Arniepie
737-200 Loses Engine On Take-off In CPT
Wed Nov 07, 2007 3:29 pm
Apparently a Nationwide 737-200 lost an engine on take-off at CPT.
The aircraft was seen heavily smoking and diverted to a nearby airport.
Engine came loose after TR buckets deployed causing the engine to shear off.
737 is ex LH build in '81 reg number ZS-OMG
http://www.702.co.za/news/news.asp#76819
edit for link
[Edited 2007-11-07 07:32:54]
[edit post]
cricket
Wed Nov 07, 2007 3:34 pm
Wow, that must have been rather scary! Kudos to the pilot!
A300B2/B4/6R, A313, A319/320/321, A333, A343, A388, 737-2/3/4/7/8/9, 747-3/4, 772/2E/2L/3, E170/190, F70, CR2/7, 146-3,
A390
Wed Nov 07, 2007 3:38 pm
CraigW
how does an engine just fall off a plane, i must have just come in from JNB or DUR before leaving again fro JNb so it had just done a flight?
Orion737
Wed Nov 07, 2007 3:49 pm
Same happened to a Piedmont 737-2 in the 80s, where the engine fell off in flight.
A390
Wed Nov 07, 2007 3:56 pm
Here is some more news
http://www.int.iol.co.za/index.php?s...&art_id=nw20071107171817856C423027
Must have been a pretty scary landing. Not only one engine but I'm sure quite a few other systems would have been affected.
PlymSpotter
"They took off and left the engine behind," he said.
What, didn't quite get that?
"It was an engine lying on the ground."
Ahh - that makes it perfectly clear  silly
That guy sounds about as shocked as the passengers onboard would have been! Still, I believe on older aircraft models like the 737-100/200 that the engines were attached with sheer pins, which were designed to sheer off in case of an incident? I'm sure someone will know the full details - but I seem to remember reading this in a book once.
Dan Smile
tom355uk
Wed Nov 07, 2007 3:57 pm
Quoting CraigW (Reply 3):
When AA191 (DC10) crashed after losing an engine at ORD, It was discovered the damage had occurred quite a while before the accident. Several cycles had been completed with no problems or indications of a fault, but during the fateful take off roll, the forces on the damaged mounting simply became too great and ripped the pylon and engine off (and the hydraulics and captains instrument power supply).
Tom
on Twitter @tombeckett2285
MD11Engineer
Wed Nov 07, 2007 4:08 pm
The JT8D engine on a 737-200 is attached to the pylon by two cone bolts in vibration damper mounts forward and one cone bolt aft. The aft mount also contains a second safety backup bolt. Just above the T-R is a decal with a green line and an arrow pointing at it, which shows if the rear mount came loose. If the rear mount is defecttive and the engine only held by the backup bolt, the arrow will not align anymore with the green line.
(from memory, the last time I worked on a -200 is about 9 years ago)
Jan
SEPilot
Wed Nov 07, 2007 4:21 pm
There have been a number of 737-200's that have had engines fall off; all of them have landed safely. A 727 lost an outboard engine once after ingesting "blue ice" from a leaking toilet; it also landed safely. I don't know if any 707's have lost engines; I would be surprised if none have. The only Boeing plane that has crashed because of an engine falling off is the 747; and it happened to two of them. One was the El Al cargo plane that crashed in Amsterdam, and that was because when first engine fell off it hit the other engine on that wing (the first one fell off because the fuse pin failed from fatigue) and knocked it off as well, but more importantly destroyed the leading edge slat between the two engines. This caused the same effect as the DC-10 at Chicago, which crashed not because the engine fell off but because the slats retracted when the hydraulic lines were severed and the pilot was unaware of it. The same befell the El Al plane. A China Airlines 747 also had a very similar accident with the same outcome; the 747 pylon attachments were redesigned as a result. Boeing's philosophy was that they would rather have an engine fall off then do structural damage if it became too unbalanced (from losing fan blades, or some such event). This works fine on a twin or even the outboard engines on the 727, but causes problems on the inboard engines of quads.
Gatorman96
Wed Nov 07, 2007 4:30 pm
Pilot: "Left engine seen smoking heavily..."
Maintenance: "Gave it a nicotine patch..."
Cha brro
OPNLguy
Wed Nov 07, 2007 4:58 pm
Quoting MD11Engineer (Reply 8):
Good memory, and the only thing I'd note is that the single aft cone bolt has a cable as a back-up, not another bolt..
All the comparisons with other aircraft are apples and oranges, the cone bolt issues on the 737-100s and 737-200s are, or were, well-known. Increasing inspection intervals seemed to resolve the issue here, and I don't think the industry saw any more problems since the last-1980s. Whether adherence inspections elsewhere is as compliant is another matter.
Coronado990
Wed Nov 07, 2007 5:18 pm
Quoting ArniePie (Thread starter):
Wow! Didn't we just lose a HS-OMG? Very strange! Glad this one made a safe landing.
Uncle SAN at your service!
nema
Wed Nov 07, 2007 5:38 pm
Quoting SEPilot (Reply 9):
And how reassuring is that?. Amazing and great to know.
There isnt really a dark side to the moon, as a matter of fact its all dark!
SEPilot
Wed Nov 07, 2007 5:56 pm
Quoting NEMA (Reply 13):
As I said in my previous post, it goes to the design philosophy that Boeing has had on its jetliners, which has worked on most but not on the 747. I consider it reassuring that, of all of the things that can cause an airliner to fall out of the sky, an engine falling off a Boeing twin is not likely to be one of them.
Arniepie
Wed Nov 07, 2007 6:11 pm
Aren't safety bolts for engines common practise in aircraft design and not solely Boeing's practise?
[edit post]
kalvado
Wed Nov 07, 2007 6:21 pm
Would the plane be able to land with one engine in reverse (or even engine off with TR deployed)?
MD11Engineer
Wed Nov 07, 2007 6:23 pm
Quoting OPNLguy (Reply 11):
I remeber a crushable honeycomb block and a bolt. I think I'll have to dig out my old course notes and check.
Jan
zTagged
Wed Nov 07, 2007 6:25 pm
Quoting Coronado990 (Reply 12):
You know, I thought that when I saw that. Good eye.  checkmark
Quoting Gatorman96 (Reply 10):
Thank you for my new email signature!  rotfl
Something awful.
Wed Nov 07, 2007 6:26 pm
Wow, really amazing. Wonder what the passengers thought when they didn't see any engine.
Any pics???
A390
Wed Nov 07, 2007 6:35 pm
Hopefully I'll get some pics tomorow. If I do I will definatley post them.
Here's hoping !
Wed Nov 07, 2007 6:39 pm
Quoting A390 (Reply 20):
That is great.
Would love to see some pics.
iRISH251
Wed Nov 07, 2007 7:00 pm
Quoting Cricket (Reply 1):
Or "pilots", even.
Many years ago an Aer Lingus 737-200 (EI-ASA, I think) struck a flock of birds on takeoff at Dublin and one of the engines was badly damaged, to the extent that its aft mounting failed and it was retained by the cable that has been mentioned earlier. The aircraft managed to limp back for a landing but at one stage the crew considered that they might have to put it down short of the airport if they did not make it.
Here is a report of a 707 from which an engine detached in flight over France in 1992 but which just managed to land safely, though the aircraft never flew again. http://aviation-safety.net/database/record.php?id=19920331-0
I recall that a USAF KC-135 also suffered the loss of one, or maybe two, engines during GW1 in 1991 but managed to land safely.
JoKeR
Wed Nov 07, 2007 7:08 pm
ZS-OMG
Great that all ended well!
Can't help but noticing the "OMG" part of the registration! How appropriate!
Kafa, čaj, šraf?
CraigW
Wed Nov 07, 2007 8:01 pm
A342
Wed Nov 07, 2007 8:08 pm
That's what I call "losing an engine"! If only more a.nutters learnt to use the word "engine failure" to avoid any ambiguity...
Exceptions confirm the rule.
JoKeR
Wed Nov 07, 2007 8:25 pm
Just reading the press reports and comments on PPRUNE.... the flight deck crew did an excellent job, as did the flight attendants!
Well done to the entire crew of Nationwide 723!  praise
Kafa, čaj, šraf?
OPNLguy
Wed Nov 07, 2007 8:36 pm
Quoting MD11Engineer (Reply 17):
The crushable stuff may have been there too but I -know- the cable was, since that's all the aft part of the engine on ours was hanging on by when it landed, back in the mid-1980s.
In fact, just about every 737 engine cone bolt problem in the USA I can recall (US at PHL, PI @ ORD, DL@DFW, and our partial at DAL was back roughly in the 10 year period of the 1980s, give or take a year on either end. Bad batch?
jcf5002
Thu Nov 08, 2007 4:46 am
ZS-OMG... Ironic because I bet most of the passengers were screaming Oh My G-d!!!
Good job and a pat on the back goes to the crew. I'm guess the flight characteristics of the 732 are slightly changed when it leaves an engine behind..
-Jeff
Its always a sunny day above the clouds || CSEL, CMEL, CFI, CFII, MEI
miamix707
Thu Nov 08, 2007 5:06 am
Tampa 707 on takeoff from Miami, engine bounced fell off, crossed perimeter road and fell on the lake after crossing the street lol
Notice anything unusal about this 707?
http://www.auctiontransportation.com/sites/cv340/images/0000146927_1.jpg
A390
Thu Nov 08, 2007 8:10 am
First pictures and some more information so far. Well done to the crew !
 bigthumbsup
http://www.flyafrica.info/forums/showthread.php?t=8039
OPNLguy
Thu Nov 08, 2007 8:41 am
Quoting OPNLguy (Reply 29):
A little off in my memory of years... 1986, 1987, 1989, and 1992--a six year span...
Delta B737-200 7Jan92 DFW. Engine separation on takeoff. After T/O at 200' breakaway safety bolts called "Cone Pins" sheared for right engine. Engine bounced on grass on right side of runway.
http://www.ntsb.gov/ntsb/brief.asp?e...11X13985&key=1
... FTW92IA055 ....
... DELTA AIR LINES ...
... Tuesday, January 07, 1992 in DFW ...
... BOEING 737-232 ... N322DL ...
THE RIGHT ENGINE SEPARATED ... CLIMBING THROUGH 200 FEET AFTER TAKEOFF. ... UNEVENTFUL LANDING ...
ENGINE SEPARATION WAS THE RESULT OF THE FAILURE OF THE AFT CONE BOLT AND THE ENGINE SECONDARY SUPPORT ASSEMBLY. THE AFT CONE BOLT FAILED AS RESULT OF A PREEXISTING FATIGUE CRACK, WHILE THE ENGINE SECONDARY SUPPORT ASSEMBLY FAILED AS RESULT OF THE DYNAMIC LOADS THAT EXCEEDED THE DESIGNED CAPACITY OF THE MOUNTING BOLTS.
THE TWO FORWARD CONE BOLTS FAILED AT Macedonian Airlines (Greece)">IN OVERLOAD AS THE ENGINE SWUNG FORWARD DURING THE SEPARATION SEQUENCE.
METALLURGICAL TESTING REVEALED THAT THE FATIGUE OF THE AFT CONE BOLT WAS A RESULT OF LUBRICANT INADVERTENTLY INTRODUCED INTO THE CONICAL SURFACE OF THE CONE BOLT.
...Board determines the probable cause ...
THE FAILURE OF THE AFT CONE BOLT AS RESULT OF PREEXISTING FATIGUE CRACKING DUE TO IMPROPER MAINTENANCE, AND THE FAILURE OF THE SECONDARY SUPPORT STRUCTURE AS A RESULT OF LOADS THAT EXCEEDED THE CAPACITY OF THE ATTACHING HARDWARE AND THE CRUSHABLE HONEYCOMB CORE.
Piedmont Airlines B737-200, 20Jan89, right engine separated from aircraft after T/O at Chicago. Newly designed secondary support structure had not yet been installed.
http://www.ntsb.gov/ntsb/brief.asp?e...13X27558&key=1
... CHI89MA046 ....
... PIEDMONT AIRLINES
... Friday, January 20, 1989 in CHICAGO, IL ...
... BOEING 737-201 ... N242US ...
AN AT Macedonian Airlines (Greece)">IN-FLIGHT TEARAWAY OF THE RIGHT ENGINE (FROM THE RIGHT WING) OCCURRED AS THE AIRPLANE LIFTED OFF FROM THE RUNWAY. ... CONTINUED THE TAKEOFF ... RETURNED ...
AN EXAM OF ITS WING & SEPARATED ENGINE REVEALED THE AFT CONE (ENG MOUNTING) BOLT HAD FAILED FROM FATIGUE, THEN THE TWO FORWARD CONE BOLTS FAILED FROM DUCTILE OVERSTRESS.
A RAISED MECHANICAL DEFORMATIVE WAS FOUND ON THE CONICAL SURFACE OF THE AFT BOLT. THE DEFORMITY WAS INDICATIVE OF DAMAGE PRODUCED PRIOR TO OR DURING ASSEMBLY OF THE CONE BOLT AT Macedonian Airlines (Greece)">IN THE ISOLATION MOUNT. A MATCHING CAVITY WAS NOTED ON THE ISOLATION MOUNT. THERE WAS EVIDENCE THAT THE MECHANICAL IRREGULARITY RESULTED AT Macedonian Airlines (Greece)">IN A NONUNIFORM FIT WHICH ALLOWED THE TORQUED FITTING TO LOOSEN DURING CYCLIC LOADING.
AD 88-01-07 REQUIRED THAT ULTRASONIC INSPECTION OF THE CONE BOLTS BE PERFORMED AT INTERVALS NOT TO EXCEED 600 CYCLES. AN ULTRASONIC INSPECTION OF THE BOLTS HAD BEEN ACCOMPLISHED ABOUT 330 CYCLES BEFORE THE ENGINE SEPARATED.
... Board determines the probable cause ...
PREVIOUS DAMAGE TO THE AFT CONE (ENGINE MOUNTING) BOLT, WHICH RESULTED AT Macedonian Airlines (Greece)">IN MISMATCHED SURFACES BETWEEN THE BOLT AND ISOLATION MOUNT, LOSS OF TORQUE DURING CYCLIC LOADING OF THE MOUNTING BOLT, AND SUBSEQUENT FATIGUE FAILURE OF THE BOLT.
US Air B737-200 PHL 5Dec87 #2 engine separated shortly after takeoff. Cracks caused by metal fatigue in one of three bolts; after rear bolt failed the two forward bolts and support cable failed in overload. http://www.ntsb.gov/ntsb/brief.asp?e...13X32769&key=1
... NYC88FA050 ....
... USAIR
... Saturday, December 05, 1987 ... DEPTFORD, NJ ...
... BOEING 737-2B7 ... N319AU ...
DRG TKOF, AS USAIR FLT 224 WAS CLBG THRU 4000', THE ACFT YAWED/ROLLED RGT. SIMULTANEOUSLY, THE CREW NOTICED THE #2 THROTTLE SLAM/LOCK TO THE IDLE PSN & A CONTINUOUS AIRFRAME BUFFET BEGAN.
SOON THEREAFTER, THE #2 ENG SEPD FM THE ACFT & THE BUFFET STOPPED.
THE ENG IMPACTED AT Macedonian Airlines (Greece)">IN AN OPEN FLD, 6 MI FM THE ARPT.
JUST BFR AND Irtysh-Avia (Kazakhstan)">IT SEPD, A PAX SAW THE AFT END OF THE #2 ENG MOMENTARILY DROOP ABOUT 30 DEG.
AFTER ENG SEPN, THE 'B' HYD SYS LOST PRES & THE TE FLAPS WOULD ONLY EXTD 10 DEG.
THE ACFT WAS LNDD SAFELY AFTER AN EMERG GEAR EXTN & DIFFERENTIAL BRAKING WAS USED FOR STEERING.
AN EXAM REVEALED THE AFT MOUNT CONE BOLT FOR THE #2 ENG HAD FAILED FM FATIGUE THRU THE THREAD RELIEF UNDERCUT RADIUS. FATIGUE CRACKS HAD INITIATED ON DIAMETRICALLY OPPOSITE SIDES OF THE RADIUS. SUBSEQUENTLY, THE FWD MOUNT CONE BOLTS & SECONDARY SUPPORT CABLE FAILED FROM OVERLOAD.
ENGINE INSTALLATION, MOUNTING BOLT ..FATIGUE
"Southwest 223" / 3Jan86 B737-2H4, after T/O from Love Field (Dallas), Rt Engine rear mount Cone Bolt sheared, mount failed and restraining cable broke; leaving the engine attached by only the two fwd mount bolts; returned safely. [AWST 124:31 Ja 13'86, photo.]
http://www.ntsb.gov/ntsb/brief.asp?e...10X00187&key=1
... FTW86MA030
... SOUTHWEST ...
... January 03, 1986 in DALLAS, TX
... BOEING 737-2H4 ... N86SW ...
THIS INCIDENT OCCURRED WHEN THE NO. 2 ENGINE EXPERIENCED AN AFT ENGINE MOUNT CONE BOLT FAILURE AND THE SUBSEQUENT FAILURE OF THE SECONDARY SUPPORT LINK (STAINLESS STEEL CABLE).
THE FAILURE OF BOTH AFT ENGINE SUPPORT ASSEMBLIES DURING THE TAKEOFF ROLL ALLOWED THE AFT SECTION OF THE ENG TO HANG DOWN TO WITHIN 4' [sic, transcription err] OF THE GROUND. AS A RESULT, THE NO.2 THRUST REVERSER ACTUATOR ASSEMBLY DRUG THE RUNWAY ON ROTATION.
... RETURNED ... LANDED...
METALLURGICAL EXAMINATION OF THE CONE BOLT REVEALED THAT AND Irtysh-Avia (Kazakhstan)">IT FAILED AS A RESULT OF FATIGUE, MOST PROBABLY DUE TO IMPROPER INSTALLATION OF THE BOLT, SPECIFICALLY, THAT AND Irtysh-Avia (Kazakhstan)">IT WAS UNDER TORQUED WHEN THE OPERATOR RE-INSTALLED THE ENG.
THE SAFETY CABLE FAILED AS A RESULT OF OVERSTRESS, PROBABLY INDUCED WHEN THE ACFT ENCOUNTERED A ROUGH STRETCH OF RUNWAY DURING THE TAKEOFF ROLL.
ENGINE INSTALLATION, SUSPENSION MOUNTS .. FAILURE, PARTIAL
... FATIGUE ... SEPARATION ... OVERLOAD ... UNDERTORQUED
MAINTENANCE, INSTALLATION .. IMPROPER ...
Contributing Factors ... RUNWAY / LANDING AREA CONDITION ... ROUGH /UNEVEN
skyguyB727
Thu Nov 08, 2007 8:44 am
I remember years ago when WN had a B737-200 with an engine dangling precariously just after takeoff. The pic was in all the newspapers.
A390
Thu Nov 08, 2007 9:41 am
LH526
Crew
Thu Nov 08, 2007 9:57 am
Seeing the one-two-go crash earlier last month I can say that -OMG is not a good Reg to fly!
Trittst im Morgenrot daher, seh ich dich im Strahlenmeer ...
MD11Engineer
Thu Nov 08, 2007 10:30 am
Just had a look in my old books. At least the LH 737-200 (I did my apprenticeship on them and also my practical exams for qualifying) didn't use a cable but a long bolt as secondary restraint. The secondary bolt was normally not carrying any load, and so that it wouldn't be overloaded by a shock load should the cone bolt fail, it was attached to the engine via a crushable honeycomb block, which would deform and slow the application of load to the secondary bolt.
Jan
ltbewr
Thu Nov 08, 2007 12:39 pm
At least the design of the 737 and the particular way this incidnet occured as well as well trained cockpit crew meant a good and safe emergency landing. I bet some heads may roll at the mx facility for this failure. Of course, there is a delicate balance of engineering as to engine mounts so that stay on, but can shear off in case of certain extreme circumstances.
Don't forget the Kalita Air 747-100 freighter that lost an engine into Lake Michigan in the USA a few years ago. The a/c was able to land safely a short time later.
A390
Thu Nov 08, 2007 12:56 pm
What if one of these engines fall into an urban area? Central London, packed sports stadium, as examples.
A/C often fly over cities in the world.
I would have thought there were far more safety measures to ensure engines don't just fall off.  Confused
A390
Thu Nov 08, 2007 2:01 pm
Update:
Nationwide Airlines
Press Statement
08 November 2007 – 14h30
Nationwide Airlines Salutes Pilots and Crew
Nationwide Airlines Chief Executive Officer Vernon Bricknell today complimented his entire staff and in particular the Captain and crew of Flight CE 723 for their heroic efforts in helping to maintain the company’s outstanding safety record.
Flight CE 723 was discontinued following an incident yesterday soon after take off from Cape Town International Airport.
Bricknell says this is the first major incident that the airline has experienced since taking to the skies 12 years ago.
Bricknell says he is relieved that the incident, which took place yesterday at Cape Town International Airport, did not result in injury to passengers or people on the ground.
“Upon take off of Boeing 737 Flight CE 723 yesterday at Cape Town International, the captain heard a loud noise immediately followed by a yaw of the aircraft. The captain, after confirmation of information from flight deck instrumentation that one of the engines had failed, immediately applied emergency procedures, an emergency was declared and the aircraft returned to make an emergency landing in Cape Town,” says Bricknell.
Nationwide Airlines has since determined that during the take off roll an object which is yet to be defined was ingested into the engine causing engine failure. The subsequent forces experienced by the engine supporting structure caused this to fail and for the number two engine to detach from the wing. The engine-to-wing supporting structure is designed to release the engine when extreme forces are applied to prevent any structural damage to the wing that may impair the aircraft’s ability to fly.
He reiterated the fact that the Boeing 737 aircraft is by far one of the safest aircraft in service today. “The Boeing 737 is aviation’s most successful story,” says Bricknell
According to Bricknell, there are approximately 5 000 Boeing 737 in service around the world, with one Boeing 737 taking off every 9 seconds, every day.
He says Nationwide Airlines is working with the proper authorities to establish the nature of the unidentified object and will keep the public informed as more information becomes available.
Furthermore Bricknell says Nationwide Airlines has met and surpassed local and international safety best practice standards. The airline is accredited by IOSA, the Operational Safety Audit of the International Airline Transport Association (IATA).
He says the airline industry is the most regulated sector in the world in terms of safety, training and aircraft maintenance.
‘In no other profession are skilled individuals such as pilots required to undergo testing and to demonstrate their proficiency on such a regular basis. Training encompasses a wide variety of subjects and scenarios that hopefully flight crew members will never be called upon to exercise in the operational environment. Yesterday this training paid off – the skills of the crew were called upon and procedures were carried out in a text-book fashion,” says Bricknell.
Nationwide Airlines is a privately owned airline company which flies to local, regional and international destinations.
Ends.
Thu Nov 08, 2007 2:05 pm
Quoting A390 (Reply 35):
Thank you for the pics.
It looks really bad.
A390
Thu Nov 08, 2007 2:14 pm
Quoting B747forever (Reply 42):
No problem !
No doubt there will be more to follow.
LX001
RE: 737-200 Loses Engine On Take-off In CPT
Thu Nov 08, 2007 3:29 pm
I just can't understand why these old planes are still allowed to fly. Even if they are maintained well, I would rather prever seeing them in the museum than flying on them...
LY4XELD
Thu Nov 08, 2007 3:43 pm
From the Independent Online (South Africa)
""The guy next to me seemed to know something about planes. He said, don't worry: the plane will go with one engine. So I thought, that's okay."
She said that while the plane was making a wide turn and dumping fuel, the cabin crew took the passengers through the emergency procedures, getting them to take off their shoes and practice bending down."
Am I crazy or correct in saying that no 737 can begin "dumping fuel"?
http://www.int.iol.co.za/index.php?s...&art_id=nw20071107194353660C626321
That's why we're here.
Umfolozi
Thu Nov 08, 2007 3:56 pm
Several tour groups from the UK were aboard. They were on their way to catch connecting flights to London.
The only good suit is a wetsuit
MD11Engineer
Thu Nov 08, 2007 4:02 pm
Quoting LTBEWR (Reply 39):
During my apprenticeship I have witnessed how a group of mechanics tried to install an engine on a 737-200 f*cked up. The problem was that everybody thought that he was in charge and the 5 people pulled the hoists without any coordination. The result was that the fwd R/H conebolt snagged when it was supposed to enter the hole and got stressed in a direction it was not designed for. One mechanic wanted to sweep everything under the carpet and continue with the installation as if nothing had happened, but the others were more intelligent and insisted that the supect cone bolt should be removed and brought to the NDT department for testing. The result was that it had been cracked by the force acting in the wrong direction and needed replacement. Good that they insisted on checking the bolt!
Quoting LX001 (Reply 44):
Stupid talk by somebody without a clue about aircraft maintenance and operation.
Jan
Siren
Fri Nov 09, 2007 3:05 am
OMG! The plane almost crashed!
Seriously though. I was alerted to this via CNN's story. The 732 doesn't even have facilities to dump fuel... the article specifically says that the plane dumped fuel and "came in very slow". While this appears to be a catastrophic failure, this kind of stuff really does happen fairly regularly (eg. the Kalitta flight into Lake Michigan, and a couple others I'm thinking of but can't name...)
Again, media overhype.
2175301
Fri Nov 09, 2007 3:51 am
Quoting A390 (Reply 37):
Actually, the safety feature is that the engine can fall off in abnormal situations.
It is a lot better than having the wing break apart and the entire aircraft crash.
You are correct that an engine that falls off could hurt or kill someone (or even a few people) - not to mention cause property damage.
That must be balanced by the result where the engine would not break off - and the entire plane would crash. A lot more people would get hurt and killed - and a lot more property damage would result.
Sometimes - having an engine fall off is a good thing. Note that the aircraft managed to do an adequate take off and fly quite well without the missing engine. Another safety feature most people never think about.
Of course, having an engine fall off due to poor maintenance practices is not the best for your image.
The article claims a foreign object. If true - then the safety features worked in this case.
2H4
Fri Nov 09, 2007 6:13 am
Quoting LY4XELD (Reply 42):
You're 100% correct, and the media/tabloids are 100% incorrect:
http://i7.tinypic.com/81hn707.jpg
Source: http://www.boeing.com/commercial/airports/faqs/fueldump.pdf
2H4
Intentionally Left Blank
pilotaydin
Fri Nov 09, 2007 7:24 am
Quoting B747forever (Reply 19):
That low budget airline has a new meaning  Smile?
The only time there is too much fuel onboard, is when you're on fire!
A390
Fri Nov 09, 2007 8:21 am
Quoting 2175301 (Reply 46):
Thanks, what you say makes sense  Smile
