Gonzalo
ANA 787 Hits Boarding Bridge
Wed Oct 19, 2011 11:00 am
Not the best way of giving a baptism to the newest toy in the fleet  http://www.flightglobal.com/news/art...t-787-into-boarding-bridge-363604/
Apparently the damage was very minor, but still, come on guys... be careful with this baby !!!
Rgds.
G.
[Edited 2011-10-19 04:03:58]
[Edited 2011-10-19 04:12:51]
Gear Up!!: DC-3 / EMB-110 / Fairchild-227 / Ab318-19-20-21 / B732 / B763 / B789
wilco737
RE: ANA 787 Hit Boarding Bridge
Wed Oct 19, 2011 11:02 am
Quoting Gonzalo (Thread starter):
Oh boy. Not a good start. But these things can happen. Bad luck that it was the 787.
wilco737
UA933
RE: ANA 787 Hits Boarding Bridge
Wed Oct 19, 2011 12:09 pm
Will repairs to the fuselage be more expensive or complex now that they are using composites compared to aluminum?
united - It's time to fly!
fpetrutiu
Wed Oct 19, 2011 1:08 pm
Quoting UA933 (Reply 2):
I think yes, but will not happen as often as aliminum.
Florin
Orlando, FL
bikerthai
Wed Oct 19, 2011 1:19 pm
Depends . . .
If they decide to do a standard bolt-on repair, then the cost would be almost the same.
If they decide to do a "bonded" repair, then it could be more costly.
As far as this incident is concern, looks like the damage was to the engine cowl which would have been composite anyway whether the fuselage was aluminum or composite.
bikerthai.
SKAirbus
Wed Oct 19, 2011 1:21 pm
It's not like this aircraft is the biggest in the ANA fleet... It is only really slightly bigger than the 767!
When the A380 entered service there were a number of mishaps, which although avoidable were slightly more understandable due to the aircraft's size and dimensions.
Did ANA put its most inexperienced ground crew in charge of towing this expensive piece of gear around?
Next Flights: LHR-OSL (738), OSL-CPH (320), CPH-LHR (321), LHR-HEL (359), HEL-LHR (359)
MadameConcorde
Wed Oct 19, 2011 1:32 pm
Article is dated 14 October.
I am sure the new ANA beauty is very fine by now and back to the skies.
I will have to SevenWaitSeven until 21 January to be on the flight from HND to FRA - first long haul for Princess Dreamliner.
It will not be the same aircraft as this HND-FRA will have the new "Staggered" Business Class seats for international operations. A two-cabin aircraft. The one they will fly to HKG is the domestic version - first delivered aircraft to ANA. "We Fly First".
The HND-FRA flight will be more like the true first international commercial flight as it is opened to all to fly on. The 26 October inaugural was by lottery, invitations, the press and a few rare outlandish priced Business seats for charity on Yahoo Japan and ebay (3 each).
United787
Wed Oct 19, 2011 3:36 pm
This answers the question...what is ANA going to be doing with the 787 for a month before service...playing bumper cars...
Seriously, they need to stop toying with this thing and put the damn thing in service...they have had plenty of time to prepare for this plane...for crying out loud, the 748F went directly into service...rant over...
jetblast
Wed Oct 19, 2011 3:46 pm
Quoting United787 (Reply 7):
Some slight differences, you may note the 748F is not an entirely new design while the 787 has some quirks about it. The freighter is also not carrying passengers...
[Edited 2011-10-19 08:47:31]
Speedbird Concorde One
Navigator
Wed Oct 19, 2011 3:48 pm
Quoting bikerthai (Reply 4):
Can you do a "standard" bolt-on repair on a composite structure on a 787?
747-400/747-200/L1011/DC-10/DC-9/DC-8/MD-80/MD90/A340/A330/A300/A310/A321/A320/A319/767/757/737/727/HS-121/CV990/CV440/S
SKAirbus
Wed Oct 19, 2011 3:49 pm
Pretty unfair comparison imho.
The 787 is a brand new aircraft with completely new systems and an all new flightdeck. It is also made up of many composite parts so not only do flight crews and cabin crew need to get used to it but also engineers and other maintenance staff.
The 748F has the exact same flight deck as the 747-400, many of the same systems with the main differences being in the wings, engines and the fuselage lengthening. Probably explains why the 748i hasn't sold very well as it isn't much of an upgauge on the 744. I am suprised the 748 1980s flight deck has not been replaced by a more modern 787/777 style full glass cockpit.
DfwRevolution
Wed Oct 19, 2011 4:20 pm
Quoting SKAirbus (Reply 10):
To an extent, it did:
http://www.flightglobal.com/blogs/fl...a-closer-look-747-flight-deck.html
andytb77
Wed Oct 19, 2011 4:53 pm
So will the damage to the engine cowl cause a performance penalty in the laminar flow? Remember the discussions on how Boeing will require the engines to all be white so as not to disturb the laminar flow. You would think that any type of surface damage would hinder performance, albeit slight.
United787
Wed Oct 19, 2011 6:28 pm
Quoting jetblast (Reply 8):
I know...sarcasm...but anxious, their ramp up time seems to be excessive regardless...
bikerthai
Wed Oct 19, 2011 6:44 pm
Quoting Navigator (Reply 9):
For the 787 fuselage. The composite is a laminate type. Small damage to the skin (like a hole) can be covered with an aluminum sheet (or composite sheet) bolted on with fasteners (and sealant/adhesivve).
If the damage include the stringer and shear ties, then the repair may be a little more complicated.
I think there was a presentation floating out there to show how they were planning to do it.
bikerthai
474218
Wed Oct 19, 2011 6:47 pm
I think you ill find just the opposite!
Bonded repairs are cheaper!
The fasteners used in a bolt-on repair being the most costly item!
A bonded repair may take longer, because of cure time.
Yes!
amccann
Wed Oct 19, 2011 6:54 pm
Composites are not my specialty, but with the limited 787 structural knowledge I have, you can not use a bolt on repair on the 787. A few of the critical design features of the 787 are large single piece fuselage sections and integral (co-bonded) fuselage stringers, eliminating tens of skin joints and thousands of fasteners and therefore reducing weight and drag. Without bolt holes already in the fuselage (to join fuselage sections and stringers) to perform a bolt on repair on the 787 would require bolt holes to be drilled and drilling composites is a BIG problem. Drilling cured composites can de-laminate layers or fray fibers resulting in significant strength loss around the bolt hole.
What one person receives without working for, another person must work for without receiving. - Ronald Reagan
TheSonntag
This has probably not been tested in Boeing-training. So better test it before the inaugural service. After all, these things happen. No big deal if you ask me.
tdscanuck
Wed Oct 19, 2011 7:26 pm
ANA has auctioned seats for the inaugural 787 flight...would you want to go forward with that plan without *two* service-ready aircraft in case one goes tech?
Yes.
Quoting amccann (Reply 16):
You can.
It's not that big deal...the OEM's do it all the time during initial build and all repair shops know how to do it because you have to do it to maintain many of today's components (nacelles, control surfaces, flap fairings, etc.).
Tom.
707lvr
Wed Oct 19, 2011 7:37 pm
It's clear from this thread that the 787 will be under tremendous scrutiny. No surprise there. We are talking about composites and repairs when it was only an an engine cowling getting scraped. I wonder how many of us half-expected the second paragraph in the story to begin, "Sadly, the aircraft will be a write-off ... "
bikerthai
Wed Oct 19, 2011 7:38 pm
True. You need a sharp bit when drilling in CFRP. And that bit won't stay sharp for long.
On the other hand, you don't need to de-bur every single hole in the CFRP because you don't have to worry about crack propragation.
bikerthai
cmf
Wed Oct 19, 2011 7:55 pm
Quoting tdscanuck (Reply 18):
SQ did. Had many more seats sold too
Don’t repeat earlier generations mistakes. Learn history for a better future.
yellowtail
Wed Oct 19, 2011 8:52 pm
come on you guys....ANA is really testing this thing including Boeings guarantees on ramp rash etc
When in doubt, hold on to your altitude. No-one has ever collided with the sky.
Daleaholic
Wed Oct 19, 2011 9:44 pm
Plenty of factors could've caused this incident. Just one of those things which happens from time to time at an airport, it's just unfortunate that on this day it was the 787! Sounds like the damage is merely cosmetic, nothing to worry about!
Religion is an illusion of childhood... Outgrown under proper education.
FlyingHollander
Wed Oct 19, 2011 9:45 pm
Is it just me or have there been a lot of these type of incidents lately? It seems to me that people are handling these very expensive machines with little care.
If it ain't Dutch, it ain't much.
lightsaber
Crew
Wed Oct 19, 2011 11:21 pm
What's the fuss, from the OP link: "Everything was fine. There was only some surface damage, and the aircraft was back in operation on schedule," said the spokesman.
Quoting FlyingHollander (Reply 24):
There have always been a large number of the incidents. What has changed is the number of standby aircraft.
Quoting yellowtail (Reply 22):
Quoting 707lvr (Reply 19):
And the A380 wasn't?
I'm afraid some is A vs. B 'payback.'   I'd rather go into the aircraft performance and such... But in a way these threads are the economic lifeline of airliners.net.
Lightsaber
srbmod
Wed Oct 19, 2011 11:23 pm
Thankfully in this case, it was an engine inlet cowling that suffered surface damage. This sort of thing is probably the most common thing that happens when part of an a/c hits the jetway. For all we know, the jetway could have been left in the wrong position by the gate agent(s) that worked the previous flight from that gate (I've seen this happen on the ramp on numerous occasions, but thankfully the only result of this was a brief delay bringing in the a/c into the gate. But at the end of the day, the tow team should have been paying closer attention to the objects in the gate area as they were bringing the a/c into the gate. The wingwalker on the left side (assuming wingwalkers were used, as I've seen tow teams pull a/c into gates without the use of wingwalkers) definitely should have been paying attention in regards to the location of the jetway.
simpilot459
Thu Oct 20, 2011 5:52 am
Can't be that big since there are thousands of drilled holes throughout the 787. They don't glue those fuselage sections together.
Take off: Optional Landing: Mandatory
Navigator
Thu Oct 20, 2011 6:41 am
This is what I learnt before about the composite structure on the 787. One of the major problems with using composite was how to do repairs without having to switch fuselage sections and repairing them in a factory.
This was a major area of concern for Boeing. You could not just do a standard bolt-on repair from what I learnt then. It would require special procedures. How did they solve this?
MadameConcorde
Thu Oct 20, 2011 6:50 am
Quoting cmf (Reply 21):
3 Business seats were auctioned off on Yahoo Japan for Japanese residents only.
3 Business seats were auctioned off on eBay open to bidders worldwide.
One pair and one single each time. Proceeds willl go to a charity in Japan dealing with environmental causes.
All the other passengers were picked in the lottery opened to Japan residents only - not forgetting the Media and a number of ANA guests. I heard that Tom Lee the same passenger who flew on the fist 747 flight will be on board too - he was on the A380 inaugural. He had to pay for his own Economy package.
I had registered for the ebay seats and was an early bidder in the auctions for the pair of business class seats on ebay. Bids went way too high for my purse. The single seat went for about twice the price of the pair. Go figure. I know the buyer. He was on the first Singapore Airlines A380 Sydney to Singapore inaugural flight with a Suite. He may have grabbed the 3 seats on ebay. I am not sure.
I was contacted by the WSJ for an interview and told them I did not win anything so I sent them out to contact the winner which they did.
The aircraft doing the package inaugural flights to HKG will be diffferent from the aircraft doing the first flight to Frankfurt. I hope the ANA Chief pilot will be doing the flight. I would be happy if Mike Carricker be part of the flight though I doubt it.
tdscanuck
Thu Oct 20, 2011 7:14 am
Quoting Navigator (Reply 28):
It's not that big a deal...we've had carbon composites in aerostructures (mostly nacelles, flight controls, and fairings) for decades...the repair techniques are the same. The 787 just has a lot more areas where you can apply existing repair techniques.
According to Boeing, you can now.
They claim to be using the same bolted repairs as are in the SRM for aluminum airplanes, and for the 777 empennage:
http://www.compositesworld.com/artic...-composite-repair-builds-on-basics
Tom.
MadameConcorde
Thu Oct 20, 2011 7:54 am
Any update on the damaged engine inlet cowl?
Boeing 787 GEnx Engine – Inlet cowl, fan cowl, thrust reverser, centerbody and nozzle, engine integration
Trent 1000 engine - Inlet cowl, fan cowl, thrust reverser, centerbody and nozzle, engine integration
http://www.goodrich.com/Goodrich/Bus...tructures/Markets/Large-Commercial
I suppose they must have it fixed by now.
randomstriker
Mon Oct 24, 2011 5:47 pm
http://www.flightglobal.com/blogs/ai...tll-polish-out---ana-bumps-fi.html
From FlightGlobal.com "It'll polish out - ANA bumps first 787"
They probably had to use a scanning electron microscope to generate the inset magnification
[Edited 2011-10-24 10:53:45]
[Edited 2011-10-24 10:54:30]
bikerthai
Mon Oct 24, 2011 6:36 pm
Quoting randomstriker (Reply 32):
LOL. And we all are debating the merit of composite repair.
Almost like having a pimple on prom night. Everyone will look for it now.
bikerthai
747400sp
Mon Oct 24, 2011 7:16 pm
Looks like some, ANA ground crew man or woman, should be fired!
brons2
Mon Oct 24, 2011 7:20 pm
Everyone gets sad when they get their first scratch on their new car...err plane.
Firings, if well done, are good for employee morale.
