tommybp251b
TK A330: A Ladder Under The Cockpit?
Sun Nov 25, 2007 9:31 pm
Hi Guys!
What is going on here?
http://www.flugzeugbilder.de/show.php?id=695499
Thanks for help.
Regards Tom
Tom from Cologne
CRJ900
RE: TK A330: A Ladder Under The Cockpit?
Sun Nov 25, 2007 9:37 pm
Access to forward avionics bay, perhaps?
Come, fly the prevailing winds with me
jetset7e7
Sun Nov 25, 2007 9:40 pm
They will be engineering ladders, it may of have a technical fault after push back, and the engineer will be accessing the avionics bay, to try and correct the problem, i've seen it done before on an Air Atlanta 747.
Retrofitted Blended Winglets - The Future Is On The Wing
474218
Sun Nov 25, 2007 9:52 pm
There is an access panel under the flight station that leads to the forward avionics compartment. There is also a door in the flight station floor that also provides access to the same compartment. It appears that there was a technical problem that showed up after pushback and a mechanic is trying to rectify it.
pilotboi
Sun Nov 25, 2007 11:17 pm
Is that ladder built into the aircraft? If so, how is it accessed? In other words, how do you control the opening of the door and lowering of the ladder if you can't exactly reach it?
474218
Sun Nov 25, 2007 11:33 pm
Quoting Pilotboi (Reply 4):
The ladder is not part of the aircraft. The door can be opened from the inside or the outside. The door is clearly visible in the attached photo (enlarge for better detail).
Photo © JZ
LAXintl
Mon Nov 26, 2007 12:39 am
The ladder IS part of the avionics bay.
See this photo for a close up of the deployed ladder.
http://www.flickr.com/photos/360photography/1610258827/
Now... back to the THY picture.
The gentleman you see climbing up the ladder is a flight mechanic. TK regularly assigns such mechanics to ride with the aircraft to stations that are not normally set up to handle the equipment type. So after this A330 pushback he climbs in the avionics bay and then into the cockpit for a ride home.
jetmech
Mon Nov 26, 2007 1:03 am
Quoting 474218 (Reply 5):
On the A330 / A340, the ladder is part of the aircraft. It collapses into multiple sections to stow above the door. The 747 avionics access door is immediately behind the nose-wheel, it also has a ladder that stows aboard the aircraft.
Regards, JetMech
hloutweg
Mon Nov 26, 2007 1:52 am
Similar avionics bay entries can be found on this Airbus widebody:
Photo © Jackson Qiu
Photo © Willem Honders
The door can be found only on the left side of the aircraft right next to the nose landing gear bay doors.
Click on this link to view a cutaway of the A380 and notice the tiny ladder next to the scaled image of a man right below the nose
[Edited 2007-11-25 17:58:01]
In Varietate Concordia
474218
Mon Nov 26, 2007 4:12 am
Quoting LAXintl (Reply 6):
I learn something everyday.
pilotboi
Tue Nov 27, 2007 5:04 am
Why do I find this hard to believe? I'm not saying your wrong - but if he was really non-reving somewhere, why didn't he just bored on the jetway like everyone else? Even if he's an employee, he can't just jump on board and go - he needs to at least be added to the manifest and such.
Quoting JetMech (Reply 7):
So how does one open/close the door and lower/raise the ladder from the ground? I imagine there is some control panel on the nose gear. Or maybe a control in the cockpit?
LAXintl
Tue Nov 27, 2007 5:09 am
Quoting Pilotboi (Reply 10):
He's on the headset supervising the push back and engine start.....
He's considered part of the operating crew
BreninTW
Tue Nov 27, 2007 5:13 am
The way I understand it is that he's not non-revving, but is actually part of the flight crew. He does his thing outside the plane during pushback, then hops into the cockpit via the avionics bay prior to take-off. Thus he is on the manifest etc.
This only happens when the station is not one that has the flight/aircraft type scheduled.
Ceph
Tue Nov 27, 2007 5:50 am
Interesting... Just learn about this... Never knew about it till now.
Airbus_A340
Tue Nov 27, 2007 8:55 am
We removed those collapsible stairs on the Airbus fleet recently in Cathay as a weight saving measure because we never use them.
People. They make an airline. www.cathaypacific.com
pilotaydin
Tue Nov 27, 2007 10:43 am
LAX is right, as a TK pilot i can tell you that's correct....we serve stations that have no MX facilities such as SIP or ODS, and a MX guy has to ride along with, he is part of the dry operating weight, once we declare pantry and crew, he is added into the load sheet, it's really simple, nothing there to have trouble believing....
The only time there is too much fuel onboard, is when you're on fire!
jetmech
Tue Nov 27, 2007 6:34 pm
The ladder actually stows in a bracket mechanism which keeps it clear of the door. The ladder is manually deployed.
Quoting Airbus_A340 (Reply 14):
Makes sense, as you need a separate stand to access the avionics hatch from the outside in the first place, which negates the need for the ladder. Accessing the avionics bay from the cockpit does not require the ladder. On the 747, you can actually climb onto the nose gear to open and close the hatch, and deploy and stow the ladder. Most of the time we never bothered with the ladder and just pulled ourselves up unto the avionics bay manually.
Regards, JetMech
Door5Right
Tue Nov 27, 2007 9:06 pm
Goodness, I never knew any of this! Most fascinating.
My soul is in the sky...
jetmech
Tue Nov 27, 2007 9:11 pm
Quoting Door5right (Reply 17):
On the 747, there is also another hatch located on the lowest part of the fuselage just before where the wing to body fairing starts. When you open it, you are looking into the forward cargo bay. There is a small amount of electronic equipment inside as well as power outlets. We used to use the power outlets to supply power to our borescope equipment when we did borescope inspections at the terminal.
Regards, JetMech
[Edited 2007-11-27 13:16:20]
breiz
Tue Nov 27, 2007 10:50 pm
Quoting JetMech (Reply 16):
JetMech, I still do not catch how the ladder is deployed manually from the ground. The door is out of reach.
It looks like that you have to access from inside, open the door, release the ladder... and then go out and climb the ladder to reach the position where you were already minutes before....???
DaBuzzard
Tue Nov 27, 2007 11:21 pm
Hmmm, if the flight crew don't open the trap door, does the poor sob have to ride in the hell hole all the way home?
 Silly
pilotboi
Wed Nov 28, 2007 12:20 am
Quoting Breiz (Reply 19):
I don't get that either. And I've asked it twice already and still can't get the answer I'm looking for, lol. If the ladder is in the aircraft, one can not reach the door to open it manually...so there must be some remote control for it, either on the nose gear strut or in the cockpit.
BreninTW
Wed Nov 28, 2007 12:41 am
Quoting Pilotboi (Reply 21):
I think the answer is right here:
Doesn't make an awful lot of sense to have the ladder if you need an extra stand to access the door.
However, in the way that TK uses the ladder, it makes a lot of sense -- the pilot/FO pops down to the avionics hatch, opens the door and the FE climbs aboard -- it's probably all part of a checklist. Your T/O checklist is already being delayed while you wait for the FE to get into the cockpit, so it's no big deal.
jetmech
Wed Nov 28, 2007 3:06 am
I think the idea behind the ladder is that someone accesses the avionics bay from inside the aircraft first. They can then open the hatch from the inside, and manually deploy the ladder. Other people from the outside of the aircraft can then climb up into the avionics bay.
Regards, JetMech
QANTAS077
Wed Nov 28, 2007 3:10 am
Photo © Montague Smith-WorldWide Aviation Photos
shot one here in Perth myself...
BlueSkys
Wed Nov 28, 2007 3:33 am
Does anyone have a picture inside the avionics bay inside a widebody?
dc10hound
Wed Nov 28, 2007 1:17 pm
Quoting JetMech (Reply 23):
That is absolutely correct!
But the excercise of deploying that thing can be ridiculous. They jam, they stick, and generally are an enormous pain. The ladders on AA A300s were removed years ago, mainly to save weight, but also due to the non-functionality of that critter...
"Eagles soar. But weasels never get sucked into jet intakes.."
breiz
Wed Nov 28, 2007 1:48 pm
Quoting Dc10hound (Reply 26):
Now it make sense (well, maybe not the ladder in the first place Smile). Thanks a lot to both of you.
Gr8Circle
Wed Nov 28, 2007 2:32 pm
Can anyone post a picture of these access doors on the 747 please....? Thanks  smile
Wed Nov 28, 2007 4:06 pm
They were taken out about 5 years ago during SARS as a weight saving measure, not recently.
Airbus_A340
Wed Nov 28, 2007 4:25 pm
Quoting Zeke (Reply 29):
Must have been an old iSuggest that I read then, i was in Year 12 5 years ago!
