Thai A330
A330-200 & A330-300
Wed Sep 06, 2000 8:05 pm
How could I tell the different between A330-200 and A330-330 ? Might be stupid asking this, but I really don't know. Thanks
Triple Seven
RE: A330-200 & A330-300
Wed Sep 06, 2000 8:26 pm
The A330-200 is several frames shorter than the A330-300. This translate to longer range for the aircraft. I suggest you view photos of the A330-200 (like Canada3000, Air Transat) and compare them to the A330-300 (like that of LTU,MAS,TG). You will notice the differences.
- Triple Seven.
TSV
Thu Sep 07, 2000 5:47 pm
10 (6+4) frames shorter and a broader fin.
"I told you I was ill ..." Spike Milligan
oxygen
Fri Sep 08, 2000 2:37 pm
Pay attention to the distance between the tip of the tail and the root if the rudder. It is shorter on the -200 because of the enlarged tail.
ZRH
Fri Sep 08, 2000 3:26 pm
The A 330-200 is not only shorter is a real long distance airliner which can make Europe-LAX without problems.
WorldTraveller
Fri Sep 08, 2000 4:01 pm
Hope this helps:
A330-300
Click for large version
Photo © Darcy Stevens
A330-200
The A330-200 is just shorter and has a larger tailfin, as already mentioned. The A330-200 also has a smaller exit no. 3.
widebody
Fri Sep 08, 2000 6:26 pm
....just to clarify, the small No. 3 exit is standard on all A330/A340 aircraft, the large exit is an option, which most airlines prefer to take........
