CHRISBA777ER
Spotter Tip - A330 Engines
Wed Dec 12, 2007 2:25 pm
Hullo,
I've struggled to tell the difference for a long time between the different engines on the A330.
The Rolls ones are obvious, but how do you tell between the CF6 and the PW? Are there different variants that look different, or is it just a case of remembering who has what?
Rgds,
CM
What do you mean you dont have any bourbon? Do you know how far it is to Houston? What kind of airline is this???
jetmech
RE: Spotter Tip - A330 Engines
Wed Dec 12, 2007 2:37 pm
The CF-6 has a long, sharp cone coming out of the exhaust;
Photo © Mathias Krewedl
The PW has a "blunt" exhaust section;
Photo © JKSC
Regards, JetMech
steman
Wed Dec 12, 2007 2:38 pm
CF6-80 are easy to spot ´cause they have a cone protruding from the nozzle
while all the PW (apart from those installed on the 777) don´t.
Just check PWs equipped A330 like Korean Air, MD11s like JAL or Swiss
and compare with GE powered A330 like Air France and MD11 like KLM
Ciao
Stefano
Transpac787
Wed Dec 12, 2007 2:40 pm
Quoting CHRISBA777ER (Thread starter):
Often, this is the best way. I personally have even more trouble with telling apart the CF6 and PW on the 747-400's. Anyhow...
Photo © Ralph Duenas - Jetwash Images
Photo © Philippe Jeandy
NWA, now with the largest A330 fleet in the world, has been a long-time PW customer, and has the PW4168A on all their A330's. AF has always been a die-hard GE customer, and has the CF6 on their 330's.
The best dead-giveaway I can offer, is the aft part of the engine. The CV6 has that huge spike thing (is it obvious I'm not an engineer?!?), while the PW does not. Unfortunately I don't really know how to explain it any better than that, haha.....so hopefully the pictures speak for themselves.
Transpac787
Wed Dec 12, 2007 2:41 pm
Damn!! You guys beat me to it!!
albird87
Wed Dec 12, 2007 2:44 pm
Is there a reason why then RR makes there engines exaushts so different?? I know they look cool but is there an actual advantage to the shapes of the RRs??
steman
Wed Dec 12, 2007 2:46 pm
On the Boeing 747 and 767 it is actually more difficult to tell them apart since
both GE and PW looks very similar (with no cone in the exhaust)
Is it true that NW has the biggest A330 fleet in the world?
How many do they have?
How does it compare with the likes of CX and EK?
Ciao
Stefano
Transpac787
Wed Dec 12, 2007 2:53 pm
Also, if you happen to know the model number ahead of time, that's how Airbus designates their planes. Boeing assigns model numbers based on the ordering customer, but Airbus assigns model numbers based on aircraft series, and then engine type.
-202 = CF6-80E1A4
-203 = CF6-80E1A3
-223/323 = PW4168A
-243/343 = Trent 772-B60
-301 = CF6-80E1A2
-321 = PW4164
-322 = PW4168
-341 = Trent 768-60
-342 = Trent 772-60
-343 = Trent 772B-60/C-60
Ex- All of the NW A330's are A330-223 or A330-323, as they all are equipped with the PW4168A's.
Quoting Steman (Reply 6):
Is it true that NW has the biggest A330 fleet in the world?How many do they have?How does it compare with the likes of CX and EK?
Yes, they do. There was a thread about it awhile back I'll see if I can't dig it up here. Anyhow, current fleets of your mentioned airlines are:
NWA-
11x A332
21x A333
EK-
29x A332
CX-
29x A333
QR-
20x A332
10x A333
steman
Wed Dec 12, 2007 2:58 pm
Transpac787,
very informing,
thank you
Ciao
Stefano
CHRISBA777ER
Wed Dec 12, 2007 2:59 pm
So there are no pointy cone PWs?
jetmech
Wed Dec 12, 2007 3:35 pm
Quoting CHRISBA777ER (Reply 10):
Not for the A330, but PW installations on the B777 for example, do have pointy exhaust cones;
Photo © Ian Schofield
Regards, JetMech
Transpac787
Wed Dec 12, 2007 3:39 pm
The only PW motors you'll see with the exhaust cones are on the 777. The PW4077 and PW4090 both have them.
Photo © Steve Flint
All other "modern" PW engines do not. PW on UPS MD11:
Photo © Michael Carter
PW4056 on NW 744:
Photo © Je89 W.
PW4060 on UA 763:
Photo © Andres Contador
steman
Wed Dec 12, 2007 4:09 pm
To complicate the things,
GE´s CF6-80 installed on B767 and B747 do not have the pointy cone either.
747fan
Wed Dec 12, 2007 4:55 pm
Here's another comparison involving the Airbus A300-600R:
UPS A306, PW4058
Photo © Mike Paschal
AA A306, CF6-80C2
Photo © Felix Bahamonde - PR Planespotters
Quoting Steman (Reply 13):
That point cone is the exhaust cone. And very good observation...
AA B763ER
Photo © Paul Markman
UA B763ER
Photo © Airsnaps - WorldAirlineImages
I'm usually able to pick out different engines based on their sounds. However, the PW4000 on the A330, A300, 744, and 767 sound nearly identical during takeoff to the CF6-80 series - the fan growl is ever so slightly different; sometimes I can barely tell the difference, but usually I can't. They do sound a little different when landing, so its easier to tell which engine when spotting approaches. On the other hand, all 3 777 engines are easy to tell apart.
PlunaCRJ
Wed Dec 12, 2007 5:08 pm
Quoting Albird87 (Reply 5):
Interesting question, I would like to hear the answer.
Sketty222
Wed Dec 12, 2007 5:12 pm
Sorry for being dim here but what does the RR engine look like compared to the other two? Does it have a pointy cone exhaust bit?
Lee
PenPusher
Wed Dec 12, 2007 5:39 pm
Hi All
The correct name for the Pointy thing on the CF6 Engines is an AFT Centerbody, I will not bore you with the part number, don't want to be seen as a complete Geek !!
Transpac787
Wed Dec 12, 2007 6:21 pm
Quoting 747fan (Reply 14):
UPS A306, PW4058
They're actually PW4158's. Pratt & Whitney has specific designations between aircraft types for engines. The first number designates the series.....2XXX, 4XXX, etc. The second number designates whether it is an Airbus or Boeing engine. Boeing is 0, Airbus is 1. The final two numbers designate the thrust-rating. Examples:
PW2037: 2000 series engine, for Boeing, 37k thrust rate
PW4168: 4000 series engine, for Airbus, 68k thrust rate
So, it would be "impossible" to have a PW4058 on an Airbus, it would have to be a PW4158.
Quoting Sketty222 (Reply 16):
Photo © Hans Schulze
I personally find the RR motors on the A330 to be horrifically ugly, and the PW and GE engines look far better. IMO, the Trent 892 and 895 look far better, the RR's on the 777, despite having the smallest fan diameter offered on the 777.
Photo © Jonathan Derden - Spot This!
raggi
Wed Dec 12, 2007 6:32 pm
Quoting Transpac787 (Reply 18):
Correct, and if it's a MD, the number 4. Hence the PW 4462 on the MD-11 for instance.
raggi
Stick & Rudder
jacobin777
Wed Dec 12, 2007 6:42 pm
Quoting PenPusher (Reply 17):
Hi All
..nothing wrong with being a "geek" here...we already have a few of them and they are highly regarded and respected. Wink
The more information which can be provided the more we learn and appreciate.. Smile
"Up the Irons!"
flipdewaf
Wed Dec 12, 2007 7:20 pm
I asked my lecturer and he said it was mainly due to helping with reducing noise and directing flow better.
Fred
phollingsworth
Wed Dec 12, 2007 8:02 pm
Quoting Raggi (Reply 18):
GE does something similar on several of their engines for instance the CF6-80C2s if the 2 is followed by a B it is for Boeing, A for Airbus, D for McD. I am not sure what K is for. The GE90 is the same but there are only B models. Also on the CF6-80C2 if you see and F, e.g. B8F it is a FADEC engine
A342
Wed Dec 12, 2007 8:21 pm
Well, actually many RR engines have pointed exhausts, e.g. the Trent 500, 800, 900 and 1000. Among the RR high-bypass engines, only the Trent 700 and the RB.211-535E series as well as the RB.211-524G/H series have a "mixer nozzle". Correct me if I'm wrong!
Quoting Transpac787 (Reply 7):
To simplify this a bit, here are all the engine codes in the Airbus model designator A3xx-x_x:
0 = GE
1 = CFM
2 = P&W
3 = IAE
4 = RR
6 = EA (Engine Alliance)
Does anybody know why 5 is unoccupied? The best explanation I can come up with: 5 is used for Europrop International, the engine provider for the A400M.
And if it's an Ilyushin, the number 3 is used, e.g. the PW2337 on the IL-96M.
Exceptions confirm the rule.
fruitbat
Wed Dec 12, 2007 11:19 pm
Quoting Transpac787 (Reply 17):
In that case it's fairly certain that Airlines are buying on the basis of operating performance and economics not looks......
....which brings me to the best way of telling them apart......watch as they go overhead.....
RR.....not RR.....RR......not RR.....RR......not RR.......RR...... etc etc
(except in China where it's RR.......RR.......RR.........RR.........RR)
 Big grin  duck
Weaseling out of things is important to learn. It's what separates us from the animals ... except the weasel.
