mcamargo
AUS Low Cost Terminal - Status?
Tue Nov 13, 2007 5:07 am
I searched, but can't seem to find any updates as to how the new low cost carrier terminal at AUS is going. Has construction already begun?
How's it going to be set up overall? Will PAX be able to move between the two terminals or will they be completely separated?
[Edited 2007-11-12 21:08:16]
I live for the day mainline returns to BRO...
tcfc424
RE: AUS Low Cost Terminal - Status?
Tue Nov 13, 2007 5:17 am
The ULCC terminal in AUS has not started construction yet. I have heard many things, including that Viva Aerobus (Sorry, don't know their code) will be using/renovating a Texas National Guard Building?!? Either way, the "terminal" will be located on the south end of the field, prohibiting any easy movement between terminals, as the Barbara Jordan terminal is on the north end of the field. The area is bisected by two taxiways and numerous apron areas, including the maintenance (delay central) hardstand.
I will believe all of this when I see it. Viva Aerobus has backing from Ryanair, giving it some clout, and seems to have made a name for themselves in Mexico, however I just don't believe the hype that they will be able to offer THAT much lower of a fare. Aeromexico flies daily to MEX, and they only use an RJ...F9 tried CUN (they don't do it anymore)...I just don't see this being a completed venture.
Also, I have seen exactly NO activity on the south end of the airfield. If they are bucking for a March start, they better get on it, winter weather is not friendly to construction.
ssides
Tue Nov 13, 2007 4:49 pm
Can anyone tell me the purpose of building this terminal so far from the existing terminal?
"Lose" is not spelled with two o's!!!!
tcfc424
Tue Nov 13, 2007 5:08 pm
The purpose is that the building will essentially be a warehouse. It will have absolutely no frills, in order to keep costs low. The reason for it being so geographically separated is simply it is the only place to really build that won't cost an arm and a leg.
ssides
Tue Nov 13, 2007 6:35 pm
Quoting TCFC424 (Reply 3):
So, other than this Viva Aerobus airline, what other airlines would use it? I can't seeing WN or F9 going that no-frills.
Mikey711MN
Tue Nov 13, 2007 7:26 pm
Quoting Ssides (Reply 4):
Hmmm...if there only was an airline that serves the United States that is predicated on providing a no frills, ultra-low-cost operation modeled after the ones found in Europe and beyond.
I bet such an airline might be interested!  Wink
-Mike
I plan on living forever. So far, so good...
mcamargo
Tue Nov 13, 2007 10:58 pm
Skybus, perhaps?
