sq452
IFE Software Makers...who Does It?
Mon Nov 12, 2007 4:08 am
I know there are only a handful of actual IFE hardware makers in the world, but who actually develops the software or the actual 'program' to run something on the IFE? Reason I bring this up is I know the new KrisWorld on the A380 and the 777-300ER uses a Sun Microsystems office platform to run the office applications but I don't think they are actually behind the whole of the KrisWorld system...
SIN > CVG > BOS
LXA340
RE: IFE Software Makers...who Does It?
Mon Nov 12, 2007 2:08 pm
Well there is Masushita, Panasonic and Rockwell Collins however I don't know if they are only hardware or also producing most of the software. Most airlines getting a system now use one of those 3 systems I don't know if there are much more other systems now on the market.
philipkk
Mon Nov 12, 2007 3:12 pm
Well, there is Thales. I'm not very sure of which component they make but I often hear of the IFE being equipped by them.
knoxibus
Mon Nov 12, 2007 4:05 pm
Quoting LXA340 (Reply 1):
Humm, Matsushita took their worldwide brand name Panansonic a couple of years ago, therefore so far in the market we have Panasonic, Thales and Rockwell-Collins.
Rockwell has given up the long range aircraft market and now focuses on single aisle/business aviation systems (coupled with their Airshow system).
Panasonic has about 80% of the market (at least on Airbus aircraft).
The H/W and S/W are made by the same company. The IFE suppliers develop their core S/W based on a platform, i.e. the most appropriate one when they launch a new system (therefore it can be different over a couple of years, depends how many systems they produce). This core S/W is then customised to integrate the various functionalities and GUIs that the customer want.
No matter what anybody tells you, words and ideas can change the world.
1337Delta764
Mon Nov 12, 2007 5:02 pm
Quoting Knoxibus (Reply 3):
Don't forget about LiveTV, JetBlue's IFE subsidiary, which is very popular with LCCs.
Not necessarily. While Rockwell Collins currently doesn't have a contract to supply IFE to the 787 and A350 from the factory, they continue to supply systems aftermarket. AA's new IFE system that will be installed on their 777s is a Rockwell Collins system, presumably the dTES or eTES system.
LXA340
Mon Nov 12, 2007 8:21 pm
Quoting 1337Delta764 (Reply 4):
The IFE system on LH at least the AVOD for C and F class is also Rockwell Collins, don't know about the new IFE for Economy Class.
