COEWRNJ
Virgin Blue A/C Question.
Fri Nov 30, 2007 2:54 am
I am going to Australia next month and will be flying DJ within Australia. When I booked the tickets it did not say the a/c type. I know they fly the 73G, 738 and E170 but I wanted to know if there is a way to find out ahead of time which a/c is normally used for specific flights.
I will be on the following flights.
SYD-MEL-DJ830 on 1/5/08
MEL-SYD-DJ841 on 1/9/08
SYD-CNS-DJ391 on 1/9/08
CNS-BNE-DJ774 on 1/13/08
If anyone has any info, i would greatly appreciate it.
AFGMEL
RE: Virgin Blue A/C Question.
Fri Nov 30, 2007 3:14 am
Hmm, dunno. From experience, 738 most likely on your routes.
B 727-44/200 732/3/4/8/9 767-3 742/3/4, 772/3, A319/20/21 332/333 342/3 , DC3/4/10, F28/50/100, ATR72
aussie_
Fri Nov 30, 2007 3:31 am
all 737s I suspect. There's no real way of working out whether they are -700s or -800s - they are used interchangeably, though there are more -800s in their fleet these days
Pity you didn't book one flight earlier on CNS-BNE on 13/1 as that is E170 operated
dj738
Fri Nov 30, 2007 3:47 am
Quoting Aussie_ (Reply 2):
73Gs and 73Hs are specifically assigned to certain flights, and you can identify this quite easily via the VirginBlue website. HOWEVER, I have just checked the website and it looks like they're experiencing some problem as ALL flights EVERYWHERE are currently showing as 737-700s...! I will check back later.
Yes, sometimes due to scheduling and other requirements, you might find your aircraft substituted between 737-700 / 800, but generally speaking most flights remain as planned.
jetsetter629
Fri Nov 30, 2007 4:45 am
I was wondering this as well if there is a way to see which aircrafts were assigned to routes. This coming May (I know...I'm already booked on DJ flights for May 08) I'll be flying SYD-BNK and BNE-PPP. My assumption is that these are "thinner" routes and warrant a 73G.
Rob
b773
Fri Nov 30, 2007 7:56 am
Checked with a friend, at this stage the 1st 2 flights are 800's, and the 2nd 2 flights are 700's. Hope you have fun in OZ. You may even score a trip on the unusual Blue coloured 700!
Photo © Alexander Watts
Longitude
Fri Nov 30, 2007 10:51 am
When I last was in Australia they were only red ones, what made them to produce a blue one? Smile
PlunaCRJ
Fri Nov 30, 2007 10:57 am
Quoting Longitude (Reply 6):
Their 50th aircraft had to e a "true blue plane".
In my experience, the E 170 is mainly used on Qld flights out of BNE. I am not sure of this though.
COEWRNJ
Fri Nov 30, 2007 3:28 pm
Thanks for the help. How does the seating work on DJ? Is it assigned at the airport or is it a free for all like WN?
PlunaCRJ
Fri Nov 30, 2007 5:05 pm
Quoting COEWRNJ (Reply 8):
It´s assigned.
b773
Sat Dec 01, 2007 2:56 am
You can also checkin online, which opens 24hours before departure. That's a great option to try and secure a window or aisle seat.
