747400sp
Did The 777 Seal The 747 Fate From The Start?
Thu Sep 15, 2011 7:42 pm
Let's go back to the mid 80's. Boeing just put two new state of the art twin jets into service, the Boeing twins 757/767, seeing that their largest jetliner is not as advance as their second and third largest airliners at the time, they introduced the 747 400. After the 747 400 goes into service, airlines approached Boeing asking for a jet that could fit between the 747 and 767, that has the range and comfort of a 747 400 but the fuel burn of a 767. This new jet would also be ideal for replacing older trijets (DC-10s/L1011s). So Boeing start the Working Together program, where different airlines of the world got together and helped design the new jet , which be name the 777. Let us fast forward to the mid 90's, the 777 is in service, and airlines are very happy with the new jet. Boeing start working on the biggest 747 ever, the 747-X, ( 747-500, 600 and the extra wide 700) and launches this new jumbo jet. But only a small number order it and Boeing cancel the project. ANA reduce it's NRT-ORD route from a 747400 to a 777 200ER and in 2000 AZ change it's order for 747 400s to 777 200ERs.
To me it seems like the 747 started to lose ground when the 777 came a long, so it should not be such a surprise to see 77W replacing 747 400, now.
So is it me, or did airlines wanted a plane like the 777 to replace their 747 fleet, long time ago?
Stitch
RE: Did The 777 Seal The 747 Fate From The Start?
Thu Sep 15, 2011 7:47 pm
The A340-600 and A380-800 were both clear and present dangers to the 747-400. The A340-600 carried more payload by weight farther than the 747-400 and burned a great deal less fuel per seat. The A380-800 carried more people and cargo and also burned a good bit less fuel per seat.
If anything, the 777-300ER was Boeing's realization that the 747' was in the twilight part of it's career as a passenger carrier.
If the Asian Financial Crisis had not killed the 747-500X and 747-600X, they likely would have been enough to keep the model relevant into the 21st century even with the 777-300ER and A380-800 in play.
Ronaldo747
Thu Sep 15, 2011 8:09 pm
Over the years, lots of improvements were engaged and the 777 is doing far better now than the former expectations, especially the today's 777-300ER that operates routes like HKG-JFK-HKG nonstop year around as well as DXB-SFO/LAX, the latter with some payload restrictions. Of course, like the 747, the 777 is simply a great and amazing airplane with better economics.
KELPkid
Thu Sep 15, 2011 8:16 pm
Quoting 747400sp (Thread starter):
First of all, only the -300 length birds in the 777 series come close enough (cargo wise, seatwise, main floor square footage wise) to even be considered a worthy 747 replacement
Lots of changes had to happen. The original, A-market 300 was nothing more than a -200 with a longer fuselage. The range was shorter than the -200 models. It was designed to appeal mostly to Asian carriers who wanted to fly low frequencies (with high seat counts) daily within Asia.
The next problem? ETOPS. To seriously displace 747's for many carriers like QF, SQ, etc. ETOPS-180 wouldn't cut it. Otherwise, you'd have to leave cargo and pax behind and resort to funny routings to avoid ETOPS "no mans land" areas. Boeing gradually increased ETOPS on the -300ER and -LR, so it wasn't until about 2003 or so that ETOPS had been suffeciently raised to even allow carriers with long overwater segments to consider replacing quads with twins.
Problem was, many of those carriers had bought the 744, and the fleets were still relatively young. They wanted to get their money's worth out of them. The higher fuel burn wasn't a big enough issue (yet).
The final nail in the coffin for the 744 was the huge runup in oil prices in the mid to late 2000's. Then, the fuel effeciency of the twin was a no-brainer. It wasn't until 2009 that SQ, for example, changed many TransPac flights like SQ1/2 over to the 77W.
So I would say, no, the 777 kind of evolved into the 747 killer   I remember a friend who took an internship college class at Boeing (late 1990's) telling me the marketing guys said back then, the answer to which airplane you would rather sell an airline is the 747, because it is more profitable for Boeing, since the development costs had been recouped long ago...
CXB77L
Fri Sep 16, 2011 4:41 am
Quoting KELPkid (Reply 3):
Not quite. The 777-300 is a straight stretch of the 777-200ER, not the base 777-200. The 777-300 out-ranges the 777-200: according to the Boeing website, maximum range for the 773 is 6,005nm vs 5,240nm for the 772.
Boeing 777 fanboy
747400sp
Fri Sep 16, 2011 1:07 pm
Quoting CXB77L (Reply 4):
Yes, the original 777 300, is a stretch 777 200ER and believe are not, a non ER 777 300, can fly some trans Pacific routes. I remember around late 2002 or early 2003, KAL was flying 773 non stop between LAX and INC. What was funny, is that the plane did not use that much runway to get off the ground.
simairlinenet
Fri Sep 16, 2011 1:35 pm
Absolutely. Remember that when the 747 came out, it was 2.5 times larger than the next largest aircraft. That's a lot of extra capacity to fill, and was still challenging in the subsequent 25 years before the 777 entered service.
Why did airlines buy 747s? Capacity was not the primary determinant, but rather the range capabilities that the aircraft offered. As soon as it became apparent that the 777 (especially the -300ER) had sufficient range to perform the same missions, the 747 was on the way out.
PC12Fan
Fri Sep 16, 2011 1:59 pm
IMO, if the 777 was offered at the same time the 744 was, we would not have seen the numbers of 744's produced that we did. The 744's claim to fame when introduced was it's range. I remember reading an article on the 747-400 in Air Transport World. One airline exec stated, "it's the only airplane that can do the job".
Just when I think you've said the stupidest thing ever, you keep talkin'!
BlueSky1976
Fri Sep 16, 2011 2:34 pm
Live long, Mighty Triple Seven. Die soon, 747.
That's all I have to say about it.
Rule #1: Never trust your government. EVER.
Rule #2: In case of any doubt, see Rule #1.
PC12Fan
Sat Sep 17, 2011 12:30 am
Quoting BlueSky1976 (Reply 8):
You could have chosen you wording differently referring to the icon.
And that's all I have to say about it.
ltbewr
Sat Sep 17, 2011 12:47 am
I would suggest that the 777 was to be the eventual replacement for the 747 for most routes. Clearly the 777, even in it's early versions, pushed out the 747 from some fleets like BA's, put the DC-10/MD-11 to cargo duty, on many routes like between North America and Europe, where you needed most but all of the pax capacity of a 747, but more than a 767. There are very few routes today that really require the B747 or A340's 4 engines and 2 engined large a/c like the 777 are so much lower fuel guzzleers, they ride great, excellent reliabilty and not too much excess pax capacity (so end up selling fewer seats for cheap prices to fill up the a/c).
gdg9
Sat Sep 17, 2011 1:44 pm
With about 1,500 sales, I think the 747 has done all right either way.
@dfwtower
NWAROOSTER
Sat Sep 17, 2011 6:45 pm
The 777 could originally be said to be a 747-100 replacement, which was no longer being built and airlines were stating to retire the 747-100s. Then777 did not quite cut it to replace the 747-200, as it needed to prove itself as a possible 747-200 replacement, which it basically has as Boeing has improved it, stretched it and has gotten it ETOPS certified to fly just about anywhere. There are missions that the 777 will never replace the 747, such as cargo and certain passenger operations.
That is one reason Boeing has built the 747-8I in the cargo and passenger versions.
The 747-8 will never sell in the quantities that earlier versions did. But there is still a need for the 747I.
Also, Boeing originally offered the 777 with folding wings to make it easier to park at airport gates, but it never sold.  old
[Edited 2011-09-17 11:53:57]
Procrastination Is The Theft Of Time.......
747400sp
Sat Sep 17, 2011 7:45 pm
The B747 has something that these newer planes like 777s and A380s will never have, she was the last plane Boeing design for Juan Tripp. How dare you insult the last of the great Boeing Clippers design for Pan Am!
KELPkid
Sat Sep 17, 2011 8:04 pm
Quoting 747400sp (Reply 13):
I'm sure, though, that a fair bit of the 747's design was born during the Air Force's large airlifter competition, which Boeing lost out to Lockheed in   Some of the drawings of Boeing's proposal look amazingly 747-like... they had to start engineeriing things on paper, though, for the proposal.
747400sp
Sat Sep 17, 2011 10:43 pm
Quoting KELPkid (Reply 14):
Your right, but then, that's something else that the 747 offers that an 777 or A380 don't, you are riding on a C-5 design by the designer of the B-52.
Stitch
Sun Sep 18, 2011 4:00 am
I'm sure, though, that a fair bit of the 747's design was born during the Air Force's large airlifter competition, which Boeing lost out to Lockheed...
"Fair bit" being turbofan engines.
A military outsized cargo carrier meets very, very different design criteria from a large passenger carrier. The design team behind the 747 have stated for the record they drew very, very little from the CX-HLS program.
