ual757
Need Help With Plane Ident.
Sun Aug 27, 2000 11:58 pm
I'm trying to figure out what plane I saw recently. It has 4 engines mounted on the rear fueslage, and seemed either german or russian. The 4 engines were doubled in a 2-2 configuration.
TriStar
RE: Need Help With Plane Ident.
Mon Aug 28, 2000 12:11 am
Could be
Click for large version
Photo © Axel Juengerich
I'm not an expert, but this is what a quick search in the A.N database turned up.
I hope it helps, anyway.
TriStar.
b767-400er
Mon Aug 28, 2000 12:22 am
It a russian Il-62. It's a 186 seater long haul aircraft with the engine layout the same as the Vc-10.
Tony,
B767-400er
ual757
Mon Aug 28, 2000 12:29 am
that's the one! thanks! i've been spending the past hour searching the database for it, with no luck...the one I saw was a military one, in camo green, so I was searching there..
ual757
Mon Aug 28, 2000 12:31 am
as a matter of fact, here it is:
Photo © Jorgos Tsambikakis
Trvlr
Mon Aug 28, 2000 9:47 am
That is actually the military version of the British Vickers VC-10. It has been claimed that Ilyushin, the Russian company that manufactures (manufactured?) the Il-62, copied their design from the VC-10. These planes are still in service with the British RAF as fuelers and troop transports, and possibly with a few other (probably commonwealth) nations.
Aaron G.
Continental
Mon Aug 28, 2000 2:40 pm
Did you see the plane at MSP? Cause I saw the same thing at MSP, while taxiing for takeoff in a Sun Country 727.
Continental
