Shany
Etihad A330 Problem In FRA?
Tue Jan 03, 2012 12:47 pm
Hey out there,
anyone any information on the Etihad A330 that landed at FRA on January the 2nd, 2012 on 25C and stopped there for a while with fire brigade waiting on him? Later they where able to taxi to their parking stand on own power with the fire brigade escorting him.
Best regards
Shany
ETOPS - Engines Turn Or People Swim
migair54
RE: Etihad A330 Problem In FRA?
Wed Jan 04, 2012 12:18 pm
It could be many reasons...
-hot brakes.
-Hydraulic problems.
-flat tyre.
-steering problems.
-low pressure on tyres.
-and many more....
However if they taxi with own power and no tug.... My guess is hot brakes....
PanHAM
Wed Jan 04, 2012 12:21 pm
It was a problem with one engine, The aircraft returned to FRA shortly after take off with a shut down engine. Was so reported in today's media.
powered by Eierlikör
Shany
Wed Jan 04, 2012 12:37 pm
Quoting migair54 (Reply 1):
-hot brakes.
-flat tyre.
-steering problems.
-and many more....
Don't get me wrong, but I asked if someone had more info about it, not just speculation.
Quoting PanHAM (Reply 2):
Thank you, so my thought, that engine no. 2 was shut down, was correct? Because it did not produce any jetblast on the wet surface. Unfortunately no report on avherald until now.
BTW, they had their speedbrakes extended until leaving the runway. On the 757 you have to be careful concerning the speedbrakes in a possible evacuation scenario since they would block the overwing exits. On the 767 they are automatically retracted once the overwing slide deploys. How about the A330?
Thank you
Shany
something
Wed Jan 04, 2012 1:37 pm
You will probably find your answer here
http://www.smartcockpit.com/data/pdf...nd_Systems_Briefing_For_Pilots.pdf
I would assume that in an automated aircraft such as the A330, the speed brakes will automatically be released in the case of a slide deployment.
..sick of it. -K. Pilkington.
Shany
Wed Jan 04, 2012 2:19 pm
Well, my fault. The A330 doesn't have overwing exits, does it?
Best regards
Shany
Shany
Wed Jan 04, 2012 2:21 pm
Quoting something (Reply 4):
Nice document, thank you.
Shany
Shany
Thu Jan 05, 2012 9:50 pm
