Observer
380-425 Seat 787
Tue Nov 20, 2007 3:19 pm
Boeing's Scott Carson talked about a 380-425 seat 787 at the Dubai Air Show. Jon Ostrower and Scott Hamilton have interesting reads here http://www.flightglobal.com/blogs/fl...heres-been-a-good-amount.html#more and here http://leeham.net/filelib/ScottsColumn112007.pdf .
sphealey
RE: 380-425 Seat 787
Tue Nov 20, 2007 3:24 pm
Something tells me there will never be a 380-seat Boeing 787 (nor a 787-seat Airbus A380)  Wink
sPh
Stitch
Tue Nov 20, 2007 3:37 pm
I can see no reason for Boeing to go that high with the -10.
If Boeing wants to build a 787HGW, then the more logical choice (at least to me) would be to launch a 69m 787-10 with around 328 to 370 seats and a 75m 787-11 with around 370 to 405 seats.
However, as Scott Hamilton noted, a 75m 787-11 might very well be a "stretch too far". While the CFRP structure can be reinforced with less material then if it was made of Al, which helps it from suffering the issues the A340-600 does, it's still a mighty-long plane.
Boeing might very well be better off going to a 10 or 11-abreast Y3 which could firmly stake out the ground above the A350-1000 as well as offer more capacity (and lower CASM) then the A350-900 instead of a 787-10HGW and 787-11.
[Edited 2007-11-20 07:45:50]
dl767captain
Tue Nov 20, 2007 4:51 pm
if they really want to build a 787-11 it needs to be wider in diameter and not longer, it could still use the 787 technology but scaled up to be wider and hold more pax and still be around the same length as the -9 or -10 version. It almost seems like Boeing is going to try and merge the Y2 and Y3 categories together. The 787-10 could technically become the 772NG if the range works out but they really should make the -10 and -11 wider like the 777 and build a plane specifically for those seat ranges with all the 787 technology
IAD787
Tue Nov 20, 2007 7:35 pm
I sat down with Addison Schonland and Scott Hamilton of AirInsight, LLC this morning to record a podcast about the 787-10.
http://airinsight.podomatic.com/entry/2007-11-20T08_36_10-08_00
Former FlightBlogger turned Wall Street Journal Aerospace Beat Reporter
hawkercamm
Tue Nov 20, 2007 7:48 pm
I still hold the believe that Boeing should do a "half-new" aircraft to replace the 777-200/300.
I think the B787 should be stretched to a 70m -10 and a 76m -11.
Note the B777-300 is 73.25m in length.
I think the stiffness/strength/weight efficiency provided by CFRP (2nd generation at that) should allow Boeing to be near the 777-300 length without weight problems with the B787 cross-section.
I would propose:
B787-1000 with 300-340 seats (8-9 abreast Y) << 70m
B787-1100 with 340-380 seats (8-9 abreast Y) << 76m
Both these would make extensive use of the baseline aircraft:
Airframe
>Nose
>Cross-section
>Rear-end
>Fin
>Stabilizer
>Nose Landing Gear
Systems
>Systems architecture
>Hydraulic system
>Electrical system
>Flight control system
>Cabin system
>Cockpit instrumentation
Certification
>Grandfather rights for fuselage/tail/systems
Flight crew
>Same type rating for flight crew
>Same training for cabin crew
Both would benefit from the following being new
Airframe
>Totally new Mach 0.85 wing
>6-wheel MLG
>Wing-to-fuselage fairing
>Structure for MTOW to allow both -10 and -11 to do 8200nm
Engine
>New engine based on the Trent-XWB technology standard which is 1/2 a generation better than GEnX
I introduce a bigger step between the -9 and the -10 to help improve the (hypothetical) numbers for the penalty of having to carry a 6-wheel MLG.
Later if the market demands the -11 MTOW and structure can be put onto the -10 fuselage to create a B787-10LR (9000nm).
Another benefit of a bigger gap between -9 and -10 is (if required) the -10 MTOW and structure (Wing & MLG included) can be put onto the -9 to create the B787-9ULR, 9500nm, LHR-SYD with 200 business/Y+ seats, maybe!
I think this option could be done for $5-6B ($6-7B with both LR and ULR) where as a totally new design would cost $12B+ in the 2015-2018 time frame.
It has extensive commonality with the current -8 & -9 and thus reduces the costs to the airlines.
Time to market should be a little faster aim for 2015.
By designing new wing and engines you change the components that contribute to 95% of the performance.
B787/A350 fuselage cross sections are both very efficient. Bigger cross-sections (B777 & B747 aft fuse included) result in a lot of fresh air being flown around. Bigger cross-sections don't become efficient until you get to double deck triple/quad aisle (B747 forward fuse/A380). A simple measure is fuselage circumference/seat
Thoughts!
[Edited 2007-11-20 11:54:22]
IAD787
Tue Nov 20, 2007 8:33 pm
Open question, is Airbus given the advantage with Boeing selecting a cross section smaller than the 777?
Stitch
Tue Nov 20, 2007 9:20 pm
Quoting IAD787 (Reply 6):
Likely not, in that the spun-CFRP barrel should not need significant (read "heavy in weight") reinforcement even if pushed out to 75m.
While the A350 has a bit more shoulder room, in terms of actual seat width, an A350 only offers an additional three-tenths of an inch. This is essentially unnoticeable.
extspotter
Tue Nov 20, 2007 9:42 pm
I think you'll find this is a special variant of the 787-9 for FR's new transatlantic services, (3-4-3 all Y), less galley space and 29 inch pitch. Then maybe 380 could fit, either that or wait till Corsair buys a few!
AF BE BY FR MV PD SZ U2 VZ DHC6, 8-3/4Q, 732/8, 763ER, A319, A380
jacobin777
Tue Nov 20, 2007 9:45 pm
Quoting IAD787 (Reply 4):
..thanks.. thumbsup  Smile
"Up the Irons!"
SNATH
Tue Nov 20, 2007 9:47 pm
Quoting Sphealey (Reply 1):
I wouldn't be surprised if we see a 800+-seat A380 in the future. A A389 with a high density config should be able to do that.
Quoting EXTspotter (Reply 8):
Oh. My. God. An absolutely terrifying thought. I will have nightmares tonight.  Smile
Tony
Nikon: we don't want more pixels, we want better pixels.
Rheinbote
Tue Nov 20, 2007 11:23 pm
Quoting Stitch (Reply 2):
What, a 787-11 thread and Zvezda has not yet called in?  Wink
Scott Hamilton mused the 787 may be 'too much' of a point-design. I'd wager that it rather is a well balanced design devised around the -8, the -9, and 'simple stretch' -10 staying within the confines of the -9's MTOW. A 'doube-stretch' 787-11 would be a folly as much as the 340-600 is.
My bet is that the 350 will be bracketed by the 787-8/9/10 from below and an all-new Y3 from above. The 787-10HGW is nothing but a scarecrow to move the 350-1000 as far as possbile into Y3 territory. Whatever, Boeing doesn't have to make a move until the 350 is carved in stone.
Stitch
Wed Nov 21, 2007 1:07 am
Quoting Rheinbote (Reply 11):
Well a 787-11 could not reasonably be built on the current frame unless Boeing wants a 777-300 replacement and the total sales for that model were only 60 and the last was ordered over three years ago.
Yup. It would be a perfect pincer maneuver:
787-9 and 787-10 bracketing the A350-800.
787-10 and Y3-100 bracketing the A350-900.
Y3-100 and Y3-200 bracketing the A350-1000.
RIX
Wed Nov 21, 2007 2:28 am
A question: what would be the advantages of building all-new aircraft where "heavy" (literally) upgrade of existing one would work? "HGW-zing" of 787 is way cheaper than all-new Y3, 350 has nothing that is not doable on 787 (that is, they are of about the same size and technology), hence is absolutely capable to directly address larger 350. Y3 would make sense for larger capacity, but not for one that 787 can reasonably cover. Plus, 330/787/350 cross section looks to be the one with the least waste of space.
Stitch
Wed Nov 21, 2007 3:50 am
Quoting RIX (Reply 13):
With a 10 or 11 abreast seating in Y, the Y3-100 and Y3-200 could carry more folks then a 787-10 or 787-11 in a smaller package. Even though the 787's structure should scale to 69m and 75m, there will be some penalties in doing so. Also, shorter planes improve airport compatibility, though the A350XWB itself will be quite long (67m and 74m), so a long 787 won't be any more of an imposition on airports that handle A350s.
iwok
Wed Nov 21, 2007 4:07 am
If the 350 could have done 10x wide, then yes. However, since the 350 is limited to 9x wide, then they are essentially the same plane.
-iwok
SKA380
Wed Nov 21, 2007 7:00 am
What issues does the A340-600 suffer from?
XT6Wagon
Wed Nov 21, 2007 10:34 am
As others have stated, the A350 right now can't do 10Y in anything less than charter configuration. the 777 right now can do 10Y with seats that while not a full 17.2", is "passable" with a custom outer seat.
While I personally think a 787HGW is the proper way to go, It might be possible to get a better 10Y config in a 777NG if they can thin out the sidewalls. More expensive but possible given the round fuselage would be thinning the floor beams and lowering the floor. 10Y at 17.2" would dramatically change the seat mile costs compared to 9Y.
scouseflyer
Wed Nov 21, 2007 11:35 am
Quoting SKA380 (Reply 16):
I don't know if it actually suffers from any issues inreality but it is very long for it's width and care has to be taken with weight distribution as it can become nose heavy otherwise leading to poorer fuel consumtion.
Plane diameter Length Ratio
A346 5.28m 75.5m 14.3
B773 5.86m 60.6m 10.3
B753 3.54m 54.5m 15.3
Obviously there is a balance to be found somewhere between diameter and length the thinner and longer a fuse is the better the aerodynamics are (less frontal area) but the more unstable and less use the interor is. A very short and fat airline wouls have good stability but appalling aerodynamics so it's a balance in the middle.
It'd be interesting if the 757-300 suffers from the problem that the A346 is rumoured to have?
RIX
Wed Nov 21, 2007 12:33 pm
Quoting Stitch (Reply 14):
- that's the point, "more folks". That would make sense as a lower end of a whole different capacity range. Which (the whole range) may also be covered by larger/heavier 787 and 10 abreast, possibly slightly more stretched, upgraded 777. The upper end would be still left void, but that is the one approaching VLA which is hardly a hot seller. While 787 can be expanded to cover current 777 segment, and 777 itself to be shifted to where 744 is, being a "twin monopoly" there. BTW, that may be exactly what BA means by "something more radical" from Boeing (may also be heavy 78A, or both).
Stitch
Wed Nov 21, 2007 1:56 pm
Because of the length of the fuselage compared to the diameter, Airbus was forced to add a not insignificant amount of additional structural reinforcement to the fuselage which added a not insignificant amount of weight. So, like the A345, she is "heavy" for her size and that eats into the payload (passenger, cargo, and fuel) she can carry. So she is not as capable as she could be.
CFRP does not require as much material to reinforce it for the same loads as Al does, plus the material is lighter then Al and the larger cabin diameter of the 787 means less reinforcement is required. So while a 787-10 and (especially) a 787-11 would be "heavy" for their size, it would be not nearly as high in terms of a payload penalty percentage as it was for the A340-600.
Quoting Scouseflyer (Reply 18):
It'd be interesting if the 757-300 suffers from the problem that the A346 is rumored to have?
There would be some penalty, I am sure, but the 757-300 stretch was not as great from the baseline 757-200 as the A340-600's was from the A340-300. What hurt the 757-300 was her lower range, since MTOW could not be raised enough to allow for sufficient fuel load to match the 757-200.
justloveplanes
Wed Nov 21, 2007 4:57 pm
 checkmark
I think Boeing's best bet is all an new Y3 by 2018, at which point they will have an advantage over Airbus. Until then, even with the 777X, Boeing will be taking it on the chin. Boeing neeeds to be very aggressive with the 788/9 to make up the difference, an advantage they may keep for quite a while. I am one of those that believe the 787 will maintain a technical advantage over the life of the 787/350 airframes as long as the engine technologies stay even. So Airbus has about 3 to 5 years (the difference between A3510 and Y3 EIS) to lead the 777 sized market.
abba
Wed Nov 21, 2007 5:35 pm
Quoting Justloveplanes (Reply 21):
If Boeing does that then Airbus will make a brand new 320 with the new engines available by then - or (knowing that the A320 is doing very well indeed over the 737 and knowing that the 320 still have more potential for further improvements than the 737due to its newer design ) - make the A350 a little sister as technology by then will make it possible to get performance better than the 787.
This game is a little bit like chess - you make a move and by the same token you also weaken yourself and open yourself for attack. Boeing went for the 330 and is now going to loose the 777. Overall Airbus seems to be in the strongest position due to the 320 doing so very well indeed so that they better than Boeing can afford to keep status quo in the single isle market.
Abba
Stitch
Wed Nov 21, 2007 5:52 pm
Quoting Abba (Reply 22):
If Boeing does that then Airbus will make a brand new 320 with the new engines available by then...
Boeing will likely have the 737RS ready before Airbus can have the A320RS ready, but I wonder if Boeing might hold off on deploying it in order to prevent Airbus from revising it after the 737RS enters service to try and position it better.
On the flip side, even with Airbus constantly following Boeing's lead, the Boeing product still does very, very well. The 737NG has kept general pace with the A318-A320 and the 747, 757, 767, and 777 families have outsold the A380, A330 and A340 families as well as the A321.
So Boeing may feel the initial replacement market for the 737RS would be so strong they could easily secure 2000+ orders within twelve months of program launch which would mean even if Airbus makes the A320RS "better", the 737RS will be guaranteed a positive program RoI, regardless.
It will be interesting to see what the margins on those A320 sales are. Again, while I am not implying in any way, shape, or form that Airbus sold any of those frames at a loss, I would doubt the margins on the majority of them are better then a few percentage points. Of course, with that volume, even 4-5% margins will bring in a bunch of money.
abba
Wed Nov 21, 2007 7:36 pm
Quoting Stitch (Reply 23):
They might - however, it is nevertheless Boeing that will have the most to gain if they can change the situation in the SI segment. Sure, the 737 is doing ok. But the 320 is doing better. So here Airbus can well afford to wait untill Boeing moves and tail them with a few years - in particular as Airbus is now updating the 320 so as to minimise as much as possible the advantage an 737RS might have over their product. There are obvious advantages to be the second mover!
So let us look at the WB.
Untill the 380 Airbus had essentially only one competing aircraft in this segment - the 330/340 can be seen as one aircraft in two variations. Sure there was the 300/310 but as a short range WB this was a niche aircraft if there ever was one!
Boeing on the other had had a full line up: the 767 (with the 757), the 777 and the 747. The 767 was the one that was having most problems so Boeing went to replace that while at the same time updating the 747 to compote primarily as a freighter (and as an also run as the intercontinental that hasn't been exactly successful).
Doing the 350 makes for a very interesting situation:
if Boeing goes for the Y3 and put it in between the 777/350 and the 380 Airbus can go for the 787. And as the 787 is the first composite aircraft there are possibly room for quite some improvements! This will leave Boeing in a difficult situation with only one dominant model while Airbus is having a strong line up of with its newer 787 competitor, the 350 and the 380. Boeing will have a 777 also run, a 787 also run, a Y3 as their only state of the art aircraft. The 747 finally gone by then.
As to timing: Airbus might well be able to begin definition and development of a new frame by the time the 380 and the A400 are both up and running rather than when the 350 is out of the door. This might be about the same time as Boeing is ready - or shortly thereafter.
jacobin777
Wed Nov 21, 2007 7:58 pm
...these arguments sound nice and pretty but don't hold any water because at the end of the day, since both Boeing and Airbus (EADS) are publicly traded companies, ROI is more important than market share......
One company has a +ROI and another a -ROI to flat-ROI....I'll let you do the guessing... Wink
"Up the Irons!"
Stitch
Wed Nov 21, 2007 10:22 pm
Quoting Abba (Reply 24):
The trick is, how much is each sale bringing in? Again, I firmly believe Airbus is not selling A320s at a loss, but they are likely discounting deeper then Boeing to win these new customer orders. So four 737s might bring in as much revenue as five A320s and, as such, Boeing's 2007 rate of selling five 737s for every six A320s means Boeing is making more money, overall, even on less volume. Also, as Airbus pushes their backlog further and further out, Boeing becomes better able to meet some customer's delivery timetables and can improve their margins a bit - "You can pay $75 million for this 737-800 and have it in three years, or pay $70 million for that A320-200 and have it in five".
Then again, Airbus building such a huge backlog of planes might mean that even if they have the A320RS ready, they won't be able to launch it because they still have so many deliveries to meet, allowing Boeing to de-facto score additional orders due to being better able to meet a customer's delivery timetables.
If Boeing goes for the Y3 and put it in between the 777/350 and the 380 Airbus can go for the 787. And as the 787 is the first composite aircraft there are possibly room for quite some improvements! This will leave Boeing in a difficult situation with only one dominant model while Airbus is having a strong line up of with its newer 787 competitor, the 350 and the 380. Boeing will have a 777 also run, a 787 also run, a Y3 as their only state of the art aircraft. The 747 finally gone by then.
The trick is, the A350 will not be as effective as the 787 in the marketspace the 787 currently is addressing (A330/767) because the A350-800 is a shrink of the baseline (A350-900) and is competing against both the baseline (787-8) and stretch (787-9). The A350-900 is already closing on a 2:1 advantage over the A350-800, whilst the 787-8 is enjoying a 4:1 advantage over the 787-9.
Where the A350 is going to do best is as a 777 and A340 replacement. The A350-900 nicely covers the 777-200 and A340-300 market and the A350-1000 handles the 777-300/A340-500/A340-600 zone.
So Boeing has little to fear, overall, from the A350 when it comes to the 787.
They have a good deal to fear from the A350 when it comes to the 777, which I think if Boeing wants a long-term answer, they need to skip the 787HGW and go to Y3, even if it takes longer and costs more. Part of what helped the 777 sell against the A340 was that extra seat in each row of Business and Economy. Airbus can tout how passengers like not having that extra seat, but the only opinion that really matters in the end is the airline's and they do like it. As such, I think Boeing needs Y3 so they can respond with that extra seat in C/J and Y and maybe even two more seats in Y (3+5+3), if possible.
justloveplanes
Wed Nov 21, 2007 10:31 pm
Airbus has already ceded the 788 sized market to Boeing in the near term. If it tries to go for it with the A320NG, it will again leave the bottom end to Boeing's 737NG as one would expect Boeing to have an optimized family below the 787. Regarding composite improvements, this is the other fly in the ointment for Airbus. It is reasonably possible that the A350 will not have superior CASM to the 787 upon introduction, this being because of Boeing's lead in composite construction. Boeing will have probably delivered 400 plus barrel composite aircraft before the A350 ever flies and will have a lead in understanding optimization of this technology which they may apply in the intervening time. If the engine technologies migrate equally, there will be no leapfrogging on the A350 versus B787 like is customarily the case. This is due to where A and B placed their bets earlier this decade (A380 versus B787) as has been discussed before.
jacobin777
Thu Nov 22, 2007 12:07 am
Quoting Stitch (Reply 26):
....Boeing is going to be waiting to see the final specs for the A350-1000 before making any types of commitments with the B787/Y3, etc....so for now, it will be a "waiting game" until we get a more definitive A350-1000 number.... Smile
"Up the Irons!"
XT6Wagon
Thu Nov 22, 2007 12:53 am
Quoting Justloveplanes (Reply 27):
It looks like Airbus has ceded the 788 and 789 markets entirely for a long time to come. Airbus has proven its only capible of having 2 balls in the air. When it threw in a 3rs (A380) its handling of the first 2 got sloppy. This might change in the future, but it remains that Airbus would be ill-advised to persue 3 active aircraft families. Thus making a plane that bridges the gap between the A320 and the A350 a bad plan. I'm not even sure about them keeping the A380 an active instead of legacy project since its time, money and other resources being spent.
Airbus also has a problem. The 737RS is going to be bigger than the 737NG. The MX benifits from the 787 technologies is enough to cause plenty of airlines to say they will order it even with the engines of today. Basicly we are looking at what Airbus did with the A320 series when Boeing refused to upgrade the 737 when customers asked. Only this time its Boeing that will have the years in the lead, and doesn't have the problem Airbus had at the time... no name and 0 market share in the segment. That said until the next recession, narrowbody market share is all about the production rates, not the relative quality. So Boeing stealing market share back in the narrowbody market will be based on either a willingness to increase production with the 737RS program over the 737ng levels, or a major recession causing orders cancled and orders based on a much deeper level than "when can I get it parked at my gate with my logo on the side".
Lots of A320 and 737 are sold providing the financial people lots of fairly reliable numbers out in the public domain. They support your assertion that the 737NG costs more on average than a A320. More troubling for Airbus is that the 737NG commands a higher used price than the A320 series. This lowers the cost of leasing and borrowing against the plane, making the higher asking price effectively the same to many airlines. In other words, Its easier to talk leasing companies and banks to put a plane in your hands if It costs 1.5million more, but after 5-10 years its still WORTH 1.5 million more than your other choice. Which effectively adds a couple points in the value comparison as it ages, and provides "profit" on default of a loan, or on lease return.
That said, the A320 production rate is a big problem for the valuation of the planes used. The recent increases in production can't help but kneecap it more. Afterall why buy used when Airbus has 400+ slots a year it HAS to sell. The 737 market being limited to just a hair over 30/month on the production side, with a large % of that taken every month every year by large carriers like WN and RyanAir its hard to get your hands on a new one, and low production makes for it hard to get a used one. Keeps the value high.
abba
Thu Nov 22, 2007 7:13 am
Possibly - even if neither you nor I know for sure. And their ability to discount deeper might be that their methods of manufacturing the 320 is using advanced '80 techniques optimized and modified ever since while the 737 is using optimized and modified ditto from the late '60ties. Remember that the cost of production is also defined by how a product is made. Airbus might well be able to sell the 320 cheaper than the 373 and still maintain a higher margin. It is no doubt way cheaper to produce a 320 than to produce a 737. Save for the last year or so where they have paid off the 380 troubles Airbus has had - also compared to Boeing - satisfactory result.
Why do you think that they are establishing lines in China?
Well - I am not talking about the 350 - but a new product Airbus might begin to develop when and if Boeing decides to go for the the 350 "from the top". Such a potential product might have an EIS 8-10 years after the 787 and will then have technology available that will allow it to do to the 787 what the 787 did to the 330.
And as the 350 came out later than the 787 and Y3 will likely come out before Airbus goes for the 787 with a new model Airbus might be able to make improvements over the 787 that are better than the improvement Boeing can let the Y3 have over the 350. Airbus will simply have an older target to fight in the 787 than Boeing will in the 350!
As I have said many times - the right response for Airbus to the 787 from a strategic point of view was to go directly for the 777 taking what untill then was Boeing's only state of the art aircraft in its class out of the game.
hawkercamm
Thu Nov 22, 2007 7:49 am
Quoting XT6Wagon (Reply 29):
In fact Airbus have placed the A350-800 between the 788 & 789 with comparable fuel burn per seat. Stretching to the A350-900 fuel burn per seat improves and is better than B787. Trent-XWB!
Stitch
Thu Nov 22, 2007 5:56 pm
Quoting Abba (Reply 30):
The 737's moving assembly line is more modern and optimized then the "old-style" static production line A320s are built on. Airbus does build the A318/A319/A321 on a moving line at XFW.
That I tend to doubt. A320 sections are flown where 737 sections are sent by rail, so the transport costs for an A320 are more. And the static production line is not as efficient and is more susceptible to "bottlenecks" that will stall the production line compared to the moving line the 737 is on. I believe the A320 parts arrive in a more completed state then the 737 parts do, so that will make final assembly both quicker and more efficient.
To get China to buy A320s. Much, if not all, of that plant's production is tasked to the Chinese market.
I tend to doubt Airbus will build an "A345" to compete with the 787 once the 787 has already had ten years worth of sales and has already met most of the demand for that market niche. There is a reason Airbus did not exactly match the size and payload of the 747 when they launched the A380.
Yes it was. And Airbus was very fortunate that the market told them this in time for Airbus to respond.
Rheinbote
Thu Nov 22, 2007 6:14 pm
Quoting Jacobin777 (Reply 25):
 checkmark  see Tom Enders' speech of today to the Hamburg work council...
http://www.spiegel.de/international/business/0,1518,519021,00.html
Outstanding orders are likely to be convertible, as the 320RS may actually be cheaper/faster to produce than its predecessor.
But all have the -1000's wing, so there's no direct competitor for the 787-8 and the 350-800 is a direct competitor to the -9.
Quoting Jacobin777 (Reply 28):
 checkmark
Quoting HawkerCamm (Reply 31):
To me it looks like the -800 and the -9 are about equal in MTOW, range, and payload. The -9 is better in fuel burn per seat than the -8. Where is the 350-800 in between, in fuel burn per seat?  scratchchin
XT6Wagon
Thu Nov 22, 2007 6:16 pm
Quoting Stitch (Reply 32):
I don't think Airbus was told, so much as grabbed off the street, taken into a back alley and beaten nearly to death in time to change the A350 plans.
Even then its taken a couple return visits from ILFC to slap Airbus around in public to make them stop going about it 1/2 assed.
Rheinbote
Thu Nov 22, 2007 6:44 pm
With hindsight, a thoroughly modernized A330 with new engines, advanced alloys and a new interior might have been a 'more appropriate' idea than the 350XWB.
tdscanuck
Thu Nov 22, 2007 7:02 pm
The 737NG production line was designed in the 90's. It is considerably more advanced than the A320 line (except the line in China).
Quoting Rheinbote (Reply 35):
How you figure? There is no way a re-engined/re-interiored A330 would come close to the maintenance cost reductions of either the A350 or the 787.
Tom.
Rheinbote
Thu Nov 22, 2007 7:30 pm
Quoting Tdscanuck (Reply 36):
More appropriate if you have a look at the situation Airbus is in. Airbus could have expected to sell a number of them, say, in the high hundreds at acceptable profit while finishing the 400M and the 380, and then prepare for the 320RS. Now they face changing their complete industrial setup from metal to black - in the midst of a financial and leadership crisis.
Rheinbote
Thu Nov 22, 2007 7:37 pm
The main A318/319/321 FAL in XFW is a flow line very similar to that of the 787. I think the XFW operation is even more advanced than Renton as section assembly and the systems installation lines are flow lines as well.
Stitch
Thu Nov 22, 2007 8:03 pm
Quoting Rheinbote:
With hindsight, a thoroughly modernized A330 with new engines, advanced alloys and a new interior might have been a 'more appropriate' idea than the 350XWB. Airbus could have expected to sell a number of them, say, in the high hundreds at acceptable profit while finishing the 400M and the 380, and then prepare for the 320RS. Now they face changing their complete industrial setup from metal to black - in the midst of a financial and leadership crisis.
But did they not offer just that with the final non-XWB A350? Though you are correct in noting that it had scored 182 orders and likely would have scored more.
However, the long-term trend appeared to favor the 787 because of the longevity and maintenance advantages of it's CFRP structure. As such, Airbus may have felt the 767/A330 replacement market was essentially "lost" to them and with the sales prospects of the A345E/A346E looking grim, likely felt that it was better to just re-position themselves in the A340/777 marketplace which begat the A350XWB.
However, even there Airbus made a mistake by going with only 9-abreast at minimal extra comfort then the 787. If Airbus had launched a true 10-abreast plane, they would have stopped the 787 cold at the 787-9 or 787-10LGW and forced Boeing to launch Y3 because even a refreshed 777 would gain no traction from having extra seating. We might now be seeing two or even three times as many A350XWB sales now as airlines rushed to it to eventually replace their A340/777 fleets. Mind you, most customers do fly the 777 in nine-abreast, but some like EK do so in 10 and I would not be surprised one bit if EK did not buy another few score of 777s before their first A350 arrives.
RIX
Thu Nov 22, 2007 8:37 pm
Quoting Rheinbote (Reply 37):
- but they are doing it well, aren't they? Not moving ahead in mid-size twin market, already several years behind competitor in introducing technology leap (not just new type, in which case not being the first might not be bad at all) would lead to losing strong positions on this market.
Quoting Stitch (Reply 39):
- this may be right. Now, 787 can go HGW while 777 can be upgraded with getting additional capacity, hence shifting away from 350 competition. But larger 350 would make both this options (that may work very well together) "not an option"-s at all.
tdscanuck
Thu Nov 22, 2007 10:50 pm
It's true that they're taking some risk by changing industrial setup while retooling the company and going through a currency crunch...but from big risk can come big gains. Although an A320RS would certainly be a huge seller, both Boeing and Airbus have agreed for a long time that there was going to be a huge business in the 767/A330/787/A350 size class and that the profit from that sector is significantly greater than from single-aisles or VLA's. It would have been a very questionable business decision for Airbus to cede the biggest part of the coming market to their competitor.
Tom.
