747classic
Pictures Of An Uncontained PW4056 Engine Failure.
Thu Nov 03, 2011 9:21 am
The first photos are emerging from an uncontained PW 4056 engine failure of a Delta 747-451 aircraft en route from Detroit to Narita.
This accident happened on Oct 23, the aircraft involved was N661US, an ex NWA 744.
See : http://www.aviationweek.com/aw/blogs...=blogScript&plckElementId=blogDest
Operating a twin over the ocean, you're always one engine failure from a total emergency.
gokmengs
RE: Pictures Of An Uncontained PW4056 Engine Failure.
Thu Nov 03, 2011 1:37 pm
Thanks for sharing this. Uncontained engine failures are rare events really.
What is te status oftne ac as of today? Can anyone share some info.
Gercekleri Tarih Yazar Tarihide Galatasaray
tdscanuck
Thu Nov 03, 2011 1:48 pm
Just to attempt to head off the inevitable...the photos clearly show liberation of multiple rotating components in the turbine section. This is *not* necessarily a condition that the engine containment is designed to handle. The regulations require containment of the most critical blade and related debris, not multiple blades or pieces of rotor. The fact that bits got out of the engine in this scenario is why the airframers design for rotor bursts.
Tom.
gokmengs
Thu Nov 03, 2011 1:55 pm
Quoting tdscanuck (Reply 2):
Thanks for the explanation as always. So just looking at the damage in these pictures does not confirm uncontained failure? The design was successful in holding the critical blade contained? Thanks
747classic
Thu Nov 03, 2011 2:58 pm
This event could be within the design containment limits of the engine, fact is that several high energy debris, blade fragments,etc. came out of the engine (partly through the engine casing - NOT fan casing) and have damaged parts of the primary flight controls (ailerons) and secondary flight controls (TE and LE flaps).
This classifies this event as an accident according ICAO.
In depth investigation will reveal if the damage is outside or inside engine containment limits.
Thrust
Thu Nov 03, 2011 4:21 pm
I'm assuming this is not a write-off? To my knowledge, N661US is the first Boeing 747-400 off the production line.
Fly one thing; Fly it well
litz
Thu Nov 03, 2011 4:30 pm
Per Flightaware (e.g., take with grain of salt), it has not flown since the incident.
That being said ... again with a grain of salt ... as long as the whizzing bits of escaped turbine blade didn't do anything major to the airplane itself, it should be a fixable issue, one would think.
What's the status of engine spares might be a better question to ask ...
as739x
Thu Nov 03, 2011 4:31 pm
Quoting Thrust (Reply 5):
The engine will be a write-off. But the plane doesn't seem to have any damage, so No.
777STL
Thu Nov 03, 2011 5:03 pm
Quoting as739x (Reply 7):
Ehh, not according to the article.
"On return to Detroit post-flight inspections revealed severe damage to the engine and wing with large holes noted in the cowling as well as damage to slats, flaps and aileron. "
PHX based
n685fe
Thu Nov 03, 2011 5:07 pm
We have covered this before, but let's refresh....
FAA & NTSB defines an accident and regulations for an uncontained failure as follows,
http://www.airsafe.com/events/define.htm
http://www.skybrary.aero/index.php/Uncontained_Engine_Failure
http://rgl.faa.gov/Regulatory_and_Gu...570d5006ff49b/$FILE/2005-25-09.pdf
http://faa.custhelp.com/cgi-bin/faa....RzPSZwX3B2PSZwX2N2PSZwX3BhZ2U9MQ!!
http://www.airweb.faa.gov/Regulatory...047AC852565C500612017?OpenDocument
From the description of the article, the damage to the wing would be the most critical component involved and the type of repair to it, major or minor, would define the classification.
psp. lead by example
flyinryan99
Thu Nov 03, 2011 5:14 pm
Quoting litz (Reply 6):
Correct. The airplane is still up at the hangar in DTW.
Quoting 777STL (Reply 8):
Nothing that can't be fixed.
seabosdca
Thu Nov 03, 2011 5:45 pm
Ouch!
Quoting flyinryan99 (Reply 10):
But is it worth the cost of the necessary repairs to the wing on a 1989 744 that probably is close to 100,000 hours?
n685fe
Thu Nov 03, 2011 6:36 pm
That all depends on which bean counter you ask. Some view the capital expense for an out right puchase to save on fuel out weighs operating a payed off a/c. Most airlines have a mix of owned and leased a/c, so it just means playing with the numbers to support the direction you want to go. It also depends if you have any -400's that are in storage and could be returned to service for a lower cost then the repairs required for this one.
If you were to ask me, and delta plans to keep the 747 in their fleet, I would repair if possible. If it did need to be scrapped, I would replace it if needed with another used frame rather then purchase a new frame. With such a small fleet of 747's it would make sense to plan a fleet upgrade rather then stick a single -8 (if it were even available) into the fleet of -400's. The commonalities between the two would help but running a single or couple of new -8's would prove expensive within just a couple of years.
[Edited 2011-11-03 11:38:33]
flyinryan99
Thu Nov 03, 2011 7:03 pm
Quoting seabosdca (Reply 11):
Depends on the insured value of the aircraft...my guess is they have a very high deductible like $500k to $1M. Also, if the engine failed itself and was not caused by ingestion, then the engine failure is not covered. So, that being said a new engine would be needed plus their deductible before they hit their insurance. Delta can decide not to fly it anymore and scrap it, but the aircraft itself won't be totaled unless there is spar damage or something like it. I'm sure I would've heard it if it was going to be a big loss
SEA
Thu Nov 03, 2011 7:18 pm
First off the production line, but 6th delivered.
sgtusmc96
Thu Nov 03, 2011 8:16 pm
The engine is a total write off like stated before. Other than that all the other damage was minimal. Some composite work and light sheet metal work and whole lot of inspections. A/C should be back in the air by the end of the weekend.
seabosdca
Thu Nov 03, 2011 9:03 pm
Quoting sgtusmc96 (Reply 15):
Good to hear. With the description above, I was thinking this was a VH-OQA sort of situation with the wing...
wn700driver
Fri Nov 04, 2011 12:32 am
Quoting SEA (Reply 14):
Correct. I believe N663US was actually the first in service; also a NW turned DL machine, of course...
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
Okie
Fri Nov 04, 2011 2:01 am
The linked article stated that only 16 747's were painted to DL colors that in its self would indicate 64 turbines in service.
Whether that is leased power by the hour or DL owned in any case with 64 active turbines of the same model there more than likely more than one spare power plant somewhere in the system that was looking for a home as the 400's start to wind down.
I agree that since nothing was mentioned about structural damage or fuel tank leakage. Just some sheet metal work and a few replaceable/repairable parts the plane will be back in action in short order.
I am thinking there are a few that are either trying to compare the major structural damage to QF's 380 to minor sheet metal work or in a hurry to push DL's 744's to VCV
Okie
traindoc
Fri Nov 04, 2011 2:28 am
Very reminiscent of the QF engine failure on climb out from SIN! For whatever reason, this incident got almost no media coverage. What we don't know is what systems were damaged by the shrapnel exiting the engine. Any guess as to why the media seem to have ignored this potentially serious event? (Aviation Week excepted)
KDTWflyer
Fri Nov 04, 2011 5:38 am
http://flightaware.com/live/flight/D...5/history/20111023/1925Z/KDTW/KDTW Here you guys can see it orbiting around dumping fuel after the failure. Pretty crazy stuff. At least the engine remained on the pylon unlike the Kalitta B741 which LOST an engine over Lake Michigan and made an emergency landing at DTW. As of now N661US is still stuck in DTW.
NW B744 B742 B753 B752 A333 A332 A320 A319 DC10 DC9 ARJ CRJ S340
KDTWflyer
Fri Nov 04, 2011 6:11 am
I think they will repair it because even if they were going to scrap it wouldn't they have to fly it out to say AZ or something? Or maybe leave DTW on 3 engines haha?
BTW here are a couple vids of it dumping fuel over SE Michigan.
http://youtu.be/WrW_ClLvKFo
http://youtu.be/TToh1LPOBj4
tdscanuck
Fri Nov 04, 2011 6:21 am
Quoting gokmengs (Reply 3):
There are holes in the engine case...that confirms uncontained engine failure. But that's not necessarily a violation of any design requirements. There is a popular, but very wrong, belief on a.net that the engine is supposed to contain all failures. It's not...it's just supposed to contain some specific failures. The fact that an engine has an uncontained failure is, by itself, no evidence that there is a design problem with the engine.
Can't tell yet...if it was a blade failure that started it all, the engine failed (because it's supposed to contain the critical blade and any resulting debris from the failure). If it was a multi-blade failure, or FOD, or a rotor burst, then it may not be a design problem.
Quoting traindoc (Reply 19):
Other than both incidents involving engines, not really reminiscent at all.
Because this one didn't do nearly as much damage to the airframe, did not (as far as the public evidence shows) demonstrate any design failure, and didn't endanger the passnegers, crew, or airframe.
We know it wasn't as bad as the QF A380 failure...this engine at least responded to commands and, according to all media reports, the shrapnel didn't sever any primary structure.
Because it wasn't nearly as serious.
Tom.
