stealth777
A380 And The Triple Jetways
Sat Oct 27, 2007 5:42 pm
Just wondering how many of the A380 airports have the triple jetways installed for the aircraft. SFO has one set installed currently and should have a total of 4 installed, 2 on the G side and 2 on the A side. Here is a picture I took when the aircraft was doing its ground testing at SFO (sorry about the poor non-airliners.net quality, sun was not in the ideal position for me). I may be wrong in this but I believe SFO is currently the only airport in the US with the triple jetway system.
-stealth
p.s. Let me know what you think of the picture. Thanks.
[Edited 2007-10-27 10:58:18]
PC12Fan
RE: A380 And The Triple Jetways
Sat Oct 27, 2007 6:16 pm
I'm not sure of other airports, but here is another configuration.
http://www.tkaps.com/nextgenerationpic.htm
Just when I think you've said the stupidest thing ever, you keep talkin'!
mestrugo
Sat Oct 27, 2007 8:02 pm
Let's just hope that the airport authorities have at least the common sense to make a line for every jetway instead of making a HUGE line and then sort people depending on their seat. It may sound silly, but I see it coming. :b
FlySSC
Sat Oct 27, 2007 8:23 pm
CDG has 6 parking stands designed for the A380 with a triple jetways at the brand new satellite S3, opened last June.
speedbird2263
Sat Oct 27, 2007 9:48 pm
Quoting PC12Fan (Reply 1):
I find the first schematic interesting, Im not quite sure if that set up would be more efficient than the current M1,M2 & U2 arrangement though, it may very well offer the same level of efficiency for a somewhat more expensive design. If I remember correctly, JXB has planned to install at least triple Jet-bridges at all its A380 gates.
With the seemingly "unlimited" cash flow it'd would be nice to see them incorporate the quad-Jet bridge design. I saw it in an airport planning document relating to the A380, its basically the current triple design being used incorporating an over-wing bridge as well as in the schematic shown by PC12Fan .
[Edited 2007-10-27 14:49:59]
Straight'n Up 'N Fly Right Son
flyboeingjets
Sat Oct 27, 2007 10:21 pm
Nice picture. I don't think any airports right now besides SFO in the US have triples. Only in the past few years have we even seen the return of duals at some of the newer US airport terminals.
Some of the old JFK IAB gates had triples, but the thing is, I don't think I ever saw a picture where all three jetways were being utilized. It was always just one or two in use. On a 747, it would have been the L1 L2 & L4 doors....L4 being accessed by an OTW bridge much like what AMS has.
7e72004
Sat Oct 27, 2007 10:24 pm
That is a good picture. I used to think it was something to see two jetways used. On a side note, they should make Airplane III using the A380  Big grin
The next generation of aircraft is just around the corner!
Nice photo but it would be nice if the jetways were glass like in TLS . Those really are nice bridges.
7e72004
Sat Oct 27, 2007 10:40 pm
Do the A380s have to have specialized baggage claim areas built? I cannot imagine standing in a "normal" claim in LAX or JFK, etc. with all of those people.
ikramerica
Sat Oct 27, 2007 10:52 pm
Quad would be ridiculous. Triple is overkill already. But 2 jetways are perfectly fine if they are designed so the second lifts higher and goes to the upper deck on the A380, or lowers to be the "2 door" jetway for single decker planes.
Certain airlines/airports will of course use the 3rd to segregate pax into a "premium boarding area" where they need not mingle with the rif-raf in Y.
But considering it doesn't take that long to board a 450 seat QF 743 from ONE jetway (since it has a wide door and two aisles, and boarding at 2L means many pax turn L), the need for 3 jetways for an A380 with 475 seats is greatly exaggerated, and I think over time you'll see airports install only 2 to save money, with the 2nd being of the type that can raise to the upper deck. Boarding will be via L2L and U1L.
Leezyjet
Sat Oct 27, 2007 10:57 pm
That photo in the link is of the jetbridges on stand 342 at LHR T3 !!. I remember just after they came into service, I raised the one nearest the camera up as high as it would go. It was amusing seeing the look on the 747 Capt's face as he taxied onto stand and I was at the same height he was !!. They were so used to looking down onto the jetbridges that it had taken him by surprise !!.
All the A380 gates at LHR have the standard 2 jet bridges.
 Smile
"She Rolls, 45 knots, 90, 135, nose comes up to 20 degrees, she's airborne - She flies, Concorde Flies"
flexo
Sat Oct 27, 2007 11:01 pm
Quoting Ikramerica (Reply 9):
I think that is exactly what happened in the scenario pictured by the OP. The first jetbridge seems to serve that "premium passenger" purpose. For fast turnarounds jetbridges 101C and 101A are way too close together.
ikramerica
Sat Oct 27, 2007 11:41 pm
Quoting Flexo (Reply 11):
I think it's planned in the new DXB airport that there will be a whole terminal floor devoted to the premium pax. Basically a giant lounge or set of lounges. The premium jetway would be attached to this floor directly, with the other two jetways attached to the main "rif raf" floor.
But for practical purposes, it's just not necassary to have 3. 2 is plenty. Many airports board 777s and A330/340s with 1 jetway. So if you think of the main deck of the A380 as 77W and the upper as an A340-200, 2 jetways should be plenty, right?
caspritz78
Sun Oct 28, 2007 12:11 am
Don't forget if the jetbridges' layout is somehow smart that you can handle at least tow 737, 320 or similar at the gate. Remember that from CDG where two AF 737 used the same gate. Left jetbridge was to DUS (if I remember right) and right bridge was to FRA.
RayChuang
Sun Oct 28, 2007 1:19 am
I believe that SFO will probably get a second triple jetbridge gate (most likely on the Concourse G side) some time in 2008. They only need one for now given that it will service the Singapore Airlines A380's once they starting using the plane on the SQ 001/002 route (SIN to SFO via HKG).
legacyins
Sun Oct 28, 2007 1:30 am
Quoting Stealth777 (Thread starter):
Thanks for the picture. Gives a great perspective.
joffie
Sun Oct 28, 2007 2:11 am
I thought there was a picture at Sydney with tripple jetways. Is in the database somewhere.
LTU932
Sun Oct 28, 2007 5:09 am
What about overwing jetways at e.g. AMS? Could those be used for deboarding of A380s, if they were to come to AMS on a regular basis? Or can AMS's jetways only be used for 747s?
HSV
Sun Oct 28, 2007 5:23 am
Quoting Mestrugo (Reply 2):
In Singapore for the first commercial flight there was only 1 queue... and then there was a sign where the jetways split to indicate whether that particular jetway led to the main deck or the upper deck.
Quoting 7E72004 (Reply 8):
On arrival into Sydney, bags for Suites, Business and priority passengers came out on carousel 4 while the bags for everyone else came out on carousel 3. So basically, nothing special has been built for the A380... they just use 2 carousels instead.
WingedMigrator
Sun Oct 28, 2007 5:30 am
Cool pic.
Quoting Speedbird2263 (Reply 4):
The schematics are also interesting because they show the older configuration of the A380, when it was still supposed to have a door at the front of the upper deck. That door was deleted from the A388 to save weight, but will be featured on the A389 (if built).
laca773
Sun Oct 28, 2007 7:20 am
Great photo, Stealth777. Will you be placing it in the data base here on A.net?
Does anyone know if the 388 gates @ LAX will be dual bridges or will they do it with three? It was hard for me to tell when I flew in last week from ORD as I just saw the steel frame.
LACA773
speedbird2263
Sun Oct 28, 2007 8:03 am
Quoting WingedMigrator (Reply 19):
Good observation Wink It certainly didnt click to me that the schematic was showing more doors on the Upperdeck than there should be. I agree that that door would most definately be added on the A389 if and when its built. Although Ikramerica pointed out earlier that a quad jet-way system would be rather unnecessary, I'll admit that it would be quite something to see in operation, if i recall from the planning document I had read sometime ago, the configuration would most likely be M1L, M4L, U1L and U3L.
GBan
Sun Oct 28, 2007 8:20 am
Quoting HSV (Reply 18):
Now that's a boring solution, isn't it?  Wink
ikramerica
Sun Oct 28, 2007 8:24 am
Quoting GBan (Reply 22):
They do the same at LAX for the 744s. At least in my experience.
Of course my bag didn't come out at all. They told me after I waited the whole time that it was on a different flight...
gigneil
Sun Oct 28, 2007 11:35 am
Quoting Ikramerica (Reply 12):
That is really only supportable if all premium seats are located on the second floor. Otherwise, boarding the upstairs Business section is done most efficiently from door 1 and up the staircase.
NS
BA0284
Sun Oct 28, 2007 1:55 pm
Out of interest, which gates on the A side at SFO will have the triple airbridge configuration? If BA use the A380 to SFO, the BA terraces lounge is currently situated between gates A4 and A6, and currently has the ability to board through the lounge to the air bridges on these gates (for Club World, First, Silver Member etc). If the triple air bridge wont be at either of these gates, and BA decides to use the 380 to SFO, then they wont be able to board through the lounge....? It'll be interesting to see where they place them!
anyway, my main question is which gates on the A side at SFO will have the triple airbridge? Does anyone know yet?
BA0284
RayChuang
Sun Oct 28, 2007 2:42 pm
BA0284,
I think only the gates at the very end of Concourse A at SFO will get the triple jet bridges, because they were designed with the 80 x 80 meter parking space in mind. BA could ask to move their lounge to near these gates, if they're willing to pay SFO for the construction and moving costs.
ikramerica
Sun Oct 28, 2007 6:07 pm
Quoting Gigneil (Reply 24):
Actually, we are talking about jetway "A" here, the one that attaches to door 1L. This door has access to the grand staircase which brings you up to business cabin as well as direct access to F (and more J if they put it on the main deck behind F as well).
For anyone who can't climb the stairs due to health, I would assume they plan on an elevator/lift that would connect the upper lounge with the lower boarding area, or a ramp in the jetway support structure that goes to the other two jetways (for VIPs that just happen to be in Y, for ground staff to navigate, etc.)
stealth777
Sun Oct 28, 2007 8:16 pm
Quoting BA0284 (Reply 25):
From what I have heard it would be at the very end, identical to the layout on the G side. When I go back to work next week I'll check and see how the boarding area is set up at G101, but I believe there is nothing different inside the terminal. So the 1st class would be in line with the business whom would be in line with the Y class passengers. The only difference I have seen in SFO is door 1 from the terminal is for 1st and Business and door 2 is for the Y-cabin. Once all the premium pax are on board (or the majority of them) the airlines then use both doors for boarding to speed up the process.
-Stealth
