BAKJet
Old Terminal At IND
Fri Nov 09, 2007 1:28 am
I know people have been speculating about what is going to happen to the old IND terminal. most say it will be demolished. well here is mine. I think that the old terminal will be remodeled and used by FedEx for freight to expand at IND.
post your speculations here! ?
[Edited 2007-11-08 17:47:46]
TZTriStar500
RE: Old Terminal At IND
Fri Nov 09, 2007 1:32 am
its going to be demolished...end of discussion
35 years of American Trans Air/ATA Airlines, 1973-2008. A great little airline that will not be soon forgotten.
7e72004
Fri Nov 09, 2007 1:42 am
TZTristar500 seems to have a lot of "quick-short answers." You sound very convincing!! Anyway, i think it will be torn down and used by Fed Ex for extra space. There is no need to keep that "shack" up as it is old and dingy.
The next generation of aircraft is just around the corner!
chase
Fri Nov 09, 2007 3:34 am
There was a thread about this a couple weeks ago. Or may have been an offshoot of a thread on the renaming of the airport expressway. If you're interested. I had heard through radio or indystar.com or some pseudo-reputable source that they were going to make it a shopping mall, but I doubt that's really true...
Indy
Fri Nov 09, 2007 3:37 am
Quoting TZTriStar500 (Reply 1):
I must say I agree with this assessment.
Indy = Indianapolis and not Independence Air
RW170
Fri Nov 09, 2007 3:50 am
 checkmark
319/320/321/712/733/734/735/73G/738/752/753/763/CR2/CR9/DH8/135/145/170/175/190/D9S/D94/D95/M82/M83/M88
BAKJet
Fri Nov 09, 2007 8:20 pm
Quoting Chase (Reply 3):
That wouldn't make much sense because it is so close to the airport, not the city. it probably will be demolished.  Sad
lrdc9
Sat Nov 10, 2007 12:04 am
Quoting 7E72004 (Reply 2):
I flew through there and found nothing to be that bad.
Photo © Andy Jung
Pretty much. Not too much too it.
Just say NO to scabs.
Jeremy
Sat Nov 10, 2007 12:14 am
Anybody know what will happen to the Radisson and Holiday Inn hotels?
You are now free to be sexually harassed and then terminated for filing a complaint--Southwest Airlines to me.
IndyCanuck
Sat Nov 10, 2007 3:48 am
Quoting Jeremy (Reply 8):
Not sure about the Radisson, but the HI Select has just been re-branded or is in the process of re-branding to a Crowne Plaza. From what I understand they are spending quite a bit on upgrading it.
As far as the old terminal goes, I would expect to see it sit empty for a few years while the city attempts to find a tenant, and then that failing it will meet the wreckers ball.
dispatchguy
Sat Nov 10, 2007 10:40 am
I can still remember when the concourse for SWA, and UAL was just nothing more than a tin-roofed walkway, and when the NWA concourse was the old TWA and EAL concourse.
[Edited 2007-11-10 02:41:31]
Nobody screws you better than an airline job!
