hamad
Cool Video About Ditching Procedures On You Tube.
Tue Nov 27, 2007 9:19 pm
i was searching on you tube, and i found this video. i always thought that the arming procedures were the same .. but apparantly they are different
PHX - i miss spotting
edina
RE: Cool Video About Ditching Procedures On You Tube.
Tue Nov 27, 2007 10:33 pm
I'm guessing the slide rafts are only fitted as an option - I've worked on A32x aircraft for 2 airlines (IT & BA), both early & late series & they have all been fitted with regular slides. I would have thought they are standard on the CJ models.
Worked on - Caravelle Mercure A300 A320 F27 SD3-60 BAe146 747-100/200/400 DC10-30 767 777 737-400 757 A319 A321
EWRCabincrew
Tue Nov 27, 2007 10:41 pm
This video is almost as exciting as the slide relocation video for the 747/DC-10. There is no way possible to make these interesting.  yawn
You can't cure stupid
skytony
Tue Nov 27, 2007 10:42 pm
This is a video explaining a slide raft move procedure in the event you have to use a slide from an unusable exit to a usable one.
Lower your expectations! You will always be pleasantly surprised!
usflyer msp
Wed Nov 28, 2007 12:10 am
I highly doubt that if your plane ditches you are gonna have time to do all that work or be in a state of mind to remember all of those intricate steps.
hamad
Wed Nov 28, 2007 6:08 pm
Quoting USFlyer MSP (Reply 4):
i think they do that before the plane ditches if it was planned  Smile
PYP757
Wed Nov 28, 2007 6:15 pm
Quoting Edina (Reply 1):
That's right. Add to that that the inside of the plane might be dark (like in that Transat plane that nearly had to ditch in the Atlantic by night), and with 200+ screaming passengers behind, I cannot see how such a detailled procedure can be followed either. My guess is everyone jumps in the water, and forget about the rafts and the survival kits!
hamad
Wed Nov 28, 2007 6:33 pm
Quoting EWRCabincrew (Reply 2):
now where can i find that video, would love to see it
EWRCabincrew
Wed Nov 28, 2007 6:38 pm
Quoting PYP757 (Reply 6):
The sceaming idiots would.
