FlyBoy84
Flying The Friendly Skies!
Mon Dec 03, 2007 11:55 pm
I'm flying to ORD this month on  Wow! (of ALL things) UAx. I have some questions that I hope someone can answer:
Why is there only one mainline flight from ORD to STL, but none from STL to ORD?
And...
I know some UAx flights arrive/depart from the C concourse, but from checking the flight status it appears that my flight will arrive at E/F. Will I have to go to T1 for bag claim, or will it be in T2? If I was flying UAx from ORD through E/F, which terminal would I go to for check-in?
Thanks in advance a-netters!
KDCA
RE: Flying The Friendly Skies!
Tue Dec 04, 2007 12:45 am
All UA check-in and bag check is in Terminal 1 at ORD.
Viscount724
Wed Dec 05, 2007 2:24 am
Quoting FlyBoy84 (Thread starter):
Looks like the ORD-STL UA mainline flight then operates STL-DEN. On that sector they have 3 mainline flights STL-DEN but only 2 DEN-STL, so the extra one must be the one mainline flight ORD-STL. Assume it reflects demand at those times of the day, or other aircraft routing issues.
SkyexRamper
Wed Dec 05, 2007 8:29 pm
Because Trans States ala GoJets serves STL to and from ORD, and STL is TSA's home base.
Good Luck to all Skyway Pilots! It's been great working with you!
