Mortyman
Pan Am: London-New York In 88/90
Sun Nov 13, 2011 5:06 am
I flew Pan MA B747 between London and New York and back, both in 1988 and 1990. Is it possible to find out the Clipper names of these aircrafts or did Pan Am change aircraft frequently on this route ?
XXXX10
RE: Pan Am: London-New York In 88/90
Sun Nov 13, 2011 8:37 am
All PA aircraft were called clippers, if you have the registration of the planes that you flew on then, if you put it into google you will probably find the name.
If not it could be any PA aircraft. AFAIK, there were not any specific aircraft allocated to that route.
rutankrd
Sun Nov 13, 2011 9:45 am
Quoting Mortyman (Thread starter):
Yes its possible if you know the flight numbers day of operation and routing
This site will give you the registration/tail number
http://www.lhr-lgw.co.uk/groupfiles/newlhrarchives.htm
From that this site can help you identify the name
http://www.panamair.org/aircraft/clippernames.htm
Mortyman
Sun Nov 13, 2011 11:11 am
Quoting rutankrd (Reply 2):
http://www.panamair.org/aircraft/cli...s.htm
Thank you, but I gave up finding it. I'm not sure how to read it. If I should look at departure time from Heatrow or what ...
I flew 12.03.1988 from Heatrow to New York 11:00
Flew from 01.04.1988 New York to London 19:00
From Heatrow to New York 18.07.1990 11:00 Flt PA101
From Miami to London 30.07.1990 18:15 F lt PA 1098
[Edited 2011-11-13 03:18:43]
adambrau
Mon Nov 14, 2011 3:06 am
Flight numbers were pretty consistent in the last years on JFK-LHR-JFK
JFK-LHR 0900 dep PA100
JFK-LHR 1900 dep PA2
JFK-LHR 2100 dep PA102
LHR-JFK 1100 dep PA 101
LHR-JFK 1300 dep PA1
LHR-JFK 1800 dep PA103 then PA 3 then PA11
There was also a 4th departure in the summer some years, PA 104/105
