited 2007-10-23 16:53:49]
[Edited 2007-10-23 16:58:47]
N702ML
RE: Delta At DFW
Wed Oct 24, 2007 12:38 am
JULY 1, 1990
Abilene (6x)
Acapulco (1x)
Albuquerque (5x)
Alexandria (4x via ASA)
Amarillo (4x)
Atlanta (11x)
Austin (9x)
Baltimore (2x)
Baton Rouge (6x)
Birmingham (1x)
Boston (3x)
Chicago O'Hare (5x)
Cincinnati (4x)
College Station (7x via ASA)
Corpus Christi (3x)
Denver (5x)
El Paso (5x)
Fayetteville AR (5x via ASA)
Fort Laudedale (3x)
Fort Smith (5x via ASA)
Frankfurt (1x)
Houston Hobby (6x)
Huntsville (1x)
Jackson (4x)
Jacksonville (1x)
Kansas City (5x)
Killeen (6x via ASA)
Knoxville (2x)
Las Vegas (4x)
Lawton (9x via ASA)
Little Rock (5x)
Long Beach (2x)
Longview (4x)
Los Angeles (5x)
Louisville (3x)
Lubbock (4x)
Memphis (5x)
Mexico City (2x)
Miami (3x)
Mobile (1x)
Monroe (1x)
Nashville (4x)
New Orleans (6x)
Newark (3x)
Oakland (2x)
Oklahoma City (8x)
Ontario (3x)
Orange County (2x)
Orlando (4x)
Pensacola (2x)
Philadelphia (3x)
Phoenix (5x)
Portland OR (2x)
Raleigh/Durham (2x)
Sacramento (3x)
Salt Lake City (5x)
San Angelo (5x via ASA)
San Antonio (9x)
San Diego (5x)
San Francisco (5x)
San Jose (3x)
Seattle/Tacoma (3x)
Shreveport (6x)
Tampa (5x)
Texarkana (5x via ASA)
Tucson (4x)
Tulsa (6x)
Tyler (7x via ASA)
Waco (5x via ASA)
Wichita (3x)
TOTAL DESTINATIONS: 78
TOTAL FLIGHTS: 337
elmothehobo
RE: Delta At DFW
Wed Oct 24, 2007 12:48 am
Quoting Super80DFW (Thread starter):
Yes. American's biggest competitor in the Dallas/Ft. Worth market disappeared, and American added nearly 100 flights to compensate. American's expansion in the Southeast wouldn't have been possible without Delta's pullout. Most of the markets American has added since 2005 in the Southeast from DFW were Delta Connection markets.
SLCUT2777
RE: Delta At DFW
Wed Oct 24, 2007 12:59 am
Quoting ElmoTheHobo (Reply 13):
Once the last vestiges of the Wright Amendment go into effect, WN will be AA's biggest competitor, albeit from a different airport; DAL.
DELTA Air Lines; The Only Way To Fly from Salt Lake City; Let the Western Heritage always be with Delta!
Super80DFW
RE: Delta At DFW
Wed Oct 24, 2007 3:48 am
Since July 1, 1990, DL has still managed to keep 11 n/s flights to ATL daily (8 on 757's). I like seeing an occasional DL 757 instead of AA 757's flying over on approach every once in a while. How many gates does DL still have at DFW?
airstatdfw
RE: Delta At DFW
Wed Oct 24, 2007 9:02 am
Quoting Super80DFW (Reply 15):
They have 4 gates left in Term E.
They RON 3 757's right now, quite different seeing 3 757 on the Term E ramp.
N839MH
RE: Delta At DFW
Wed Oct 24, 2007 4:04 pm
Starting in December and thru January...no more scheduled B757's into DFW. Hopefully next spring DL will
be bringing back the B757's. DL will be flying a B767-300 in for the Jets charter at Thanksgiving...those are
always nice to see in DFW.
Solodude!
william
RE: Delta At DFW
Wed Oct 24, 2007 5:35 pm
Yes I have found memories of flying one of the original Delta Connection carrier RIO Airways with its visual yellow aircraft. I have flown the BE1900 and Dash 7 aircraft from Killeen to DFW many times. At the new Killeen airport (GRK) they have mini museum dedicated to Rio Airways.
Does anyone remember the traffic jams at DFW in the late 80s when every DL and AA gate emptied out for the 5-6pm afternoon rush?
