PacificF27
Lockheed Constellation Windows
Mon Sep 12, 2011 5:05 pm
The first few windows on the Connie are lower than the rest. Does the floor step down toward the front of the passenger cabin? Is the floor sloped? If neither of these what is the reason for the differing window heights?
EVA is tops across the Pacific!
Dreadnought
RE: Lockheed Constellation Windows
Mon Sep 12, 2011 5:39 pm
Photo © Rainer Spoddig
As you can see in this picture, there does indeed appear to be a step down towards the cockpit.
You have enemies? Good. That means you've stood up for something, sometime in your life. - W. Churchill
longhauler
Mon Sep 12, 2011 6:14 pm
Both the shorter versions L049/649/749 and the longer versions L1049/1649 had the step down from the middle cabin to the forward cabin. Normally though, in airline operation of the time it was not all that noticeable as usually washrooms were placed there, or that was the transition from the passenger cabin, to the crew rest area.
The step down would have occurred going from one cabin to the next.
Looking at this picture, it is very obvious on this L049, as in a charter configuration no space would be left unsold:
Photo © Ellis M. Chernoff
Or in this Save-A-Connie L1049H, you can see the step down as well.
Photo © Ryan J. Pearl
Viscount724
Mon Sep 12, 2011 10:44 pm
Quoting longhauler (Reply 2):
I believe that's true for the L-049/649/749 but not for the L-1049/1649 which had a flat floor and only the windows were positioned lower in the forward cabin. I've seen photos of a stripped L-1049 or 1649 cabin which showed the flat floor. Can't find the best photo now but did find this item. Nolte the caption of the 2nd photo.
http://www3.delta.edu/rmmee/insupcon.htm
longhauler
Mon Sep 12, 2011 10:49 pm
Quoting Viscount724 (Reply 3):
That's what I always thought. And recall the TCA L1049 that was parked near YYZ open for viewing, I don't remember a step in the floor .... however, look at the interior shot of the SAC L1049H above, that clearly shows a drop in the floor level.
Viscount724
Mon Sep 12, 2011 10:52 pm
Quoting longhauler (Reply 4):
Maybe it's my eyes, but I don't see a step in the 1049H photo.
vc10
Tue Sep 13, 2011 12:01 am
I can confirm that the 749 had a stepdown . Now with the 1049 I think what happened is that originally as a passenger aircraft it might still have had a step down as the window line definately lowers at the front, but having never seen an original passenger 1049 this is a guess.
Now when the 1049 was converted to cargo with a cargo door at the front [unlike at the rear for the 749] the step on the 1049 would have been a real problem to loading freight, so I suggest as part of the conversion the front floor was contoured to overcome the step and so make the level floor we see on 1049 today which I would say are all preserved cargo aircraft .
to support this theory if I remember correctly the floor hatch to the front freight compartment on cargo 1049 has a floor hatch and beneath that another which is the original entry hatch.
Just a theory see if you think itis ok
Viscount724
Tue Sep 13, 2011 12:20 am
Quoting vc10 (Reply 6):
Photo of forward cabin of a preserved LH L-1049G (D-ALIN), still with original passenger interior. There's no step.
http://209.85.120.99/viewphoto.php?id=6488985&nseq=12
vc10
Tue Sep 13, 2011 12:57 am
Viscount,
A lovely picture but was this aircraft preserved from it's end as a passenger aircarft in this condition or when it' passenger days were over was it converted to a cargo aircraft and then subsequently restored to a display passenger aircraft but still with a cargo floor
I have just looked up "Seaboard and Western " 1049 manual which shows the aircraft having a flat floor but as these aircraft were for both cargo and passengers and had a front cargo door it does not really settle the arguements
any other ideas
Viscount724
Tue Sep 13, 2011 1:41 am
Quoting vc10 (Reply 8):
Viscount,
As far as I can tell it was never converted to a freighter.
timz
Wed Sep 14, 2011 11:03 pm
The floor sloped on the 1649, so presumably on the 1049 as well. See the last paragraph of the first column of
http://www.flightglobal.com/pdfarchive/view/1956/1956%20-%200911.html
