AF022
The 787 And Heathrow Noise Limits
Tue Oct 23, 2007 1:44 am
Is the 787 a quieter aircraft than the 767 or other widebodies, and if so will it allow more airlines to operate during the night curfew at LHR because more arriving flights will have the same noise level as fewer noisy aircraft?
Stitch
RE: The 787 And Heathrow Noise Limits
Tue Oct 23, 2007 1:59 am
Quoting AF022 (Thread starter):
The 787 will meet the most stringent noise standards, but even a "quiet" plane is still a nuisance at night, so the curfew likely will remain in force.
scbriml
Tue Oct 23, 2007 8:56 am
The LHR curfew is a complete one. It currently doesn't matter how quiet a plane is, the curfew still applies.
The only exceptions to the curfew are a limited number of late arrivals/departures caused by operational delays, and there is a strict allocation of those per airline. Emergency diversions would be the only other category of curfew buster that I am aware of.
Geo772
Tue Oct 23, 2007 9:24 am
The 787 will be quite a bit quieter than otherwidebodies, and in fact many narrow bodies operating out of LHR. The noise curfew as has been said is for all arcraft movements (with the exception of emergencies). The airport effectively closes down at night although a runway is still kept available forr the unexpected.
Airlines have a quota of noise that they have to meet, how they use it is up to them. If they want to operate a 744 rated at QC2 they will use up 4 times more of their allocation than if they used an A380 at QC0.5. While this is not so important for operators who visit LHR, those airlines that are based there need to plan their fleets accordingly. Virgin and BA have got quieter aircraft on order for their longhaul fleet renewal which will give them a bit more flexibility in their operations.
Flown on A300B4/600,A319/20/21,A332/3,A343,B727,B732/3/4/5/6/7/8,B741/2/4,B752/3,B762/3,B772/3,DC10,L1011-200,VC10,MD80,
SEPilot
Tue Oct 23, 2007 1:06 pm
Just out of curiosity, how does the 748 compare in noise emissions to the A380?
scbriml
Tue Oct 23, 2007 1:21 pm
Quoting SEPilot (Reply 4):
I can't remember the exact figures, but they were quoted in a recent thread about the 748i. If the search function is working you might be able to find it.
The A380 is quieter than the 748 - bigger engines and a significantly bigger wing help in that respect. I believe approach speed for the A380 is slower as well.
sh0rtybr0wn
Tue Oct 23, 2007 1:35 pm
Quoting Scbriml (Reply 5):
748 GEnx will be quieter than engines on the A380. Newer technology, you know. Much less noise signature.
RayChuang
Tue Oct 23, 2007 1:55 pm
If I remember correctly, the 787 will be one of the quietest planes around because the engine nacelles use a "sawtooth" chevron exhaust nozzle, which dramatically reduces the noise level in addition to using engines with slower-turning front fans that generate much less noise to start with. As such, the plane easily meets the UK Civil Aviation Authority Quota Count 2 standard for noise emissions.
moo
Tue Oct 23, 2007 2:06 pm
Quoting Sh0rtybr0wn (Reply 6):
Not necessarily - the 747-8 GEnx variant features a smaller fan diameter than either the GEnx on the 787 or either engine type on the A380 and its this larger fan size that acts as the main noise reducer.
teme82
Tue Oct 23, 2007 2:09 pm
That will remain to be seen. Since 748 is still in the drawing board we just have to wait and see. And I bet that RR and EA will continue to improve their engines too. So it will be interesting to see how things goes  Wink
Flying high and low
AF022
Tue Oct 23, 2007 2:12 pm
Quoting RayChuang (Reply 7):
Will this give any benefit for airlines looking for more landing slots at LHR? I mean if NH wants more NRT-LHR flights will BAA look kindlier upon them because of their quieter aircraft? Maybe open a very early slot?
zak
Tue Oct 23, 2007 2:37 pm
certainly interesting claim, i will go ahead and say, unlikely, the a380 monsterwing gives it too much of an advantage in vref
10=2
Stitch
Tue Oct 23, 2007 2:48 pm
The 747-8 will meet the noise requirements for QC 2 classification on both Arrivals and Departures, and also has a significant chance of achieving the next lower classification level (QC 1) for Arrival.
The A380 was expected to be QC 1 on Arrival, but has subsequently proved to be QC 0.5. I cannot find any info on her Departure QC, but it can be no more then QC 2, which is likely what it is.
cloudyapple
Tue Oct 23, 2007 3:35 pm
Quoting Scbriml (Reply 2):
Straight answer is no, the arrival of the B787 won't increase night flights.
The curfew is not a blanket ban. A number of flights per scheduling season are allowed to operate in the curfew hours. There are 2 limits to these - the QC quota and an absolute cap in the number of movements. When either is used up, no more night flights for the rest of the season.
The entire allowance is currently used up by/allocated to the early heavy arrivals from Asia and America from 0430-0600. There is nothing to be spared for any potential late night/early morning B787 flights. It is the movement limits being used up with some spare quota on the QC limit.
The current limits are as follows:
http://www.richmond.gov.uk/home/envi...or_night_flights_at_heathrow-5.htm
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
lightsaber
Crew
Wed Oct 24, 2007 12:52 am
787 compared to the 767 on noise (warning, pdf):
www.futureheathrow.org/PressReleases/150507/FH_on_Noise_May_2007.pdf
The plane maker says its new 787 ‘Dreamliner’ will have a noise footprint around Heathrow 60 per cent smaller than previous comparable aircraft such as the 767-300,whilst its re-modeled 747-8 will deliver a 30 per cent reduction in noise compared to earlier 747 models.
For this discussion, please look at this pdf slide 19 and 20
www.aiaa.org/events/aners/Presentations/ANERS-Hawk.pdf
789 designed to be 60% quieter than the A343 (the aircraft it will send to the scrapyard):
www.v-flyer.com/pages.asp?click=196&pageid=196
As others have noted, fan diameter matters more than technological generation. I expect the GP7200 to be quieter than the 105" diameter GEnX. That said, I expect the 112" GEnX or the 111" Trent 1000 to be the quietest engine in the sky.
For comparison:
Trent 900: 116" diameter
GP7200: 116" diameter
Based on the LHR noise points, the Trent is *just* enough quieter than the GP7200 on takeoff. Both are in the same noise class for landing. How? A shrouded turbine tends to make a little less noise than an un-shrouded. The difference is usually not worth talking about... It might also be due to the changes RR made to the nacelle (but I'm speculating. Informed speculation, but be aware I am not informed of enough details to speak with any authority).
Photo © Dmitriy Pichugin - Russian AviaPhoto Team
Photo © Dn280
http://en.wikipedia.org/wiki/Compari...ent_900_and_Engine_Alliance_GP7000
Lightsaber
aerokiwi
Wed Oct 24, 2007 2:25 am
Quoting Lightsaber (Reply 14):
For comparison:
Does that mean that the GE90 is the quietest engine in the sky and the 777 the quietest aircraft? Or is the wing-engine combo what makes the A380 so quiet?
Wed Oct 24, 2007 3:11 am
In my view, that is basically based on false Boeing PR, until measurements are made, and noise certificate issued, take everything with a grain of salt.
Too many variables need to be sorted out with regard to configurations and speeds for the aircraft during flight testing.
Boeing have embellished things a little there, the 787 is not that special on the noise front, the data they have presented with regard to the comparison aircraft is false. Please note that presentation is about the 788 not 789.
From real EASA TCDS noise certificate data http://www.easa.europa.eu/doc/Certif...e/odoc/TCDSN%20Jets%20(070831).xls
http://i15.photobucket.com/albums/a357/thezeke/noise/flyovernoise.png
http://i15.photobucket.com/albums/a357/thezeke/noise/lateralnoise.png
http://i15.photobucket.com/albums/a357/thezeke/noise/approachnoise.png
Personally, I don't believe for a second the approach noise levels listed for the 788 in that document, it will be closer to the A380.
www.v-flyer.com/pages.asp?click=196&...d=196
I have not anything to suggest the VS A340s will be going to the scrapyard.
Secondly, the article does not claim the 789 is "60% quieter" than a A340, the article says "noise footprint of the 787-9 is also 60% lower than the A340-300", noise footprint refers to the amount of area covered by the 85 EPNdB contour, not 60% reduced noise produced by the engine.
I dont believe the numbers in the article, because the noise levels from the 789 will be higher than the 788 (more thrust/weight), and the 788 does not exhibit a 60% reduction over the A340.
Quoting Aerokiwi (Reply 15):
No, the GE90 and 777 are far from the quietest aircraft about, and yes, the powerplant and engine combination are important. A higher gross weight 744 will have a higher noise signature than a lighter 744, even if they have the same engines.
The quietest aircraft in the EASA database are as follows :
Lateral : Bombardier CL-600-2B19 with General Electric CF34-3A1 engines : 82.1 EPNdB
Flyover : Cessna 560 Citation Encore with Pratt & Whitney Canada PW 535A engines : 70.0 EPNdB
Approach : Cessna S550twith Pratt & Whitney JT15D-4B engines : 85.1 EPNdB
theginge
Wed Oct 24, 2007 6:54 am
Quoting AF022 (Reply 10):
The slots from early morning onwards are full so it doesn;t make a difference if an aircraft is quieter as you won't get it in anyway.
