KPDX
AS Flt.707 PHX-PDX On Flightaware
Wed Nov 28, 2007 2:50 am
Howdy guys. Just a simple question.
My sister is en route right now PHX-PDX in a AS MD-83, and they are over Nevada, but only flying at FL240 for a cruising alt, and going fairly slow compared to the intended speed.
Why are they flying so low?
http://i30.photobucket.com/albums/c326/KPDX/sophielflightphxpdx.jpg
KPDX
[Edited 2007-11-27 18:51:44]
View my aviation videos on Youtube by searching for zildjiandrummr12
futurecaptain
RE: AS Flt.707 PHX-PDX On Flightaware
Wed Nov 28, 2007 2:55 am
Looks like they may be trying to avoid some severe turbulence.
http://adds.aviationweather.gov/turbulence/
Click on the top left map for a close up.
[Edited 2007-11-27 18:57:32]
as739x
Wed Nov 28, 2007 4:34 am
Actually at FL240 it looks like it may have a 1 of the 2 packs inop. I can check the MEL board tomorrow. But I am not throwing away Futurecap's explanation. This morning I sent a few plane out on flight plan at multiple altitudes due to turbulence.
ASSFO
KELPkid
Wed Nov 28, 2007 4:42 am
Quoting KPDX (Thread starter):
Could also be the altitude with the most favorable winds aloft (sorry, no current medical, so I can't check DUATS for you  Sad ).
futurecaptain
Wed Nov 28, 2007 5:33 am
Quoting KELPkid (Reply 3):
You still have this...
http://adds.aviationweather.gov/winds/
Link near the top for official textual winds aloft.
And they appear to generally be out of the West / North West for most high altitudes.
Quoting AS739X (Reply 2):
Check tomorrow to put this to rest.  Smile
AlexPorter
Wed Nov 28, 2007 5:43 am
Every so often a flight does this, like stays down around 250 or something like that. Usually it's turbulence or winds, but as mentioned it could be some sort of mechanical restriction.
Last Flight: SCX701 MSP-PHX B738 8Jan2008
KPDX
Wed Nov 28, 2007 6:14 am
What does that mean?
as739x
Wed Nov 28, 2007 3:15 pm
Quoting Futurecaptain (Reply 1):
Unless the "Pack" was fixed over night before I checked the a/c it was probably a weather related flightplan. So your probably correct that is was due to turbulence avoidance.
Quoting KPDX (Reply 6):
Airplanes have 2 "Packs" which are air cycle mechanisms that converts bleed air from the engines to help provide pressurization to the airplane cabin. If 1 of the 2 are not working, the plane has to stay at 24,000 or 25,000 feet in case it loses the second "Pack". From that altitude it can make it to a safe altitude (quick decent) in the time frame provided by the FAA.
ASSFO
HAL
Wed Nov 28, 2007 9:31 pm
I flew in to PHX from HNL last night, and there was extensive moderate to occasionally severe turbulence all over the southwest US from FL250 up. I'm not surprised they filed as 240 because of that. Yes, if they had a pack inop they would do the same, but last night was a rough one and I'm sure it was because of the bumps.
HAL
One smooth landing is skill. Two in a row is luck. Three in a row and someone is lying.
