Jonathanxxxx
Why Did Southwest Never Start Puerto Rico?
Sun Nov 13, 2011 6:22 pm
The thought came up now.. How come they've never started Puerto Rico? Is it because they need over water equipped planes? I would assume that from Florida and Texas they shouldn't but I'm not too sure about the Northeast. I know JetBlue doesn't have them yet they're pretty large in Puerto Rico. The 737's could have also easily made it from FLL, TPA, MCO, MSY, HOU etc. . It would also technically still be a domestic flight. So why have they never started it?
longhauler
RE: Why Did Southwest Never Start Puerto Rico?
Sun Nov 13, 2011 6:26 pm
Depending on the route you take, SJU would require HF radios and life rafts/jackets from the NE United States.
My guess though, as SJU can tend to low yield, and long range, that really isn't fitting with the "Southwest Model". Perhaps as they develop the ATL hub, that may change. (From ATL to SJU, only life jackets are required).
OzarkD9S
Sun Nov 13, 2011 6:41 pm
They offer it now, via FL. Once the code-share is in place SJU will pop up on southwest.com. For now you can book FL and eventually your A+ Rewards will move over to Rapid Rewards, which is what I'll be doing next year when I visit P.R.
Next Up: STL-MIA-GCM-MIA-STL. Fun in the December sun! :santahat:
Cubsrule
Sun Nov 13, 2011 6:59 pm
Quoting longhauler (Reply 1):
Further, regardless of the routing, Puerto Rico cannot be flown on a Domestic certificate, which is what WN has.
Western727
Sun Nov 13, 2011 7:04 pm
Quoting Cubsrule (Reply 3):
Will this impact the routes to SJU once WN/FL get their SOC?
Jack @ AUS
Cubsrule
Sun Nov 13, 2011 7:06 pm
Quoting Western727 (Reply 4):
While I've not heard it officially, I assume they are keeping FL's certificate since it is Flag and the 717s are on there.
glbltrvlr
Sun Nov 13, 2011 11:05 pm
WN has had life vests on all their aircraft for a number of years now. It lets them serve Florida from the southern and western parts of the country without having to follow the coast.
einsteinboricua
Sun Nov 13, 2011 11:09 pm
Maybe it's because they consider SJU an international destination, which is something I've never understood. Airlines treat it as a "domestic" flight, but for ticket sales and such, some treat it as an international.
"You haven't seen a tree until you've seen its shadow from the sky."
Cubsrule
Sun Nov 13, 2011 11:23 pm
Quoting einsteinboricua (Reply 7):
FAA treats Puerto Rico (and Hawaii and Alaska) as "international" insofar as a Flag certificate is required to operate scheduled service to those places.
longhauler
Mon Nov 14, 2011 1:56 am
Quoting glbltrvlr (Reply 6):
Yes, but to go into New York oceanic, from say JFK area to SJU, HF radios and life rafts are required.
Quoting Cubsrule (Reply 8):
Interesting, didn't know that. What is a Flag certificate?
rfields5421
Mon Nov 14, 2011 1:49 pm
Aside for the key issue as noted above that for all intents and regulations - SJU is an international destination for the FAA
SJU doesn't fit into the WN business plan.
It is a single point destination 900+nm from any other possible service location. It is a low yield destination for the SWA passenger model. It ties up aircraft for longer periods of time than WN normally does.
Using the FL certificate and aircraft would easily meet the goal of international service, allow them to test and fine tune international operations , but preserve the domestic WN operation until the international was worked out sufficiently to integrate.
WN is slowly testing and building more long distance flights and capacity into their network. Something like SJU will come.
The one thing WN does not do is jump into a city/ location/ type of service without extensive planning and preparation. Their 'failure' rate of new service locations is much lower than other airlines.
ha763
Mon Nov 14, 2011 11:59 pm
Quoting longhauler (Reply 9):
It basically means that a U.S. airline can operate flights to foreign destinations. If you fly more than 2 hours from the U.S. or in Class II navigation airspace you need to have a flag certificate in order to operate. That's why Alaska, Hawaii, Guam, American Samoa, Puerto Rico, etc. all require operators to have a flag certificate.
