Gonzalo
Ab 320 Engine Panel Falls Off During Climb Out
Wed Nov 30, 2011 6:50 pm
This is not the first time ( and probably will not be the last ) that an aircraft component has detached in flight.
Thank god nobody was injured either on the ground or the aircraft.
http://www.avherald.com/h?article=446ebe7a&opt=0
Anyone with more info about this ?
How close is this airport to populated areas ?
Rgds.
G.
Gear Up!!: DC-3 / EMB-110 / Fairchild-227 / Ab318-19-20-21 / B732 / B763 / B789
garpd
RE: Ab 320 Engine Panel Falls Off During Climb Out
Wed Nov 30, 2011 7:38 pm
At least the engine won't have a chance to overheat
arpdesign.wordpress.com
srbmod
Wed Nov 30, 2011 8:39 pm
Sounds like a similar situation to what happened to a Ryan International A320 several years back while operating for AirTran. One of their mechanics (Ryan Int'l, not AirTran) apparently didn't make sure the latch on one of the engine cowlings latched properly and during climb out, the panel was torn from the engine.
http://airlinenightmare.com/blog/wp-content/uploads/2010/07/airtranair.sized-copy.jpg
I wouldn't be surprised it this Wizzair incident mirrors the Ryan International incident, as I've heard this sort of thing has happened on multiple occasions, but not always resulting in parts falling off.
fpetrutiu
Wed Nov 30, 2011 8:48 pm
The airport is surrounded by not rural populated areas depending on which direction they took off on. If they webst east, there is nothing but open fields, west however, there are some business, car dealerships, and industrial areas.
Florin
Orlando, FL
B6JFKH81
Thu Dec 01, 2011 12:14 am
Quoting srbmod (Reply 2):
Yes, yes it has. The latches are now bright orange to make sure that MX, G/O and flight deck crews all have the chance to see them if in the open position before departure (for my airline at least).
From the following Transportation Safety Board of Canada report on an incident:
http://www.tsb.gc.ca/eng/rapports-re...viation/2000/a00o0199/a00o0199.asp
...there is a pic of these bright orange latches:
Any little help in identifying an open latch helps reduce the chances of an aircraft departing with an unsecured cowl.
