fxramper
AA MD80 Blown Engine At STL. (pics)
Wed Oct 31, 2007 2:27 am
To continue American MD-80 Lands At STL With Engine Fire (by KPDX Sep 28 2007 in Civil Aviation)
DC9 taking off from STL. The pilot did a go around with multiple warning lights on one engine. FAA is really steaming about this one.
Any more news?
(removed pic)
[Edited 2007-10-30 19:37:05]
EMBQA
RE: AA MD80 Blown Engine At STL. (pics)
Wed Oct 31, 2007 2:29 am
The top photo is Fake.......!!! The rest are real
Photo © Tim Lane
Quoting FXramper (Thread starter):
Steaming...??? Why...??? The engine failed on climb out. What else is he going to do...???
[Edited 2007-10-30 19:36:51]
boeingfever777
Wed Oct 31, 2007 2:34 am
Fxramper... Jimbo send you those?
Nothing alittle Turtle Wax can't fix!
Faire du ciel le plus bel endroit de la terre.
fxramper
Quoting EMBQA (Reply 1):
Didn't see that photo in database, but I'm hearing a lot from AA guys that the FAA is hot about this particular incident.
Comments?
sh0rtybr0wn
Wed Oct 31, 2007 2:46 am
It might sound funny, but I'm happy to see a plane with that much damage that can still land safely. It gives me more confidence in all the planes I fly on.
And also, I'm glad that pilots can stay cool and take care of business with crazy warning lights and alarms going off when they lose an engine at a crucial time.
The FAA should give them a medal.
BreninTW
Wed Oct 31, 2007 2:52 am
Did the pilot do a go-around (i.e., continue take-off, turn around, approach for a landing, then reject the landing and attempt again) with the warning lights, or did the pilot continue a take-off, turn around and come in to land?
if it was the former, I can understand why the FAA would be "steamed" ... if the latter, then I do believe that the pilot's actions were the correct ones*.
*I'm not in the aviation field, so don't know the finer points of things like this. Just trying to get things clear in my mind.
Bren
BreninTW
Wed Oct 31, 2007 2:59 am
NTSB Preliminary report makes for interesting reading ... available at http://www.ntsb.gov/ntsb/GenPDF.asp?id=CHI07MA310&rpt=p
Basically the NTSB is noting that the nosegear failed to extend when the landing was attempted. NTSB Prelim. report doesn't explicitly state that a missed approach was, or was not, executed -- wording is ambiguous.
fxramper
Wed Oct 31, 2007 3:01 am
Quoting BoeingFever777 (Reply 2):
He's your uncle too dude. Yes.
Quoting Sh0rtybr0wn (Reply 4):
I agree.
Quoting Brenintw (Reply 5):
There were multiple warning lights on, not just engine.
 redflag
BreninTW
Wed Oct 31, 2007 3:06 am
Quoting FXramper (Reply 7):
I dirrent say dat!  Smile I only asked questions.
EMBQA
Wed Oct 31, 2007 3:15 am
So what.....??? That is going to happen when you have a failure like they did.
sideflare75
Wed Oct 31, 2007 3:21 am
OK I'll bite. What makes the top one fake? Sure looks like the same plane to me.
And why would the FAA be steaming? Sounds like the crew did an extraordinary job dealing with first an engine fire and then a gear problem.
fxramper
Wed Oct 31, 2007 3:38 am
Quoting Sideflare75 (Reply 10):
According to my source, the pilots lied about the situation - warning lights on during their emergency landing.
EMBQA
Wed Oct 31, 2007 3:42 am
He deleted it. It was a photo shopped picture of the same pic I have above.... but with flames added. (Note his edit conmment)
Quoting FXramper (Reply 11):
Lied about what...? I'm sure that cockpit was lite up like a Christmas tree.
[Edited 2007-10-30 20:45:13]
KFLLCFII
Wed Oct 31, 2007 3:45 am
Would anyone have expected anything else?
And if you have to do a go-around, you have to do a go-around...one engine or two.
Of course, you try not to have to do a go-around if you're down an engine...but it can't always be avoided.
"About the only way to look at it, just a pity you are not POTUS KFLLCFII, seems as if we would all be better off."
474218
Wed Oct 31, 2007 3:46 am
I can think of at least four (4) other systems that should have had lights on, other than the engine.
fxramper
Wed Oct 31, 2007 4:24 am
Quoting EMBQA (Reply 12):
they stated, just immediate engine failure - which would include no less than four lights. There were a lot more than four lights blazing.
The whole things is screwy. I read the only thread, not much more stated so far...
nema
Wed Oct 31, 2007 7:09 am
Amazing pics of this damage.. Looks to me like all of the blast went downwards. I hate to think what might have been the outcome if it was more towards the fuselage or directly upwards towards the tail. Thankfully, this was not the case but makes you think...
There isnt really a dark side to the moon, as a matter of fact its all dark!
N766UA
Wed Oct 31, 2007 4:28 pm
Engine fire and a faulty nose wheel... that's a hell of a day! I bet they'll appreciate the sim that much more next time.
This Website Censors Me
ikramerica
Wed Oct 31, 2007 5:05 pm
Quoting NEMA (Reply 16):
But aren't the engines specifically designed so that an engine blowout points "away" from the aircraft? Isn't that part of their designed failure mode? I would hope that's the case, as you wouldn't want a "routine" engine failure, no matter how dramatic looking, to destroy the control surfaces and make the plane crash, right?
PSU.DTW.SCE
Wed Oct 31, 2007 5:06 pm
The initial report (which may have changed since) was that the left start valve malfunctioned and opened shortly after takeoff, causing the starter to spool up to a high rate of speed and fail. When the starter failed, in essentially exploded out through the engine cowling, taking out the generator, causing the fire, and compromising a portion of the hydraulic system.
During the emergency landing, the nose gear would not fully deploy due to the hydraulic system issue as a result of the engine failure/fire. They lowered the gear manually and did a go around/fly-by to ensure that the gear was lowered.
Cubsrule
Wed Oct 31, 2007 5:07 pm
Quoting N766UA (Reply 17):
Nothing wrong with the nose gear... but a hydraulic extension is a little difficult with that much engine damage.
OPNLguy
Wed Oct 31, 2007 5:11 pm
Although it was the same N454AA, the original "real" picture was shot 3 years ahead of the date of the fire on N454AA. Additionally, the real/doctored photo show the aircraft about to touchdown on STL's 12R, while the NTSB report indicates the flight with thefir landed on STL's 30L.
[Edited 2007-10-31 10:14:27]
cubastar
Wed Oct 31, 2007 5:20 pm
Quoting Ikramerica (Reply 18):
Engines are designed for containment in the event of a catastrophic failure. Some things can't be designed totally fail safe. The CF-6 center engine failure on the UAL DC-10 was failure of the compressor disc. DL had a MD-88 turbine disc failure on takeoff out of Pensacola where several pax were killed. CO had a DC-10 engine overspeed (caused by the crew) that sent shrapnel through the fuselage and killed a pax. Designers and manufacturers shoot for 100 percent. Occasionally, they don't quite make it.
AAR90
Wed Oct 31, 2007 5:30 pm
Quoting FXramper (Reply 15):
The unofficial story within AA pilot ranks (AA's "official" position is that the "incident" is being "investigated") is that the starter valve (placarded so a mechanic had to manually open/shut this valve) wasn't fully closed after start, the Start Valve Open light was not illuminated after engine start (should have been), therefore the starter spun essentially out-of-control during takeoff and "blew" shortly thereafter causing the fire. Engine Fire light properly illuminated and crew followed proper procedures, but fire continued (nacelle would not hold extinguishing agent for obvious reasons).
There were other problems (I don't recall all) including the DC Bus-Tie not closing so they did NOT have the emergency instruments they would normally have (as in all simulated situations) along with the nose gear indicating UNSAFE when attempting the first emergency landing (nose "pin" not extended). A go-around was initiated and the subsequent emergency landing completed successfully (gear lowered by alternate means). FAA (individual?) is upset due to the go-around with an active fire indication (IMHO: Captain's Emergency Authority so FAA is upset they can do nothing legally... I think I would have just landed, but that is me talking about it and I wasn't the CA on this flight) and didn't evacuate the plane after stopping.
Possible (strong rumors) individual FAA person(s) upset because they may(?) have "tested" the landing gear WITHOUT company/union/manufacturer/etc. representatives present and claim there was no problem with the gear indications --even stronger rumors that such test was invalid as the plane was not configured as it was on the incident flight, but when found out what was going on and properly configured the same as the incident flight.... the same problems occured: No DC Bus-Tie, nose gear unsafe indication, etc. These "individual(s)" were "shown-up" by "others"???
Lots of "stories" floating around the AA pilot rumor mill, but that's the basics that seem to be repeated in ALL the stories I've heard so far. Along with rumors of whom one "FAA individual" may be and why he/she may be "out to get 'those AA' pilots."
In the end, a highly unusual multiple emergency situation where there are no specific procedures in any manual and the Captain used his discretionary authority to make decisions that ultimately led to a safe landing with no injuries. Some may disagree with his decisions, but that's why there is Captain' Emergency Authority... it was HIS decision(s) to make.
TrijetsRMissed
Wed Oct 31, 2007 6:22 pm
Quoting AAR90 (Reply 23):
Shouldn't this have been an indication to the crew to not take-off and perhaps avoid the whole incident?
Quoting Cubastar (Reply 22):
 checkmark  Not to nitpick, but I think the over-speed incident was National.
There's nothing quite like a trijet.
airlinelover
Wed Oct 31, 2007 6:41 pm
Am I the only one who saw that??? AA has no DC9's..
Lets do some sexy math. We add you, subtract your clothes, divide your legs and multiply
777STL
Wed Oct 31, 2007 6:54 pm
Quoting Airlinelover (Reply 25):
Technically, an MD80 is a DC9-80. That's what the type certificate says anyway.
EDIT: To be more specific, there is no specific model known as an MD80, "MD80" is a generic term used for the entire -8x series, i.e. the -81, -83, -87, and -88.
[Edited 2007-10-31 11:58:57]
PHX based
757drvr
Wed Oct 31, 2007 7:01 pm
MD80's are DC9's!
The original designation for this series of aircraft was DC-9-81,82,83 etc.
AA777ER
Wed Oct 31, 2007 7:55 pm
The starter valve/light on this AC was deferred for 10 days before it malfunction after Take Off and cause MAJOR problems for this crew.
This crew did a great job getting the 125 PAX back safety on the ground after Multi Problems with Eng FIRE, HYD Problems and Electric ........................
The FAA and the NTSB investigation continues into MX Programs at ALL US Airlines.
jetmech
Quoting PSU.DTW.SCE (Reply 19):
Interesting. Many of the starter motors I have seen have a really thick ring of material surrounding the air turbine to contain failure. I guess this is to contain a few blades only, and not the whole wheel exploding. This picture shows the starter motor of a RR Trent 700.
http://i94.photobucket.com/albums/l118/Jet-Mech/IMG_0838.jpg
It seems that in all the cases you have mentioned, that entire compressor, fan or turbine discs exploded. IIRC, the certification for the fan casing for instance, is the retention of a single liberated fan blade. I'm not sure if it is a case of the engineers failing to reach 100%, but more the case that an exploding disc, especially a fan disc is impossible to practically contain, and not a certification requirement in either case.
Regards, JetMech
access-air
Wed Oct 31, 2007 8:31 pm
Quoting 777STL (Reply 26):
Yes and No.....The DC9 series includes the 10, 20, 30, 40, 50, 81, 82, 83 and 87.....The MD-88, MD-90, anmd MD 95-30 (B717) are what the what the official FAA Airworthiness certificate says...all the others are DC9s....
Access-Air
Remember, Wherever you go, there you are!!!!
xtoler
Wed Oct 31, 2007 8:44 pm
Kudos on the crew for their actions.
Just a reminder, though, the FAA and NTSB may not be hot under the collar, it's just they have to do their jobs once in a while. Unfortunately their jobs are to pinpoint anything and everything which went wrong and have to go over the same questions 20 times more. The reason being is how can something already safe be made more safe and for this particular incident not happen again. Remember, nothing is infallible and there are always room for improvement.
EMB145 F/A, F/E, J41 F/A, F/E, because my wife clipped my wings, armchair captain
Indio66
Wed Oct 31, 2007 9:07 pm
Come on guys, its all ball bearings these days!
AAR90
Wed Oct 31, 2007 9:22 pm
Quoting TrijetsRMissed (Reply 24):
Quoting trijetsRMissed (Reply 24):
I should have CAPITALIZED the words "NOT ILLUMINATED"??? If the light was NOT on, how would the crew know not to take-off? FWIW, the light is above the CA's head --out of the field of view during takeoffs (and just about any other time as well).
TrijetsRMissed
Thu Nov 01, 2007 5:55 am
Quoting AAR90 (Reply 33):
First off, calm the heck down. I am not the FAA, nor am I out to get you or your friends. This is a forum, we have discussions. Better? Okay. I don't fly an MD-80 so I don't know where every light is. But when you say, light X was not illuminated when it normally is or should have been prior to departure, that led me to ask why the pilots took off.
If the non illuminated starter valve light led directly to the out of control starter and subsequent engine failure, than I don't think it's unreasonable to suggest if light X was noticed to be not illuminated, the crew may have foregone the take-off altogether, preventing the incident.
pilotpip
Thu Nov 01, 2007 6:05 am
I was sitting on the pad waiting for my gate to open up. I watched them do the go around with the mains down and the nose up. The left engine was unusually black but no smoke was coming out. That plane might have been the creepiest thing I've ever seen in the pattern. It was climbing, but not well. Not a day that I'd want to have.
Throughout the whole thing, whoever was NFP at that point was calm, cool and collected on the radio. They did a great job regardless of if the feds don't think their story adds up or not.
DMI
EA CO AS
Thu Nov 01, 2007 6:20 am
Quoting Indio66 (Reply 32):
 rotfl  rotfl  rotfl  rotfl  rotfl  rotfl  rotfl  rotfl
cubastar
Thu Nov 01, 2007 6:11 pm
Quoting TrijetsRMissed (Reply 34):
I believe that most indication light panels are designed to be "dark". Then, any light that is "on" would indicate a malfunction.
cubastar
Thu Nov 01, 2007 7:22 pm
You are absolutely right. My age is showing! Note the following:
Airline: National Airlines
Aircraft: McDonnell Douglas DC-10-10
Registration: N60NA
The aircraft's no.1 engine exploded after overspeeding caused by the crew's experimenting with the auto-throttle system. Shrapnel from the engine struck the fuselage, breaking a window, and leading to an explosive decompression in which one passenger was ejected from the aircraft. The plane landed safely at ABQ after an emergency descent.
tdscanuck
Fri Nov 02, 2007 12:57 am
Not really. The engines are designed to contain parts that they can contain (e.g. blades) but parts on the outside (like the starter) aren't contained or oriented in any particular direction. In this case, it's unlikely that the starter had enough energy to thrown anything through the nacelle and fuselage, even if it went in the right direction. The rest of the mess (fire, generator down, etc.) is primarily a systems issue, not a containment problem.
Engines do not contain burst disks, nor is there any requirement to do so. The energy of a disk is far too high to be practically contained. You assume that a burst disk will go in a straight line from the engine through everything in its path and just try to avoid putting critical and redundant systems in the burst zones.
Quoting JetMech (Reply 29):
Bingo.
Quoting Cubastar (Reply 37):
Correct. All MD/Boeing (and Airbus as well, I think) use "dark cockpit" philosophies. If everything is working right, you should see no lights.
Tom.
higherflyer
Fri Nov 02, 2007 2:58 am
Quoting Xtoler (Reply 31):
The airworthiness certificate may say -88, -90 or -95/717, but the type ratings on pilot certificates show them as DC-9's.
AAR90
Fri Nov 02, 2007 3:23 am
Sorry if you think I was upset... I was not. Just thought what I wrote made sense. I'll try again (see below).
The START VALVE OPEN light simply indicates if the starter valve is open (illuminated) or close (not-illuminated). The light should be on ONLY during actual engine starting. Before starting or after start, the light should be off. Reportedly the crew said the light was NOT illuminated prior to takeoff which would indicate a NORMAL condition.
Quoting Tdscanuck (Reply 39):
STARTING with the late 1970's designs... this is true. The MD82/83 series is a continuation of the DC-9 which was designed in the 1960's. There are a LOT of blue "advisory" and yellow "caution" lights on during NORMAL operations. Sad, but true. Sad
TrijetsRMissed
Fri Nov 02, 2007 4:30 am
True, I should know better. I misinterpreted what was said earlier.
Quoting AAR90 (Reply 41):
Thank you for clarifying.
Quoting Cubastar (Reply 38):
Whatever happened to this crew? I assume at the very least they were fired?
neuroticdave
Fri Nov 02, 2007 4:44 am
I congratulate the pilots on a job well done in getting that bird on the ground with no incidents.
FlagshipAZ
Fri Nov 02, 2007 4:48 am
Is it too soon to know whether N454AA is repairable, or a write-off? Obviously the port engine is a total loss, but how did the fuselage & tail assembly fared? Anyone here know?
Regards.
"Beer is living proof that God loves us and wants us to be happy." --Ben Franklin
mrstl
Fri Nov 02, 2007 4:55 am
I was at Lambert today, I 'm pretty sure I saw this bird without its engine parked in front of the maintenance hangar.
Seems like a long time (a month now) to keep the plane out of service, I assume the investigation is still in progress. Will it go back into service?
PC12Fan
Fri Nov 02, 2007 2:15 pm
Quoting MrSTL (Reply 45):
That's the one.
Just when I think you've said the stupidest thing ever, you keep talkin'!
litz
Fri Nov 02, 2007 9:06 pm
Remember the AA 762 some time back that blew an engine during a MX runup, whilst on the test stand?
Pieces of that fragmented disk sailed clean over something like 2 runways/taxiways, other pieces knifed clear through the bottom of the airplane's fuselage and ended up embedded in the other engine's nacelle.
And for the engine itself? It was sundered completely in two at the point where the disc failed.
A previous accident with a (I think) USAir 762 send pieces of blown disc clear over the top of the airplane's fuselage, across airport properly, into a nearby river.
Blown discs, needless to say, are an incredibly high energy event ...
- litz
FlagshipAZ
Sat Nov 03, 2007 6:55 pm
I just recently learned that the AA 762 in question, N330AA has been written-off and is now being prepped for dismantlement at LAX. I certainly hope the same fate does not happen to MD-80 N454AA at STL.
Regards.
EMBQA
Sat Nov 03, 2007 6:58 pm
Quoting FlagshipAZ (Reply 48):
Why would it...?? I'm sure it was back flying a few days later. That damage actually is pretty minor. A quick engine change, a new cowling and you're back in the air. 6-8 hours.
[Edited 2007-11-03 12:06:37]
Users browsing this forum: 747classic, airmale757, aviatorcraig, b6sea, Baidu [Spider], Bing [Bot], BobMUC, EA CO AS, headlessmike, IAHFLYR, Iemand91, Jetty, lhpdx, LionelHutz, MaksFly, raylee67, rookie00, User001, whatusaid and 12 guests
