voar
A380 Cleared For Service Into GRU
Fri Sep 02, 2011 12:14 am
As per an article in the Folha de São Paulo website, INFRAERO (Brazil's airport operator) has given the green light for Emirates to fly into São Paulo (GRU) with the A380. A condition is the arrival and departure time which INFRAERO would like to be off-peak times due to airport saturation. Emirates was hoping for an 1830 arrival with a 0100 departure time, but INFRAERO want the arrival to be between 1600 and 1630 with a 0200 departure time. Emirates wants to start service with the A380 to São Paulo in december.
reference: http://www1.folha.uol.com.br/mercado...viao-de-passageiros-do-mundo.shtml (In Portuguese)
[Edited 2011-09-01 17:18:54]
lightsaber
RE: A380 Cleared For Service Into GRU
Fri Sep 02, 2011 3:41 am
Allowing the A380 to GRU is a surprise.
Quoting voar (Thread starter):
This isn't that much of a surprise.
Looking at EK's operations at DXB via the exceptional analysis of HB-IWC:
Emirates At DXB - Ultimate Operational Analysis (by HB-IWC Sep 27 2010 in Civil Aviation)
EK could move the departure to GRU up two hours. But the current departure from DXB allows for the entire 4am to 7am bank to feed the DXB-GRU flight. I believe that a departure earlier than 08:20 would start cutting into connecting traffic.
The real issue will be the arrivals back at DXB. The GRU flight is already the last flight in the 3pm to 9pm arrivals bank. But then again, the GRU flight to DXB is really 45 minutes early for the 10pm to 1am arrival bank.
The other issue will be the ground time. 1630 arrival with an 0200 departure is forcing 9.5 hours of ground time versus 6.5 hours. EK has been running the A380s hard (see the same link above). Losing the use of an A388 for 3 more hours per day is a cost that will add up.
I suspect there is further negotiation ahead, but that GRU will have no choice but to set fairly rigid conditions.   I'll be curious to see how the time changes effect the route's economics. I suspect EK will still launch the A380 to GRU on schedule.
Lightsaber
You only have the first amendment with the 2nd. If you're not going to offend someone with what you say, you don't have the 1st.
C010T3
Fri Sep 02, 2011 4:03 am
Quoting lightsaber (Reply 1):
Not really. It's all about politics. Infraero is trying to use this fact in time before GRU's concession to the private sector. Nothing has been done to prepare the airport for the A380. I mean NOTHING!
[Edited 2011-09-01 21:05:52]
Lufthansa
Fri Sep 02, 2011 4:18 am
And so it starts.
This will be a blow more to the european carriers for connecting traffic.
But if LH or AF start sending the A380 down, TAM will feel it. I wonder what they are gonna do in
terms of gate space? Simply send the A380 to a remote stand?
HB-IWC
Fri Sep 02, 2011 4:30 am
I suspect EK will adjust its schedule to the slot requirements. An earlier departure from DXB will not be a problem and connectivity will still be guaranteed. The flight is currently scheduled for 10.35am from DXB, and that can easily be brought forward to 8.30am. The new GIG flight will leave at 7.10am. The return flight is scheduled close to the slot requirements already.
JAAlbert
Fri Sep 02, 2011 7:28 pm
So what route will Emirates fly its 380 into GRU? Does it overfly Africa and the atlantic to S.A. or Asia and the pacific? Will it be a non-stop flight?
lightsaber
Fri Sep 02, 2011 8:30 pm
Quoting C010T3 (Reply 2):
Ugh oh... Hope is not a plan.
Quoting HB-IWC (Reply 4):
You're the expert.
Lightsaber
willzzz88
Fri Sep 02, 2011 8:40 pm
JAAlbert,
EK flies DXB-GRU and very soon DXB-GIG.
They use the 100% Africa over-fly route.
The Pacific route to Auckland, Sydney and on-wards to Asia is flown only by 3 airlines:
LAN Chile (SCL-AKL-SYD), Aerolinas Argentinas (EZE-AKL-SYD) and Qantas (EZE-SYD but very soon SCL-SYD because they can use a regular 744 on that instead of a 744ER required for EZE-SYD).
EZE-SYD is trans-polar and SCL-AKL/SYD follows a polar-arc.
oksman
Sat Sep 03, 2011 12:22 pm
It is very sad, but you're right. I'll be happy to see the A380 at GRU, but I don't know how the airport is going to handle it with it's current structure. Two weeks ago, the passport control queue was so loaded that it was reaching the gates, not allowing passengers to deplane! And the World Cup is coming.....
oksman
Sat Sep 03, 2011 12:27 pm
MCO2BRS
Sat Sep 03, 2011 12:41 pm
Just an idea, but if EK are required to use the 1600 Arrival and 0200 departure slots, could they operate a tag-on to say EZE to reduce the amount of time the A380 has to spend on the ground at GRU (and not earning revenue).
MCO 2 BRS
airbazar
Sat Sep 03, 2011 12:48 pm
Quoting MCO2BRS (Reply 10):
I doubt it. I suspect a lot of it has to do with airfield limitations as much as terminal limitations. GRU may not want to have an A380 taxiing around during the busy time. They may have to halt all ground ops to allow the A380 to taxi. Again, this is just a suspicion of mine, not a fact. Would be nice to know though.
FlySSC
Sat Sep 03, 2011 2:05 pm
AF is planing a DAILY A380 on CDG-GRU + a DAILY A380 on CDG-GIG for the winter 2012/2013.
copa330200
Sat Sep 03, 2011 6:54 pm
Quoting FlySSC (Reply 12):
that's great !!! I guess we will see LH considering the same
now, this will raise the preasure on TAM
On the run !!!
JAAlbert
Sun Sep 04, 2011 4:48 pm
Thanks Willzzz for responding! That must be quite a flight from DXB over africa and into GRU!
