AT
747-200 With Winglets
Fri Sep 15, 2000 5:30 am
I was wondering:
the winglets on the 747-400 are supposed to increase peformance and decrease fuel consumption.
Why don't airlines then adapt their 747 models with winglets too? Is this possible? And would it increase performance on these aircraft?
RE: 747-200 With Winglets
Fri Sep 15, 2000 5:48 am
UA took them off one 744 to compare its performance. Well it made no difference it the performance or fule consuption. Boeing offered to take them off but non of the airlines wanted to as it imakes the 744 reconisable!
Iain
sammyk
Fri Sep 15, 2000 5:54 am
Aviation Partners, the firm that developed the blended winglets for the 737/BBJ is running experiments on the 747-200. Supposedly they are achieving lower fuel burn.
Sammy
Fri Sep 15, 2000 6:20 am
Winglets on B747-400s do account for around a 5% cut in fuel consumption, and also increase MTOW.
In late 1999 British Airways operated G-BNLR for a week without it's port winlet, after it had been damaged but could not immediately be replaced.
Handling minus the winglet was identical, but without winglets induced drag is higher. With the port winlet missing the BA B747-400 suffered a 2.5% increase in fuel consumption, and Max Take off weight had to be reduced by 9.5T.
If the winglets served no purpose, why would airlines fly them around, adding to the weight of their aircraft. Why would Aviation Partners be developing winglets to retrofit onto B747-200s and B737NGs?
Aviation Partners actually have a B747-200 test flying with 4.42m (16ft 6in) winglets at the moment, which are scaled up versions of those they developed for the 737NG/BBJ. On the 747-200 they reduce fuel consumption by 6-7%. The winglets can be retrofitted onto all B747-200/300s and even -400s because the blended winglets are more effective than existing B747-400 winglets
JET SETTER
Fri Sep 15, 2000 6:31 am
Jet Setter from what I heard from a mechanic was that UA took one of for the week and it made no difference. Some winglets work like the Gulfstream 5 ones and the A340 ones but theh 747-400 one is not effecient. If you read my post I said it made no difference so basically it supports its own weight and not do all what Boeing said it does!
Iain
Fri Sep 15, 2000 6:52 am
Points of interest: I hear Aviation Partners and Hexcell are working with a AA737-300 for a winglet retrofit. I believe JAL has 747-400s without winglets for domestic use.
Fri Sep 15, 2000 6:59 am
Yes those are 744D's (domestic)
Isn't KLM at least retrofitting it's classic 747's with glass cockpits? Why not add the winglets in too?
Fri Sep 15, 2000 3:43 pm
Aviation Partners of Seattle has been flight testing 4.3 metre high winglets that promise a 6-7% drag reduction not a 6-7% fuel burn reduction. The aircraft being used is a 747-200 freighter, with unpainted fuselage, and what looks like a solid black tail. I can't see the reg number.
Fri Sep 15, 2000 3:57 pm
IndianGuy
Fri Sep 15, 2000 4:18 pm
Jet Setter: Are u sure about the figures pal?
Removing the winglets reduces MTOW by 9.5t? Thats Unbelievable!
Fri Sep 15, 2000 4:58 pm
I saw a picture of those winglets on the 747-200 in Flight International, I believe. They look huge, compared with the ones on the 744 they stick upright and are very tall.
Fri Sep 15, 2000 9:22 pm
The data is from a Flight International article about British Airways operation of the B747-400 without a winglet, and yes the quoted figures were 2.5% fuel burn penalty and 9.5T MTOW penalty. It is a lot!
AFa340-300E
Blended Winglets
Sat Sep 16, 2000 3:04 am
Hello,
Of course the winglets are of some use. These fitted on the Boeing 747-400s give the advantages reported by Jet Setter. Otherwise they'd have been removed, as they add some weight to the aircraft.
Now, the winglets possibly to be fitted on the Boeing 747 Classics would be more efficient. I'm not sure they would reduce drag more than these of the Boeing 747-400, but as they'll be blended winglets, there'll no longer be any need for major end-wing reinforcement to carry it.
The Boeing 747-400Ds used by JAL and ANA on their domestic networks are not fitted with the winglets because the gain in fuel consumption on such short hauls don't outweigh the extra-weight.
Click for large version
Photo © Søren Geertsen
Alain Mengus
Sat Sep 16, 2000 3:11 am
Nice shot Mr.Mengus, what airline's that??
sammyk
RE: 747-200 With Winglets - Capt.
Sat Sep 16, 2000 4:02 am
Thats a Singapore 744 Winglet. I agree, nice shot.
Sammy
Avilitigator
Sat Sep 16, 2000 4:43 am
Does anyone out there know how the winglets decrease drag and reduce fuel burn? I know this is what we read about, but what are the physics behind winglets?
Do they provide extra lift? If so, what is the advantage of fitting them at an angle or blending them to the regular wing?
I ask this because the 767-400 has the raked wingtips, which essentially look like the winglets on a B744 or A340 except the 767-400s' wingtips aren't angled upwards.
Thanks.
Sat Sep 16, 2000 4:53 am
You guys really do not read the posts do you? As I have said the winglets support themselves but the aircraft is exactly the same without them.
Iain
Navion
Iainhol
Sat Sep 16, 2000 5:07 am
Hi Iainhol. I just wanted to say I believe the United mechanic you refer to is not right. The winglets on the 744 have a very positive effect on long haul flights. I will agree with you the blended winglet is a greater evolution of winglet design and is more efficient, but the 744's winglets are effective. The only reference to flying without them is A) short hauls do not take advantage of winglet performance (except for hot & high airports), and B) if a 744 has to, it can fly without one of it's winglets without an adverse affect in handling.
Starship
Sat Sep 16, 2000 5:30 am
It is a Singapore Airlines B747-412
Behind every "no" is a "yes"
Avilitigator
RE: Iainhol
Sat Sep 16, 2000 5:53 am
Iainhol,
Yes, we do read the posts and there is nothing wrong with us. So far there haven't been any posts providing a scientific explanation regarding the efficiency of winglets. Your posts explaining winglet efficiency were based on secondhand information but if you or anyone else know of any publications or physics manuals on wing designs, that would contribute greatly here.
Sat Sep 16, 2000 6:32 am
I agree winglets work and do a good job, but the 747-400 winglets do not work as well as Boeing had planned. The tests on the UA 747-400 happend quite a while ago, and Boeing did offer to take the winglets off but the airlines kept them as they support themselves the easiest way to tell a 744 is by the winglets! I do not know enough about winglets to figure out all what is going but I will try and get the guy i spoke to come here and tell you guys more about the findings!
Iain
Sat Sep 16, 2000 6:52 am
The way the winglets work is not too hard to understand. At the end of all airplane wings, vortices known as "wingtip vortices" form where low pressure air above the wing draws high pressure air from below the wing up around the end of the wing. Somehow this creates drag. The winglets prevents the formation of wingtip vortices, hence less drag.
Another note about 747 evolution: I read that when Boeing introduced the extended upper deck on the 747-300 (& 400 for that matter), the changed contour of the upper deck allowed cruise speed to increase to Mach .85 from .84 on the 200.
Adria
Sat Sep 16, 2000 6:54 am
The 747-200 is so old that even if they wouldn't need any fule they would be still more expensive to operate
RE: Adria
Sat Sep 16, 2000 7:02 am
"The 747-200 is so old that even if they wouldn't need any fule they would be still more expensive to operate"
It seems that your sentence doesn't make much sense. Putting winglets on any 747 would have good effect.
It doesn't matter if the 747-200 is an old jet! It's still one of the best ones today!
Rgds,
B744
Adria
RE: Boeing 744
Sat Sep 16, 2000 7:12 am
Dream on
Avilitigator
Thanks Saluki777 for the clear and simple explanation that winglets reduce/eliminate wingtip vortices, thereby reducing drag. Do the 767-400 raked wingtips do the same thing, or do you need to angle the winglets like on the 744, A340/330/319 to achieve the reduced drag?
Why doesn't the 777 have winglets, or is the 777's wing design so advanced that wingtip vortices don't form?
Thanks.
Sat Sep 16, 2000 7:13 am
some of them are not that old, the last one was built in 1991.
http://www.boeing.com/commercial/747/evolution.html
RE: Adria
Sat Sep 16, 2000 8:00 am
What's that supposed to mean? You make no sense at all. I was just speculating that a winglet on ANY 747 would be better. It's true, I would love for the 742 to remain in service for a much longer time, especially with UAL, but 20 years from now, I garauntee you that there will still be a few 747-200's in service. VA plans to keep theirs for awhile, right? Look at the DC-9, it will probably still be in service for awhile longer!!
You "Dream On" that the classics will die soon, whatever!
oxygen
RE: Adria
Sat Sep 16, 2000 1:16 pm
I read somewhere that boeing did not put winglets on the 777 in the beginning is because they think that the 777 wing is so efficient that it does not need the winglet to squeese out extra performance.
