YYZAMS
What Is The Status Of FRA Expansion?
Fri Sep 09, 2011 12:52 am
I know last December I was there and my A340 dropped us off in the middle of the ramp and we were put on a bus clear across Germany (well it seemed that way) to customs. There was still construction going on and no jetway. Will I have a gate this December or will the construction still be present? What is the latest update?
ogepma
RE: What Is The Status Of FRA Expansion?
Fri Sep 09, 2011 2:06 am
Quoting YYZAMS (Thread starter):
FRA had always been known for having numerous remote stands but there are still a lot of jetways connected to the terminal. Terminal 1 is being expanded with the new pier A plus which will add 7 extra jetways to the terminal. The remote stands are not really there because of the construction so there will always be a 50/50 chance that you might not get a direct gate and with the new runway opening in October, the likelihood of departing or arriving at a remote stand might be higher at least until next year when the new pier opens. The construction at FRA will be on till around 2017 when the first phase of the new terminal 3 would have been completed
YYZAMS
Sat Sep 10, 2011 3:07 am
thanks for the update! looks like I will go to MUC until 2017!
fraT
Sat Sep 10, 2011 9:14 am
When you are arriving on a intercontinental flight, the chances of a jetway psoition are quite high. European flights often have a tarmac position but intercont flights not that often. Which airline are you flying with?
PanHAM
Sat Sep 10, 2011 9:39 am
I always prefer getting bussed over getting dropped at gate A42 with a Marathon walk as a result. Arriving from Schengen at the bus drop in A is quite convenient.
To answer the question, the change is constant at FRA and when T3 will be opened there will still be construction going on., somwhere else. 6 slots pr hour will be offered and should be taken for the initial phase and FRA can be lucky to have that chance.
All that remains to be taken care of is the confirmation necessary night ops. Freight needs the night and thjere is no mistake about that.
Was Erlauben Erdogan!!!
Burkhard
Sun Sep 11, 2011 6:05 pm
As an aircraft lover, I prefer a free sight seeing tour over the apron 1000 times of going though these ugly holes - jetways are one of the biggest wrong developments ever in aviation and nothing for a.netters.
wilco737
Sun Sep 11, 2011 6:09 pm
Quoting PanHAM (Reply 4):
Oh, so damn true... A42 is soooo far away. I hope they change that on the new A0 part of the terminal. Quite a walk as well.
I only had once an apron position with the 744, all other flights were terminal positions. But you pretty much see mostly 330s/ 340s parked on the apron. But most of the flights get terminal positions.
wilco737
iainbhx
Sun Sep 11, 2011 8:50 pm
Quoting YYZAMS (Reply 2):
MUC has plenty of buses as well, in fact there seems to be an increasing number of them. Of course, the MUC bus rides are fairly short - not halfway to Mainz.
To be fair, the bus ride at FRA can be quite interesting until you spent about half of it hugging the terminal line and seeing nothing exciting. However, if you are on a fairly tight connect, the bus ride can be a PITA and the B Non-Schengen bus gates are a pit.
iainbhx
auroralives
Sun Sep 11, 2011 10:30 pm
Quoting frat (Reply 3):
I've flown AC into FRA many times... generally from YOW or YYZ, and I'm probably at least 50/50 for bus vs a gate. After a long flight, buses just seem to be a "pain", but point taken with avoiding the long walk...
What exactly are the criteria for getting a gate?? Are airlines being "cheap" by parking in a remote stand?
Who actually makes the call of bus vs gate??
briboy
Mon Sep 12, 2011 1:50 am
Ah, the joys of the FCT at FRA. A S-class Mercedes ride on the tarmac instead of a bus.
next up: YYC, SFO, SYD, AKL, WLG, CMB, BKK, SIN, FRA, VCE, JFK
wilco737
Mon Sep 12, 2011 5:17 am
Quoting briboy (Reply 9):
Or Porsche Panamera. That has far more style than the busses to the terminal...
wilco737
PanHAM
Mon Sep 12, 2011 5:30 am
Quoting iainbhx (Reply 7):
rather a bottleneck, fighting your way up on the escalators.
Lufthansa411
Mon Sep 12, 2011 6:49 am
Quoting auroralives (Reply 8):
With most full service airlines in Europe, it comes down to who is on the plane, how busy the airport is at a given time and what the plane is doing next. By who is on the plane, I mean the number of wheelchairs, deaf, blind, and pax with infants that could have a great amount of difficulty deplaning via stairs. If you have a plane coming in with several pax that need wheelchairs and can't do stairs, it makes no sense to put them at a bus gate where they have to get a special truck to lower the pax to the ground.
Then there is gate availability. When you land, you might see several open gates even though you pull up to a remote stand. However, once you take minimum ground times and the pax manifest into account, if your plane lands at 8 am with no wheelchairs and 3 planes are landing at 8:15 and each have a bunch, it is better to put your plane at a remote stand and leave the other gates empty as your plane won't be turned around in time (that was a very simplistic example. In the real world obviously scheduling arrivals/departures is much more complex)
Finally, what the plane is doing next is important. Let's say the plane you are on lands in FRA and after your flight has 2 hours of scheduled ground time to correct deferred maintenance issues. It makes more sense to park it remotely.
In terms of who makes the call, at a major hubs like FRA, CDG and LHR, where a single airline dominates a terminal area, the airline decides and forwards the information to ramp control. There are usually several people just coordinating the data on flights and deciding what to do with specific aircraft.
Nothing in life is to be feared; it is only to be understood.
CYatUK
Mon Sep 12, 2011 8:23 am
Quoting Lufthansa411 (Reply 12):
With most full service airlines in Europe, it comes down to who is on the plane, how busy the airport is at a given time and what the plane is doing next. By who is on the plane, I mean the number of wheelchairs, deaf, blind, and pax with infants that could have a great amount of difficulty deplaning via stairs. If you have a plane coming in with several pax that need wheelchairs and can't do stairs, it makes no sense to put them at a bus gate where they have to get a special truck to lower the pax to the ground. ...
...and deciding what to do with specific aircraft.
Thanks Lufthansa411.
I was wondering if there is any trend regarding Schengen and non-Schengen flights in and out of FRA.
I fly regularly on the LCA-FRA route and we always have to use a remote stand - and its usually the very last on the south western part of the airport. (Cyprus is not part of the Schengen Area yet).
CY@Uk
iainbhx
Mon Sep 12, 2011 9:43 am
Quoting PanHAM (Reply 11):
Have you been reading my blog
Actually, the B51-55 ones are nasty as departure gates as well, luckily I've been mainly getting B30-33 as a bus gate lately with their great views.
Same goes with the B Non-Schengen FCL, although please note that F-class car pickup from plane is not certain at FRA or MUC.
Quoting CYatUK (Reply 13):
No, there are ample buses for everyone
The only tendency I have noticed is that Regional Jets are nearly always a bus and 735 and 319 have a pretty good chance of a bus. Did FRA-NUE a few months ago and I swear the bus ride was nearly as long as the flight.
iainbhx
PanHAM
Mon Sep 12, 2011 11:42 am
Quoting iainbhx (Reply 14):
no, just travelling regularly to the UK and other non Schengen countries.
look at it that way, you get a free sightseeing ride, non passengers have to pay for that. From the terminal on the right hand side, the stands behind the cargo centre are the boonies and on the left hand side behind T2 it's the bay of pigs (Schweinebucht) in German.
auroralives
Mon Sep 12, 2011 12:26 pm
In terms of who makes the call.... etc
Many thanks for the very detailed answer Lufthansa411 !!
EPA001
Mon Sep 12, 2011 2:22 pm
Quoting auroralives (Reply 16):
My thanks as well. I am not a frequent user of the airport in Frankfurt. I usually drive by it by car or by train, but have been here as a passenger about 10 times. I really like the airport though there is the contrast between the old and new terminal. But now with all the renovations and expansions going on near and inside the old buildings, the difference will probably become smaller and the quality of the airport was always good in my opinion.
Now let's wait and see how the new terminal 3 will turn out to be and how they will connect it to the present passenger terminals and train station.
Viscount724
Mon Sep 12, 2011 2:47 pm
If you want to avoid a bus for longhaul flights, connect at AMS. It's almost unheard of for anything larger than KL E-190s and Fokker 70/100s and similar regional types of other carriers to use bus gates. I have never had to use a bus gate for 737s, A320s or any widebodies.
ZRH also uses a lot of buses, again mainly for regional aircraft but also some A320 and B737 flights, but almost never for widebodies.
robffm2
Mon Sep 12, 2011 2:59 pm
Quoting EPA001 (Reply 17):
From what I hear following is in the planning for T3:
- A new suburban train line (S-Bahn)
- An extension of the APM (probably a new line, maybe also connecting the big office projects north of the airport)
- Upgrading the existing connection to the Autobahn
PanHAM
Mon Sep 12, 2011 3:02 pm
The situation at FRA will not be better with the expansion, may be with T3 but that will cause another problem with interlining between LH and * and the rest of the carriers. . The new gates at A0 will just add 8 to 12 widebody gates, The new runway will start with 6 new slots per hour. Once the full capacity of about 40 additional slots is taken up, it will be the same again as today, even with T3. We simply don't have enough space here. But again, using the bus is not that bad if you are coming in on a Schengen flight, it can save a lot of walking.
EPA001
Mon Sep 12, 2011 3:16 pm
Quoting PanHAM (Reply 20):
Indeed it can, and usually does.
Quoting Viscount724 (Reply 18):
If you want to avoid a bus for long-haul flights, connect at AMS. It's almost unheard of for anything larger than KL E-190s and Fokker 70/100s and similar regional types of other carriers to use bus gates.
The last year (mid-2010 to mid-2011) I have flown over 55 times to the UK and back. Almost always with the F70/F100. For these flights indeed always a bus is used at AMS. But I found the connection good enough and you get to see some nice views from the platforms.
[Edited 2011-09-12 08:17:23]
Semaex
Mon Sep 12, 2011 9:13 pm
The only Mercedes I see departing the FCT are Vitos. Anything lower than that is in 95% of the time a Panamera. Porsche did some good advertising there, I'm sure LH did not pay a penny for those cars...
South-West? Are you sure? That's LHT and GAT area. I think you mean North-West. In any case, I am on the side that the further the bus ride on the tarmac, the better I feel about the journey. Like it's been said before; it's a free airport tour, and hell, in FRA you have quite some exotic birds from time to time. No better spotting opportunity than a remote stand!
Quoting robffm2 (Reply 19):
About your points 2 and 3, they are as good as certain. The APM will in fact be an extension to the existing line. The APM station in T2 has been build so it can easily be extended to run to the south-side of the parallels.
I haven't heard of a new S-Bahn line in planning though. However, the S7/RE70 lines run in a North-South direction parallel to the Autobahn A5, so I can definately imagine them making a small bend to support T3.
What is a fact already is that the existing S8/S9 lines that currently run through FRA Regional Train Station will have another stop in the future at Gateway Gardens, the former US Army barracks which are in transit of becoming a new quarter of commerce right next to the airport. From what I witnessed a couple of months ago development on this cityscape is slow, but LH Catering (LSG) have settled there a while ago, Hotels are in the making and DE Headquarter are to move there from Kelsterbach.
Some other developing construction sites are:
The (Inter)National Train Station at FRA is seen a sudden birth of a multi-storey car park next to it. They are connected by an APM which spans over some heavily used streets that lead to the departure floor of FRA. Truely a magnificent sight, from an architectural point of view. Speaking of architecture; The Hilton and Hilton Inn located within the train station are almost complete, and costumers seem to enjoy it there, lot's of people shopping and dining in the "New Work City / The Squaire". If you get a chance while transiting FRA, make sure to check it out!
Some news I heard concerning the new North-West landing strip at FRA: Oct. 20 is supposed to be the date when it is cleared for full operation (that is: initially 6 landings/h), however the first airplane landing will be on Oct. 21, with none less on board than Chanceless Merkel. If I wasn't so unlucky to be in Florida at that date I'd pick up my camera and hope for an A310 ...
Mind you, be happy it's not LHR!
// You know you're an aviation enthusiast when you look at your neighbour's cars and think about fleet commonality.
briboy
Mon Sep 12, 2011 11:36 pm
Quoting Semaex (Reply 22):
That, or Porsche can't sell those rather ugly cars.
I have not been through FRA since February, and back then it seemed 50/50 Mercedes/Porsche. I will see again in the upcoming months.
PanHAM
Tue Sep 13, 2011 5:26 am
I may be one of the rather few people who like LHR but that has to do with the fact that I use that airport regularly since 1967, so nostalgia is a part of it. I pity the Brits that they do not get the badly needed third runway, so yes, we are far better off here. No doubt about that.
I am sure they spread the landings, the initial slot increase is 6 per hour, but they will ease the burden of the other 2 landing runways and distribute the traffic evenly.
CYatUK
Tue Sep 13, 2011 5:47 am
True true!
CY@Uk
LH422
Tue Sep 13, 2011 11:51 am
Quoting PanHAM (Reply 15):
I did the tour on Sunday for €8 (including free access to the visitor's terrace). It was really nice. Plus, it has the advantage that the bus stops right next to the runway whenever an A380 takes off or lands.  http://www.frankfurt-airport.com/con...joy0/airport_sightseeingtours.html
This is to the North of the Autobahn?
The whole building is amazing: http://www.thesquaire.com/en/
robffm2
Tue Sep 13, 2011 12:42 pm
There is a German speaking forum about constructions / buildings / infrastructure projects in Germany.
Especially the Frankfurt threads are quite extensive and there are many pictures too.
The Squaire
Airport - T1 Gates A0
Airport - T3 and NW Runway
Airport - other projects
And for those who are interested in other constructions as well here is an interactive map:
Frankfurt Project Map
http://www.deutsches-architektur-forum.de/forum/pics/schmittchen/fra_flugsA0.jpg
picture linked from DAF
For the NW runway Fraport has some webcams online too:
NW runway - webcams
http://apps.fraport.de/webcamBildergalerie/images/img_auswahlmap.jpg
picture linked from Fraport
Semaex
Tue Sep 13, 2011 4:38 pm
Quoting LH422 (Reply 26):
Correct. North of A3 (and the airport) and West of A5:
http://www.schuessler-plan.de/upload...isp/4_S-Bahn_Gateway_Gardens_1.png
Quoting robffm2 (Reply 27):
Quoting briboy (Reply 23):
POV, but I believe they are doing rather well selling the car
jaylink
Fri Sep 16, 2011 7:15 pm
Quoting Burkhard (Reply 5):
Mostly I agree, but you'll often get a modern-looking jetway with windows in Japan. That doesn't help in FRA, true.
ATC-SIM: the browser-based air traffic control simulator http://atc-sim.com
Semaex
Fri Sep 16, 2011 11:56 pm
A rumour (or misinformation) I've heard from someone working at the team which designs T3:
The APM will run underneath the Parallels, and not (as would be much easier to build BUT a longer drive) parallel to A5.
I know it sounds like nonsense, especially if you consider that if you were to extend the APM with the current setup, there is really no other way then routing it to the east of the runways. However, this person works directly in the construction business, so I tend to have reliable information on that.
Thoughts?
traindoc
Sat Sep 17, 2011 1:10 am
Just flew CO 51, FRA to EWR on 9/16. When the plane came in EWR, (CO 50) it docked at one of the A gates and pax deplaned thru a jetway. However, then the plane was towed to the stands, and we had to take the trans German bus ride in order to board. So my answer is, it is the flip of the coin. I agree that MUC is a nicer airport than FRA, but FRA has much better connections to the U.S. Therefore, you need to choose which is more important, the airport terminal or the airport connections.
fraT
Sat Sep 17, 2011 11:11 am
Quoting Semaex (Reply 30):
Thoughts?
That would be great but what I have heard before the tunnel would be too expensive. But you never know, things and opinions are changing.
robffm2
Sat Sep 17, 2011 8:59 pm
Quoting fraT (Reply 32):
There isn't too much space between the runways and the Autobahn. I would be surprised if it would be enough to have an elevated two tracks APM.
I can imagine that they might even go to the east of the Autobahn!
Semaex
Sun Sep 18, 2011 8:26 pm
There isn't enough space between the runways and the A5 to build an elevated APM, but who says it has to be elevated? Applying a smooth angle to get the APM on the floor after the T2 station, and you can track the whole thing parallel to the Autobahn.
Crossing the A5? Sounds good, but I think that would kill the budget.
It just won't get in my head how an APM underneath the Parallels can ever be connected to the existing system, and that must be a given!
speedbird128
Mon Sep 19, 2011 6:52 pm
Quoting robffm2 (Reply 33):
That would be fabulous - they can have a stop for me at my home in Zeppelinheim
A306, A313, A319, A320, A321, A332, A343, A345, A346 A388, AC90, B06, B722, B732, B733, B735, B738, B744, B762, B772, B7
