LAXintl
Delta Vacates Dormant Mexico Routes
Wed Dec 21, 2011 8:47 pm
Delta Airlines filed with the DOT notice that it will withdraw designation on several currently dormant Mexico authorities and that it holds no intention of resuming the routes with its own metal.
Austin - Cancun
Memphis - Mexico City
Minneapolis - Mexico City
San Antonio - Cancun
OST-2010-0133
OST-2010-0196
OST-2010-0230
slcdeltarumd11
RE: Delta Vacates Dormant Mexico Routes
Wed Dec 21, 2011 8:55 pm
Not really surprising to see any of these. Mexico routes are weak right now. MEM-MEX and MSP-MEX bombed and tourism to Mexico is suffering big time.
point2point
Wed Dec 21, 2011 9:02 pm
Quoting LAXintl (Thread starter):
Austin - Cancun
Quoting slcdeltarumd11 (Reply 1):
I would guess that tourism is really off if both Austin and San Antonio can't even fill a seasonal weekly flight to this overwhelmingly tourist destination.
With these two though, I think MSP is a bit of a surprise that they can't fill a weekly seasonal, considering connections, but with MEM, well, even with connections, no real surprise.
FlyASAGuy2005
Wed Dec 21, 2011 10:12 pm
Quoting point2point (Reply 2):
The problem was never really LF but stage-length o the flight considering the relatively weak performance. They'd rather stick the local and connecting pax on one of the many flights to Atlanta and connect from there. Look at MSP-HNL. It    would have continued to hold its own but again, why uffer on such a long route when you have legal connections through LAX, SEA, SFOand SLC. The first 2 with the flights originating in Minneapolis and opeating on the same equipment to HNL.
What gets measured gets done.
atrude777
Wed Dec 21, 2011 10:27 pm
Austin - Cancun
What a surprise!
More for Frontier to apply for or could we see Southwest making a bid for them?
I could see WN doing AUS-CUN, not sure if MEM or MSP would be worth it. Totally could see F9 applying for the other SAT-CUN.
MEM or MSP don't provide much feed the way AUS would in comparison but MSP or MEM could signal further expansion domestically if WN sees something there in MEM especially with the pulldown of the Delta Hub.
Alex
LAXintl
Wed Dec 21, 2011 10:57 pm
Personally with the new closer relationship with AeroMexico, Im surprised Delta cannot and has opted not to pursue a link from its MSP or MEM hubs to Mexico City.
Regardless of the actual segment performance seems like the routes would be beneficial from a broader network and integration aspect.
boeing773er
Wed Dec 21, 2011 10:59 pm
I would like to disagree, I flew from PHX-SJD at the end of October and the plane was full, no open seats at all.
A few people were actually bumped because of this...
Work Hard, Fly Right.
traindoc
Wed Dec 21, 2011 11:11 pm
I believe that CO still operates the SAT-CUN route on Saturdays.
smoot4208
Wed Dec 21, 2011 11:14 pm
SJD is really one of the few Mexican markets that have not felt the impact the other destinations have
bennett123
Wed Dec 21, 2011 11:19 pm
How long have they been dormant for?.
MaverickM11
Wed Dec 21, 2011 11:21 pm
Quoting LAXintl (Reply 5):
Did you see the load factors for either? No amount of codesharing could save them.
E pur si muove -Galileo
sxf24
Wed Dec 21, 2011 11:24 pm
Delta has been pretty clear that every route must now stand on its own. What exactly that means is unclear; however, it is pretty obvious there aren't many markets with meaningful traffic to MEX that are severed via MEM or MSP, but not from ATL or another DL/AM gateway city.
mariner
Wed Dec 21, 2011 11:43 pm
Quoting atrude777 (Reply 4):
I'd be very surprised if Frontier applied for AUS-CUN. It tried it years ago, in the original Mexican expansion, and it was a real turkey - a dozen pax on some flights - even with a tour operator involved (Funjet, perhaps?).
If Southwest can make it work, good luck to 'em.
mariner
[Edited 2011-12-21 15:46:02]
aeternum nauta
EddieDude
Thu Dec 22, 2011 7:22 am
I had no idea that MSP-MEX was not doing well and that it was, in fact, terminated. Pity.
AUSisAWESOME
Thu Dec 22, 2011 4:58 pm
Quoting traindoc (Reply 7):
CO/UA also operates AUS-CUN. The second that CO announced the flight DL pretty much ended it. CO has a much bigger passenger-base in AUS than DL does.
Upcoming flights: XNA-ATL-TGU/DL XNA-DFW-AUS/AA XNA-LAX/AA
threeifbyair
Thu Dec 22, 2011 5:21 pm
But the connections are terribly inefficient - only someone in Winnipeg or Duluth is going to appreciate a more direct routing thru MSP than what is available over DFW, IAH, or ORD. Being north of most of its connecting service area is a big negative for MSP for north-south routes. East-west connections are completely different, which is why MSP is still a great hub for DL, just not for Mexico flights.
Passengers from the Northeast and Mid-Atlantic regions have efficient routings by connecting in ATL (the Great Circle route for BOS-MEX overflies ATL, for example).
MEX, in my understanding, is more of a business and VFR market than a tourism destination, like CUN. Thus a weekly flight would be pretty much worthless.
EddieDude
Thu Dec 22, 2011 7:40 pm
Quoting ThreeIfByAir (Reply 15):
While MEM-MEX was from the very beginning a once weekly service to essentially let an idle A32X or 738 fly and help relieve ATL with connecting pax, I believe MSP-MEX started as daily service. Can anyone confirm? Maybe I am wrong. Thanks.
Oh, and yes... sadly MEX does not command the number of foreign tourists that it deserves. In that sense it is from the U.S. more of a business and V.F.R. destination (and in DL's particular case some DL to AM connections for V.F.R. fliers and tourists going to secondary Mexican cities).
yellowtail
Thu Dec 22, 2011 7:48 pm
Austin - Cancun
Watch for WN to jump on these.
Quoting sxf24 (Reply 11):
It means that the route most work without route subsidies (i.e. there must be demand to fill the seats). Some of the airlines are now taking the position (and rightly so) that there is no point in starting a route, even with subsidies, that has no demand, and will close after the subsidy runs out. There was a panel discussion some weeks ago at NETWORK in SJU where it was mentioned that subsidies do not solve the inherent problem of demand building.
When in doubt, hold on to your altitude. No-one has ever collided with the sky.
atrude777
Thu Dec 22, 2011 8:15 pm
Quoting yellowtail (Reply 17):
WN already got approved for SAT-CUN, that's why I said, I'd expect AUS-CUN for WN and SAT-CUN to happen for F9.
mariner
Thu Dec 22, 2011 8:23 pm
Quoting atrude777 (Reply 18):
If Southwest already has SAT-CUN - why would Frontier go for it? I don't think there is any big Apple presence at SAT.
mariner
aeternum nauta
atrude777
Thu Dec 22, 2011 8:34 pm
Quoting mariner (Reply 19):
mariner
Hadn't considered the Apple part, just the way F9 had been going into big international expansion mode, it made sense to me to simply add SAT-CUN.
Honestly to me in terms of SAT-CUN, I don't think WN and F9 would be directly competing, while yes they would be flying the same route, I was just simply thinking "Hey DL pulled out of SAT-CUN, that gives F9 another authority to try for"
F9 doesn't seem to be worried about competition so much from WN, I would hope WN being on SAT-CUN shouldn't scare F9 away from trying for it. As much of a big WN fan as I am, and I know you're aware of it, I am also for competition and variety, so I'd love to see F9 on SAT-CUN too to give WN a fight, and to help out the Customers in giving choices.
Alex
flybynight
Thu Dec 22, 2011 8:51 pm
I recently talked with an AS Captain about the decreasing number of flights to Mexico. And he told me just what I thought - tourism is way down. This is also the reason why AS is flying so many flights to Hawaii instead.
Mexico is damaged goods right now and people are looking elsewhere for vacations.
He also said that AS had a crew get shot at in Cancun. Shortly thereafter AS stopped flying there.
Heia Norge!
yellowtail
Thu Dec 22, 2011 10:01 pm
Quoting flybynight (Reply 21):
What was the crew doing to get shot in CUN?
As didn't stop CUN because a crew got shot there. They stopped because the yields were atrocious on that stage length.
[Edited 2011-12-22 14:02:45]
mariner
Thu Dec 22, 2011 10:58 pm
Quoting atrude777 (Reply 20):
I can't know the future, but I would be surprised to see Frontier on SAT-CUN - I was very mildly surprised to see Southwest on, but it gets a fair amount of feed, I guess.
I think that for Frontier/Apple there are so many other possible opportunities (many of them not in Mexico) without butting heads with Southwest again.
I look at the old USA3000 route map - when it was at its peak - and salivate.
mariner
aeternum nauta
MSPNWA
Thu Dec 22, 2011 11:21 pm
Quoting EddieDude (Reply 16):
I remember it being daily.
That would help explain the MSP-MEX load factor in F versus Y. F wasn't too bad. But Y loads were beyond dreadful.
