readytotaxi
Continental History Question LGW-747 Incident
Tue Feb 14, 2012 4:56 pm
A friend who worked at LGW in the 80's was relating a story to me about a CO 747 that took off from LGW on 26L and then struggled to gain height almost clipping trees at the end of the airport, he says it returned after dumping fuel.
Don't recall such an incident with CO,could be wrong. Anyone else the wiser?
skipness1E
RE: Continental History Question LGW-747 Incident
Tue Feb 14, 2012 5:39 pm
I was there in Feb-93 when one nearly clipped the south terminal after deviating from the ILS in LVP
readytotaxi
Tue Feb 14, 2012 5:58 pm
Quoting clydenairways (Reply 1):
WOW, so that's the one. A quick Goggle I did found nothing. Well done, many thanks.
eadc8
Tue Feb 14, 2012 6:31 pm
721 722 731 732 733 73G 738 741 742 744 752 753 762 764 DC8 DC9 MD80 DC10 L1011 A300 A319 A320 A332
planespotting
Tue Feb 14, 2012 8:04 pm
Quoting EADC8 (Reply 4):
Here is a video of the very same incident:
Yikes.
I read most of the report posted earlier - it seems that for about 4-8 seconds, the aircraft was in some real danger. Not only was the 742 only 1,000 lbs below MTOW, but due to windshear, it simultaneously lost 8 knots of headwind component as the wheels left the ground, which was the exact same time it lost power in the no. 4 engine. The stick shaker shook intermitantly for about 30 seconds as the aircraft reached 150 AGL, descended as low as 105 feet AGL, and finally clawed its way back to a three-engine climb profile after reaching V2 and retracting the flaps.
Do you like movies about gladiators?
