Alessandro
New Beluga?
Fri Nov 16, 2007 10:01 pm
So could you use a damaged A346 and build a new Beluga out of it?
MEA-707
RE: New Beluga?
Fri Nov 16, 2007 10:18 pm
Why would they bother? The A346 isn't even certified as full freighter yet. It will cost a lot to certify it, the extra length isn't needed for outside parts cargo, it's usually the bulk/height. They can better use some 2nd hand A-300s if they need a few more Beluga's, or use the A-330 as platform for a few new Beluga's.
nobody has ever died from hard work, but why take the risk?
Alessandro
RE: New Beluga?
Fri Nov 16, 2007 10:23 pm
So if they decide to fly parts of A380 (especially if the -900 becomes reality) instead of the ship/truck solution, then I see use for the A346.
Certification cost is of course part of the problem, as the design cost.
Stitch
RE: New Beluga?
Fri Nov 16, 2007 10:35 pm
Quoting Alessandro (Thread starter):
Plans did exist for an A340-based "Beluga-style" large cargo carrier.
PlymSpotter
RE: New Beluga?
Fri Nov 16, 2007 10:45 pm
It wouldn't surprise me if a new one was constructed - the A300 based variants are going to need replacement one day.
Dan Smile
Alessandro
RE: New Beluga?
Fri Nov 16, 2007 10:53 pm
Stitch do you remember which size,-600 is a bit larger than the -300...
Stitch
RE: New Beluga?
Sat Nov 17, 2007 1:45 am
Quoting Alessandro (Reply 5):
Almost positive it was based on the A340-300. Not sure an A340-600 is structurally sound for such a conversion, to be honest, due to the length of the frame, which already requires additional bracing in her passenger role. Even the A340-300 would be longer then the A300ST so it should be plenty.
