eastern023
The Future Of Star Alliance In S. America
Wed Jan 11, 2012 10:08 pm
2012 is turning out to be a big year for Latin and South America and air travel. First and most importatly LATAM merger will come to pass and Star Alliance (at least so it seems) will lose its Brazilian Star (Sounds like the Varig old song theme but anyway...) to OneWorld. Avianca-Taca to merge and join Star along with COPA of Panama, these companies would give Star access to Deep SouthAm, but it will lack connectivity to Europe. Without considering the non-top service to Europe, one would Argue that AV can feed flights through BOG, but the truth is that the most desired (albeit jammed) connecting point is GRU (and that is going to OneWorld. Avianca Brasil seems to be making the effort to become bigger but the size of its operations is a far cry from what TAM is or Varig used to be. What do you see Star's long term strategy is for South America?
AA will Rise Again!
2travel2know2
RE: The Future Of Star Alliance In S. America
Thu Jan 12, 2012 6:54 pm
Avianca Brazil has a long way to go to fill the expectations Star Alliance has for the regional South American and Brazil -Europe markets.
If Avianca remains in Star - as it's rumoured Sky might be after them - AV Colombia will have the hard task to star some key routes out for GRU/GIG. But things may not be that easy since GRU is slot restricted and the available/affordable slots are roughly between 2300h and 0600h. Setting up an operation @ VCP to take care of Sâo Paulo should be dismissed as unrealistic as long as VCP doesn't offer a fast link with Sâo Paulo major areas.
If there's such a void in deep South America for Star Alliance then its airlines flying there should try to see if through 5th liberty are OK to operate some of the key international routes so to at least offer an Star Alliance presence in those major routes.
Flying via PTY or BOG among these countries: Chile, Argentina, Uruguay, Paraguay, Brazil (except MAO), Bolivia and Peru doesn't really make any sense.
I'm not on CM's payroll.
PDPsol
Thu Jan 12, 2012 9:17 pm
Quoting 2travel2know2 (Reply 1):
You are aware AV has not even formally joined Star yet. The carrier and its affiliates at TA are expected to join Star this May and reveal common branding.
The regional strategy for Star in South America does, indeed, revolve around AV. The addition of O6 to the alliance, as well as the transfer of its ownership from Synergy SA directly to AVIANCA-TACA Holding is also expected sometime in the future.
The region's most important market is Brasil, and has always been Brasil. Infrastructure and capacity issues at GRU are well known and AV will need to adapt its market strategy if it wishes to develop O6 into a full competitor to TAM, G3 and Azul.
AV's regional strategy also includes its hub at LIM, via its T0 affiliate. Together, LIM and BOG can be developed to provide key links between markets in North and South America, as well as intra South America. AV is already planning to station one of its A330-200 at LIM, with more expected.
AV, TA, O6, etc. have much work ahead of them.
jfk777
Thu Jan 12, 2012 10:15 pm
Quoting eastern023 (Thread starter):
Star has a number of cities which can provide access to Europe from both Latin and European airlines. Bogota, Lima, Guatemala, and San Jose among them. AV/Taca could even merge with Copa and turn Panama into a true hub not just a Latin hub.
2travel2know2
Thu Jan 12, 2012 11:09 pm
Quoting jfk777 (Reply 3):
CM is a one-hub operation, CM (P5) presence in BOG is more of the focus type than hub. CM may not like the idea to share its hub with SJO, SAL, BOG and LIM hubs.
yeogeo
Thu Jan 12, 2012 11:40 pm
Quoting PDPsol (Reply 2):
In your opinion is Copa insignificant, or does it have a role to play? I notice you don't mention them at all in your post and you seem up to speed in the situation there.
(Avianca) and its affiliates at TA are expected to join Star this May and reveal common branding.
So parent company and affiliates includes Avianca Brazil (T0) and Taca... any others?
The re-branding will occur simultaneously with the admission into Star? Interesting!
yeo
One great use of words is to hide our thoughts. Voltaire
xiaotung
Fri Jan 13, 2012 12:30 am
So AV-TA will join *A as one carrier not two with one IATA code?
PDPsol
Fri Jan 13, 2012 5:15 am
Quoting yeogeo (Reply 5):
Of course CM is significant in Latin America to Star and its members. CM, however, does not operate a carrier within Brasil, and it has one hub at PTY, not two in South America such as AV, BOG and LIM.
CM has done extraordinary work developing markets between North America and deep South America via its PTY, including key destinations in Brasil, BSB, MAO, CNF and GIG, as well as MVD in Uruguay. Nonetheless, the scale of CM's business in South America will not approach that of AV and its myriad affiliates in Peru, T0, Ecuador, 2K, Brasil, O6, and, of course Central America, El Salvador, Costa Rica and Guatemala, TA, LR and GU.
Quoting xiaotung (Reply 6):
AVIANCA-TACA will maintain its disparate carriers throughout the region, as it must for legal and regulatory purposes. However, it is expected they will reveal a common brand and, of course, integrate operational activities to the extent they are able to given legal and regulatory thresholds.
Latin America is still comprised of various nations, with sovereigns maintaining certain independent commercial aviation policies. Some nations have signed cooperation and liberalization agreements and AV is certain to take advantage of those. Of course, AV as a single carrier, with a single operating certificate cannot, as of yet, market and commercialize internal cabotage flights in other nations. One day, perhaps, the largest nations, Brasil, Colombia, Argentina will homogenize their policies and regulations. I do not foresee that occurring in the near future.
The LAN-TAM transaction, as well as the AV-TA merger have consolidated much of the region's commercial aviation sector. One can argue commercial efficiency and pan-regional coverage are in the cards for the future.
