RobK
Cops Using Spy Planes To Record Mobile Phone Calls
Mon Oct 31, 2011 10:04 am
Not seen this posted (apologies if I've missed it).
http://www.telegraph.co.uk/news/ukne...-of-pounds-on-secret-aircraft.html
Not sure what a Cessna F04 is though.
blooBirdie
RE: Cops Using Spy Planes To Record Mobile Phone Calls
Mon Oct 31, 2011 10:11 am
Quoting RobK (Thread starter):
I can only guess it's a Cessna 404. Trouble is churnalists these days just cut and paste without taking a minute or two to Google.
lhr380
Mon Oct 31, 2011 10:13 am
Umm, I thought it was common knowledge the Police had planes. You see them all the time around Manchester
http://daverob.catalyst2.com/Flight4/PolicePlane.jpg
Saw this all the time when I lived in Manchester
RobK
Mon Oct 31, 2011 10:25 am
They do have planes, I am not disputing that, but these are special mobile call monitoring planes. Those are not the Islanders afaik or are you saying that you've known your mobile calls have been monitored by these police planes for a long time already?
nomadd22
Mon Oct 31, 2011 11:33 am
Ok. Maybe I'm unfamiliar with mobile phones in Britain, but what possible use would a plane like that be in intercepting modern digital phone calls? They'd be picking up dozens of cells at once and trying to sift one call out of thousands. It's hard enough when you're trying to do it off a single site. Not the sort of system you put on a Cessna.
In any case, I never had much sympathy for anyone dumb enough to think and call they make is private.
Anon
rfields5421
Mon Oct 31, 2011 1:05 pm
It is probably a F406 - a Cessna 404 type updated with PW PT-6 engines to make it closer to the Cessna 414 - built by Reims Aviation in Reims, France.
Cessna in the US ended production of twin piston/ twin turbo-prop aircraft about 20 years ago; however Reims continues to build new F406 aircraft today. One of their biggest sellers is a maritime surveillance version, not a big adaptation to use it for electronic surveillance.
Quoting nomadd22 (Reply 4):
As you imply - there is no difficulty for police to intercept cell phone communications. As far as an aircraft - the purpose would be to collect transmissions for later analysis at ground stations.
Folks would be amazed how easy it is to target a single phone and intercept the signals from that phone. An aircraft would be very useful for a phone when the user is in a vehicle or other transportation source.
GCT64
Mon Oct 31, 2011 1:43 pm
The Nor Leasing Cessna F406s alleged in the article to be used for this are G-BVJT and G-TDSA (both registered to them and both based at Farnborough).
I had always wondered what those aircraft did, perhaps this article provides the explanation? (or perhaps not   )
Flown in: A30B,A306,A310,A319,A320,A321,A332,A333,A343,A346,A359,A388,BA11,BU31,B190,(..54 more types..),VC10,WESX
edina
Mon Oct 31, 2011 2:05 pm
It's not just the "Met".........
http://www.raf.mod.uk/equipment/islander.cfm
These 2 Islanders are used by the RAF for "light communications" i.e. by MI5 for monitoring terror suspects mobile calls.
Worked on - Caravelle Mercure A300 A320 F27 SD3-60 BAe146 747-100/200/400 DC10-30 767 777 737-400 757 A319 A321
TUGMASTER
Mon Oct 31, 2011 2:36 pm
Quoting edina (Reply 7):
seen all the time operating out of Northolt ( NHT ) West London.
On Sunny days, often seen doing 10000ft circuits....
EDICHC
Tue Nov 01, 2011 12:36 am
A bit off topic, sorry, but looking at the aircraft specs on that link, I fail to see how this aircraft operates with zero thrust.
A300/319/320/346 ATR72 B722/732/3/4/5/6/8/742/4/752/762/3/772/3 BAC111 BAe146 C172 DHC1/6/8 HS121 MD80 PA28
contrails
Tue Nov 01, 2011 12:59 am
The feds have been monitoring cell calls for some time now. I'm not sure the state or local jurisdictions would have the legal ability to do this.
Flying Colors Forever!
readytotaxi
Tue Nov 01, 2011 12:49 pm
Quoting Contrails (Reply 10):
In the UK the police are required to go to court and get an order to intercept communications,written or spoken, M.I.5 however are a lot less restricted.
scouseflyer
Tue Nov 01, 2011 12:55 pm
They'd better take better care of it than Merseyside Police (UK) did of their drone recently:
http://www.liverpoolecho.co.uk/liver...into-river-mersey-100252-29689413/
sandyb123
Tue Nov 01, 2011 1:05 pm
Quoting scouseflyer (Reply 12):
Whops! Love the sensationalist tone of voice. Uk press huhhh.
Sandyb123
Member of the mile high club
