Which LH A340s Are Based At MUC?
Fri Sep 23, 2011 5:42 am
LH has A343/A343X and A346/A346X models and I wonder which of each model are based at MUC. There are 8 regular A340-300s while the rest are the newer X model. Where are those 8 models based? The same goes about the A346.
Do they have specific A340s based at each hub, or do they rotate them through FRA/MUC?
bavair
RE: Which LH A340s Are Based At MUC?
Fri Sep 23, 2011 2:45 pm
Quite a while ago this was the list of aircraft based at MUC (spring of this year):
A330-343X
A330-343X
D-AIKA
D-AIKL
D-AIKO
A340-313X
D-AIFC
D-AIFE
D-AIFF
D-AIGM
D-AIGO
D-AIGP
D-AIGU
D-AIGV
A340-642
D-AIHC
D-AIHF
D-AIHX
D-AIHY
D-AIHZ
A340-642X
D-AIHM
D-AIHN
D-AIHO
D-AIHP
D-AIHQ
D-AIHR
D-AIHU
D-AIHV
D-AIHW
As you can see its quite a mix, and of course LH is constantly shifting them around so several regs. listed here may have moved back to FRA already while other ones have joined the fleet in MUC.
Fri Sep 23, 2011 2:50 pm
Quoting bavair (Reply 1):
Thank you very much.
So it seems that all the A343s (non X) are based at FRA
EDIT: Which version of the A343 (seat layout) will LH use on their daily MUC-ORD route this winter?
[Edited 2011-09-23 07:52:53]
[Edited 2011-09-23 07:53:24]
