SMFBase
UPS Aircraft @ SMF
Tue Nov 29, 2011 5:08 pm
Sitting here at SMF and noticed both a UPS 757 & A300 on the ramp in front of Terminal A. While a diversion for weather seems logical I couldn't imagine it being that much worse at Mather than SMF. Especially since the visibility this morning has been less than 1/8 mile at SMF. Also, looks like there are ground ops in motion with the side cargo doors open. UPS 956 & 960 are the flights that arrived early this morning.
as739x
RE: UPS Aircraft @ SMF
Tue Nov 29, 2011 5:29 pm
Quoting SMFBase (Thread starter):
Mather doesn't have a Cat III approach like SMF has. SMF has both Cat II and III which can bring you down to 700 and 600 RVR respectively.
tridum
Tue Nov 29, 2011 5:32 pm
This time of year, you will see a lot of different UPS planes at different gateways because of fly through flights due to the Holiday season.
IMissPiedmont
Tue Nov 29, 2011 5:36 pm
Quoting tridum (Reply 2):
Not in this case, it was a weather diversion.
The day you stop learning is the day you should die.
SMFBase
Tue Nov 29, 2011 5:48 pm
Quoting as739x (Reply 1):
Thanks for the information. Looks like UPS has a back up plan as a few UPS semi trucks just arrived at the ramp. Assuming they are taking the cargo to the distribution center.
