flyf15
Airports Physically Connected To Each Other
Sat Dec 08, 2007 4:24 am
How many airports out there are physically connected (ie: can taxi an aircraft from one to the other) out there? I didn't know they even existed, but here is an example...
Photo © Willson Moss
To the right side of the ditch is one airport (8NC9) with a grass runway and to the left side of the ditch is another separate airport (0A7) with a grass/paved runway. There is a taxiway bridge that aircraft can taxi across to get from one to the other. Both are completely separate airports as considered by the FAA.
Anything else out there like this? Two airports (with two identifiers/names/etc) but connected? I know there are many cases of airports that are really two separate operations, maybe a military base/runway and civilian side/runway that are connected... but they're still just considered one airport.
co777er
RE: Airports Physically Connected To Each Other
Sat Dec 08, 2007 4:56 am
ELP and Biggs AFB? (aka Ft. Bliss)
PITrules
Sat Dec 08, 2007 5:01 am
I'm not 100% sure, but I believe the land area of DEN and Front Range airport border each other. The final build-out of DEN might have had a planned connection to Front Range.
Also, the new Doha airport will be next to the old one, although not connected. If the new Doha airport ever needs a third runway, they could make a link to the existing airport, whose runway will be parallel to the ones at the new airport. It would be a bit of a taxi, but not any worse than the outer runway at DFW or DEN.
ANC and Lake Hood seaplane base.
FLYi
HA_DC9
Sat Dec 08, 2007 5:07 am
HNL and Hickam AFB are connected. They share the same runways.
Photo © HGabor
Photo © M.J. Scanlon Photography
[Edited 2007-12-07 21:11:16]
futurecaptain
Sat Dec 08, 2007 5:46 am
These places would make for some interesting logbook entries. Easy XC time for sure.
ShyFlyer
Sat Dec 08, 2007 6:02 am
NAS Whiting Field North - KNSE
http://204.108.4.16/d-tpp/0712/00602AD.PDF
NAS Whiting Field South - KNDZ
http://204.108.4.16/d-tpp/0712/01909AD.PDF
by Taxiway Zulu
xtoler
Sat Dec 08, 2007 6:30 am
Can't forget FRF/FRA. Frankfurt Flughafen and Rhein-Main AB were adjacent. Aalborg and the Danish Air Base are right next to each other. If I could remember the codes, Wichita Falls Municipal and Sheppard AFB are together. Scott AFB and Mid America airport are somewhat together. Damn, guy, I can't think of two GA or GA/civil airports connected. Usually where there is one, another may be there.
Off subject, are there still Navy C-9's at AVP? Why I though about there I don't know, maybe it was becasue I was watching The Office, which takes place in Scranton, PA and I keep telling my wife about my overnights at AVP.
EMB145 F/A, F/E, J41 F/A, F/E, because my wife clipped my wings, armchair captain
PanHAM
Sat Dec 08, 2007 7:07 am
Quoting Xtoler (Reply 6):
I am part of a group called "Pro Airport" and sometimes we have a stand on local fairs, to explain the airport expansion. A frequently asked question is "Why can't you use the runway of the Americans?"
Answer - they never had one. Frankfurt Airport and Rhein-Main Airbase where the same place, no separation at all. Military planes used all three runways and the only separation was, that there was a civil and a military ramp. Same as with any US airport that homes a National Guard unit.
TGhe one in Denmark is Billund, BTW, but I believe that the military airport mirroring Billund is closed.
Was Erlauben Erdogan!!!
flyf15
Sat Dec 08, 2007 8:13 am
Quoting ShyFlyer (Reply 5):
by Taxiway Zulu
Wow, very cool, and a perfect example of what I was looking for! Thanks!
COSPN
Sat Dec 08, 2007 8:55 am
Sapporo Japan: Chitose Airport and Japan Self Defense base... same location RJCJ and RJCC
slz396
Sat Dec 08, 2007 9:10 am
Same at BRU.
Landing on 25R and turning off left, you are on the civil side at Brussels Airport EBBR; turn off right and you go to he military airport called Melsbroek EBML.
Photo © Serge Bailleul - AirTeamImages
Reading through the replies above, it seems most cases are a combined civil/military use of the same runways, with the civil airport being on one side, and the military airport on the other side. I wonder why a military airport has an ICAO letter code though...
[Edited 2007-12-08 01:15:25]
davescj
Sat Dec 08, 2007 9:50 am
Quoting CO777ER (Reply 1):
I believe you are correct.
Dave
PanHAM
Sat Dec 08, 2007 12:32 pm
Quoting Davescj (Reply 11):
could be done, but isn't
http://maps.google.com/maps?ll=31.84...q=31.849500%2C-106.380000%20(KBIF)
EDICHC
Sat Dec 08, 2007 12:57 pm
Quoting Slz396 (Reply 10):
For emergency use by civil aircraft. Even if the military airport shares the same runway facility as a civil airport there may be local or national reasons differentiating betwen the two.
A300/319/320/346 ATR72 B722/732/3/4/5/6/8/742/4/752/762/3/772/3 BAC111 BAe146 C172 DHC1/6/8 HS121 MD80 PA28
rfields5421
Sat Dec 08, 2007 1:52 pm
I think RJCJ / RJCC is the only true case of a large facility - at least I've that found.
Here's an opposite side of the question - how any airports have two, or more, runways physically separate and unable to taxi to each other. Not counting the construction of the third runway at WSSS.
RJFU - Nagasaki Japan - the original airport runway is on the shoreline and the new commercial runway is on a man made island about a mile away.
Qatara340
Sat Dec 08, 2007 2:42 pm
Quoting PITrules (Reply 2):
Hiii there!
I worked in the New Doha Airport, which is being built 4 kilometers east of the exisiting airport. Its really close to the new airport, but the new airport is designed for the next 60 years, so the need for a third runway is not important. In fact 2 runways is MORE than enough for the new DOH.
The new airport will be developed by a major real estate player into a canal, villas, shopping areas, and financial zones. So, the old airport will be a residential area.
But, I agree, the airports will be close to be each other, and it could form one huge airport, but that is not part of the plan.
Regards.
لا اله الا الله محمد رسول الله
BlueElephant
Sat Dec 08, 2007 2:50 pm
Mid America and Scott AFB are connected by a Single Taxiway...Pretty Cool Actually.
http://maps.google.com/maps?f=q&hl=e...5&spn=0.06391,0.1157&t=h&z=13&om=1
rampart
Sat Dec 08, 2007 7:41 pm
Quoting BlueElephant (Reply 16):
I could be wrong, but I think that parallel runway existed as part of Scott AFB prior to Mid America opening. In my mind, it doesn't qualify as the "two separate airports", but simply one side of the same airport being civilian, the other military, like many other examples. I'm open to correction, though.
-Rampart
KELPkid
Sat Dec 08, 2007 7:43 pm
Not yet...although the city of El Paso and Ft. Bliss have been discussing this for years. It would require the construction of one taxiway.
EDIT: By The Way, it has been Biggs Army Airfield since the early 1970's, and the station identifier is BIF  Smile
[Edited 2007-12-08 11:45:42]
KELPkid
Sat Dec 08, 2007 7:47 pm
Also, ABQ and Kirtland AFB use the same runways and control tower...
elmothehobo
Sat Dec 08, 2007 7:55 pm
Though no longer operational, Bolling Air Force Base and Anacostia Naval Air Station in the District of Columbia had their own runways, hangars, control towers; and were connected by a taxiway.
YYZatcboy
Sat Dec 08, 2007 8:17 pm
Technically (IIRC) YYZ is two separate airports. YYZ (South Side) and YZY (North). Each has their own ground/Tower/APP-DEP controls. This way they can get around having the runways slightly too close to each other, and operate multiple Approaches and Departures on both sets of runways.
DH1/3/4 MD11/88 L1011 A319/20/21/30/80 717 727 735/6/7/8/9 744 762/3 77E/W E40/75/90 CRJ/700/705 CC150
J/S DH8D 736/7/8
jetmatt777
Crew
Sat Dec 08, 2007 8:38 pm
Quoting YYZatcboy (Reply 21):
Many airports do that. It's more of seperating out the load on the ATC to separate controllers at the same station [Ground, Tower, etc.]
ATL has a different Tower frequency for each runway, and a North and South Ground controller, plus different ramp frequencies.
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
phatfarmlines
Sat Dec 08, 2007 8:57 pm
MIA were two separate airports once upon a time. The 36th street terminal and the air base next to it were merged after the conclusion of WWII.
Addendum:
On this topic, was one of LAX's master plan configurations was to send a taxiway to Hawthorne Field?
[Edited 2007-12-08 12:58:59]
wdleiser
Sat Dec 08, 2007 9:05 pm
These are all on the same airport grounds though. Rhein Mein AFB used FRA's codes. If you flew to Rhein/Mein you were landing at Frankfurt EDDF and taxiied over to the base. What the original poster ment I believe is... theres a fence between FRA and Rhein Mein, Rhein Mein has its own airport code ex: ERMA or some other identifier and had its own runways then theres a taxiway that connects the two airports.
Rhein Mein still used FRA's codes and runways it was just on the opposite side of the airport similar to having cargo operations located at a different part of an airport.
stburke
Sat Dec 08, 2007 9:36 pm
There's about ~5 miles in between the two, that would be quite a taxiway. I also saw nothing about it after digging through some old books. Front Range did, however, make an extremely competitive effort in taking away air cargo operators from DEN. Last minute changes to DIA prevented that.
qslinger
Sat Dec 08, 2007 9:54 pm
What about BOM...Sahar (Chatrapathi Shivaji International) and Santa Cruz(Domestic)? Do they qualify as airports next to each other?
Raj Koona
DeltaAVL
Sat Dec 08, 2007 11:42 pm
Nice thread! Especially considering that this is my local airport (5 minutes from home) and that I took that picture!  Wink
Quoting Flyf15 (Thread starter):
Yep, and both airports are basically run by the same group of people. 8NC9 doesn't get much use compared to 0A7, and for obvious reasons.
Another interesting aside - the grass beside the paved runway at 0A7 is sometimes used as a grass runway. It's not identified or registered as one, but aircraft sometimes use it as one.
"We break, We bend, With hand in hand, When hope is gone, Just hang on." -Guster
FlyMeToTheMoon
Sun Dec 09, 2007 12:28 am
Land at IAD on 1R. Take 267 W then 66E then the GWP and you end up at DCA on runway 15 ready for takeoff
Fly me to the moon... but not through LHR!
xtoler
Sun Dec 09, 2007 1:02 am
Quoting PanHAM (Reply 12):
Oh, forgot about that one and my best friend is still stationed at Ft. Bliss. I thought she was out of her mind when she said Buff's were going in and out of there. Her husband confirmed it for me.
malaysia
Sun Dec 09, 2007 1:11 am
Chiang Kai-Shek International and Taoyuan AFB is another example too.
I also wondered about segregated airports, single airport, but literally seperated runway areas, aprons, and operational area. such as OAK, which is connected by a taxiway from North to South Field.
There Are Those Who Believe That There May Yet Be Other Airlines Who Even Now Fight To Survive Beyond The Heavens
Mike89406
Sun Dec 09, 2007 1:16 am
MSP and RNO are connected to Air National Guard Bases.
xtoler
Sun Dec 09, 2007 1:25 am
[quote=PanHAM,reply=7]I am part of a group called "Pro Airport" and sometimes we have a stand on local fairs, to explain the airport expansion. A frequently asked question is "Why can't you use the runway of the Americans?"
Answer - they never had one. Frankfurt Airport and Rhein-Main Airbase where the same place, no separation at all. Military planes used all three runways and the only separation was, that there was a civil and a military ramp. Same as with any US airport that homes a National Guard unit.[/quote
When did you start this? I guess I should have paid more attention to the vendors than the beer and wine tents. I left Germany in November of '98, but if ya'll have a web site, PM me. Maybe I can get started out here with better usage of airfields.
If Troy from RIC is reading this, please give me some feedback.
rampart
Sun Dec 09, 2007 2:41 am
Quoting Phatfarmlines (Reply 23):
Addendum:
Yes, I remember that. I saw an article in AW&ST years ago, it was one of the options. Was not favored by the GA users at Hawthorne nor the commuter airlines that were going to be shunted there from LAX.
-Rampart
