Difference Between B737-300,-400,-500, Etc....
Mon Oct 09, 2000 12:06 pm
Does anyone know an easy way to tell the difference between Boeing 737-300, 400, 500, etc.... in flight, that is just looking at it in flight, not having any pre-flight knowledge (i.e. pilot, mechanic?) also, does anyone one know where i can get a sillouete chart of commercial aircraft, such as one's pilots in wwII used for ships and enemy aircraft? any help would be appreciated
USAFHummer
RE: Difference Between B737-300,-400,-500, Etc....
Mon Oct 09, 2000 12:34 pm
On the ground, the best way to do it is by window configuration, I can't answer for it in the air, because no commercial jetliners fly over my house. Jane's Aircraft Recognition Guide, a $20.00 book, gives silhouettes and basic stats for 500 different civil and military flying machines.
G.R.
Rotate777
Mon Oct 09, 2000 1:46 pm
the -400 is the longest of the three. The -500 is the shortest. The -300 is in the middle. You can tell if it's a -500 because there are 8 windows (i think) in the front. The -300 has 12. Not sure about the -400. You can spot a -500 in the air easily since it's short. You'll know...
tupolev154b2
Mon Oct 09, 2000 2:06 pm
The 737-500 should be recognized by its size. The 737-400 has 2 overwing exits. The 737-300, well not sure how to recognize it.
Mon Oct 09, 2000 4:48 pm
And basically, the -600 is a -500,
the -700 is similar to -300
the -800 is just slightly longer than -400.
Also, I am not sure, but I think I noticed that the NGs have less oval engines and higher tails. Can anyone confirm this?
ewr757
Mon Oct 09, 2000 8:34 pm
Correct about the oval intakes and higher tail on the NG's
